Everything posted by druxey
Well, that looks more plausible, but are the lengths 24' 0" ? They look a bit short. The other little item to observe is the lowest plank aft in the lower strake. It is a short piece (if you've arranged everything else correctly) as it was cut to shape and fitted rather than bent. The piece curls as well as curves around to the outer end of the wing transom. Check the RMG web site and search 'planking expansion' for examples.
Qui savez, Marc? As master shipwright - it's your decision.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Before you go wild, be aware that there are no short pieces at the stem! the last of the longer ones become parallel before hooding into the stem rabbet, See: https://www.rmg.co.uk/collections/objects/rmgc-object-79816?_gl=1*9ishb2*_up*MQ..*_ga*NDcyMDk2MDY0LjE3NTcxMDI0Mzg.*_ga_7JJ3J5DBF6*czE3NTcxMDI0MzgkbzEkZzEkdDE3NTcxMDI0OTUkajMkbDAkaDA.*_ga_4MH5VEZTEK*czE3NTcxMDI0MzgkbzEkZzEkdDE3NTcxMDI0OTUkajMkbDAkaDA.
If you are trying to put a burr on a scraper, hold the scraper in a vise. Run the burnisher along at a slight angle, pressing hard, to turn the burr edge. Takes a few tries to master this, but you will get it! I've only just found this thread and you are doing a great job, Jacques. It's too bad that the plan set lacks some important detail, but you seem to be overcoming the problems well.
- 133 replies
- ancre
- Bateau de Lanveoc
Peripheral to the design aspect of this treatise, it is interesting to note that, with the extreme tumblehome, more compass timber could be utilised in the toptimbers, and that less would be needed for the upper deck hanging knees. Is there any information as to why the keel and false keel cross-section was shaped in a curved taper?
Definitely a disruptive scheme!
Ah, those school years for the children! Later, you will be surprised at how quickly the time went by.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
If the paper 'grout' (caulking!) were to be added to the penultimate planks before installing them, then the last plank can be carefully sanded to fit as I described. I would be reluctant to mess with installed planks. If I slipped while modifying them, then I'd have to remove and replace them. It would be a mess!
If I understand your problem correctly, I would use a sanding surface. Rubber cement the paper to a flat surface. You can then gently sand the plank edge, holding it at a slight angle to produce a subtle wedge-like cross section. Test fit until the plank almost seats all the way into the space it needs to occupy. Then you can glue and press it all the way home for a tight fit.
Worst Planking Job Ever
druxey replied to rhephner's topic in Building, Framing, Planking and plating a ships hull and deck
It is obvious that you are now on to the process. From here it's simply a matter of refining your skills on the next model. Well done for not giving up! -
There is the video mentioned and also tutorials on this site: http://modelshipworldforum.com/resources/Framing_and_Planking/Planking primer.pdf http://modelshipworldforum.com/resources/Framing_and_Planking/Lining Off your hull for planking.pdf http://modelshipworldforum.com/resources/Framing_and_Planking/NailPatternJig.pdf http://modelshipworldforum.com/resources/Framing_and_Planking/plankingfan.pdf
Very nice, Dafi. However, the guns I've seen that were fitted with locks had their mounting holes offset on the right edge of the pan (the rectangular raised area that the vent hole was bored through) as seen from the breech end. The gunlock was mounted there with two thumbscrews. Early gunlocks were experimented with in the late 1720's by the French and were in general use by the British by the late 1780's (Caruana).
The slipway at Bucklers Hard has been archaeologically excavated and an article on BBC News posted: https://www.bbc.com/news/articles/c0qll3j0evyo
