Everything posted by druxey
Nice looking set of oars.
- 31 replies
- Lowell Grand Banks Dory
- Model Shipways
Sails on a British Cruizer Class Brig
druxey replied to DennisL's topic in - Build logs for subjects built 1801 - 1850
Royals. if present, would only be flown in very light airs. -
I think most readers here understand that different folk like to work at their own level and most will respect that. As James (an Administrator with a capital 'A') said, the armchair arrogants usually end up elsewhere.... Welcome aboard!
L'Amarante by marsalv - 1:36 - POF
druxey replied to marsalv's topic in - Build logs for subjects built 1501 - 1750
Sweet! -
Good questions. I think you need to do your own research. Look online in the RMG site. Check not only the plans, but contemporary model photos as well. An example: https://www.rmg.co.uk/collections/objects/rmgc-object-66464 Blow up this image. Although lo-res, you can see that the fore face of the bollard timber projects forward of the hawse timbers, above the line of planking - in this case.
My method is to use a long length of wire, and bend one end into a short 'V'. Then thread on the ring. The next step involves holding the two end of the V (inverted so gravity moves the ring out of the way) )in a parallel plier and squeezing the V together using a needle-nose pliers. I then release the ringbolt and, with fine wire cutters, cut the short end at an angle and then the longer end to make a stem. As observed by Gregory, the bolt is partially sunk into the wood. After drilling a suitable hole, I open it up using a miniature jewelers' screwdriver tip held at about a 35 degree angle. This forms a sort of countersink for the ringbolt.
Early carronade mounts are a subject in themselves. This was something I delved into some years ago for a 1782 fireship. From the evidence I could uncover in Caruana and elsewhere, the early carronades were mounted on the 'outside principle' and had no muzzle extension to limit blast spread. Also, there were no wheeled trucks on the inboard end of the slide. I'm about to read your pdf and may have some additional comments later.
While the use of wax or modeling clay (Plasticene) is very helpful to work out the problems of a carving in 3D, the process is quite different. In the case of carving, the process is subtractive, while modeling using a plastic material is additive. Sure, one can carve wax and clay, but if a mistake is made , one simply adds more material. Try to do that with stone or wood!
