Glenn-UK
Everything posted by Glenn-UK
  1. Was able to get a bit more done this afternoon. A great tip in Keith Julier's book The New Model Ship Handbook was to bevel the end of the dummy barrel strip to aid fitting, without the need to soak in water for the small bend. It worked very well indeed. Bevelled end Fitting dummy barrel strips Spent a bit more time adjusting the bow spirit opening on bulkhead 1, now happy with the fitting. Glued bulkhead 1 to main assembly Can't do much more at the moment until the glue sets.
  2. When checking the fitting for the masts and bow spirit whilst in dry fit mode, I noted the access hole in bulkhead 1 for the bow spirit was quite small. Checking the plans the bow spirit is a 12.7mm dowel without any reduction, therefore I think bulkhead 1 will need some work. I have done a bit this morning. See picture below. Bulkheads 2-18 have now been glued in position along with gun deck. I have double checked everything is ok! Checking Main Mast fits OK Checking Fore Mast fits OK Checking Bow Spirit fits OK, without bulkhead 1 Bulkheads glued
  3. Hi David. Thanks for that. I had realised that but I'm really glad you've got my back as I'm sure there will be many more problems to overcome. I put them there for the drilling for added security. I have now trimmed ends which I had only used a touch of glue and checked all clear with bulkheads and planking runs.
  4. Thanks for the comments and fingers crossed all goes well this time. Another 2 1/2 hours work, Drilled 3mm support holes, noting I added some scrap 5mm ply for added support. I marked the beading line and removed excess (down to 2mm at edge) with David Plane, File and sandpaper. Took the plunge and glued stem and front keelson, now left to dry overnight. In meantime I removed all the other items from the 5mm ply sheets 1 to 6 and then decided to assembly the stand. Beading line work My David Plane 3mm fixing hole 3mm fixing hole supports Glued Stem and front keelson Stand assembly, I knew the reference books would be useful. 4 hours into the build. Should be able to spend some more time in shipwrights office tomorrow, but I do have other chores to do.
  5. Got home from work and told the Admiral I was retiring to the Shipwrights office for the weekend. In the first 90 minutes I was able to remove the bulkheads, gun deck and keel from the sheets file as necessary and dry fit. The first cut The replacement parts Checking number of bulkheads! Start of the dry fit First dry fit and reference books I think this looks OK to me!
  6. Replacement arrived - I'm one very happy bunny! I have deleted a lot of my old posts as there were simply not relevant to this build. Task 1 I'm going to check, and the double check the bulkheads prior to the numbering them 1 to 18. Task 2 I'm going to check, and the double check the bulkhead positions when dry fitted. Task 3 I'm going to check, and the double check the bulkhead 1-18 positions prior to gluing.
  7. Good news, I have had confirmation of shipping from JoTika for the replacement parts, and according to the tracking service the goods are now out for delivery, it's going to be a busy weekend, trying to fit the boat build in. In the meantime here is a couple of picture of the small launch, it is nearing completion, only the Davit, twarks, stern seats, windass and gunwale left to fit, which should only take a couple of hours. The hull ribs has been the hardest task; having to careful split 3mm walnut strips into 1.5mm strips and then fit with a 4mm spacing ensuring the twarks will sit square to hull when installed. A small 4mm jig was used. I was glad to use the super phatic glue, takes a bit longer to set the CA glue but it's much easier to remove from the finger ends. Super phatic is a composite CA and wood glue which was recommended by my local model shop. I have painted the boat as per the manual.
  8. I was reading The Anatomy of Nelson's Ships by Longridge last night. In particular I was interested in a drawing showing how a singe and dual block were rigged to help secure a cannon. The single block seemed to be held in place by a continuous rope wrapped in a figure of 8 with two beckets, one at end end of the block. Please see the attached pdf file. I would be interested to know how this type of rigging would be done for the model, boat builder as I suspect the normal thread may be to small to splice into a continuous loop. Cannon Blocks.pdf Any thoughts / ideas would be greatly appreciated.
  9. Did you apply a beading line and sand the keel from beading line to the edge before the start of the planking? This is important otherwise the walnut keel and rudder parts will not sit correctly, it's the biggest mistake I made with the Scottish Maid build as I was not aware it needed to be done. Glenn
  10. A great start to the build I will continue to watch your progress with great interest. Don't make the same mistake as me and put the pins in too deep as the are then difficult to remove before sanding and installing the 2nd layer of planking. Glenn
  11. Hi David What a great set of pictures, your are making an outstanding job of the rigging. A real pleasure to see what you have done so far Glenn
  12. Completed the first planking on the small launch, this has now been sanded and coated with a watered down glue mixture and will be left overnight to dry. I have also dry fitted the bulkheads (except 6 which is walnut) to keel and deck for the small barge ship. Fingers crossed the replacement parts arrive tomorrow, I have our goods in at work on red alert.
  13. Nice start to your build and I look forward to seeing your progress over the next few months. Glenn
  14. Hi Patrick. I agree to does stick out like a sore thumb now I look at it in isolation. I was so intent on numbering the bulkheads as per the sheet numbers it simply did not occur to me the etched sheet numbers would be different to the manual sheet numbers. JoTika were very helpful and apologetic, it seems they have only recently started to etch numbers on all the 5mm plywood sheets to aid kitting up the boxes. Glenn
  15. Hi David I may be ahead of you with the small boat build but I'm at least 2 years behind you with the main build. The Manual indicates the small boats can be built within 2 weeks with evening work. I think it will take a bit more time than that. Fingers crossed parts arrive on Monday. I can then continue to work on the small boats as a low priority background task. I have decided to purchase the Amati plank bender as I think that will be essential for the main boat build.
  16. Completed first planking on starboard side of the launch. Pleased with out come; just need to sand and coat with water down wood glue in readiness for second planking. Will first plank port side before I start the second planking. This is proving to be a more interesting side project than I first expected.
  17. Hello Mort I noticed as I was dry fitting the quarter and upper gun decks; the slots did not align with bulkheads 4 to 9. I checked my pencil markings and it seemed I had fitted the bulkheads correctly then I realised that the shapes on the 5mm plysheets which where etched with the numbers 2 and 3 by JoTika were transposed when comparing with the layouts shown in manual.
  18. Hi David Once again you have done an outstanding job. It's a real pleasure to watch your progress and learn from your work. thanks Glenn
  19. I'm still waiting for the replacement parts from JoTika so I continued on with the Launch build. Its quite fiddly work putting on the first layer of planking, without putting to much glue on the bulkheads which have to be removed once the plainnking has been completed. Managed to fit 4 planks in 2 hours, as it took some time to soak, shape, bend and glue the planks.
  20. Has anyone got any photos of the launch construction, as part of the Caldercraft HMS Victory. I'm ready to start the first planking and would interested to see what anyone else has done.
  21. I like your attention to detail and I think you will build a fantastic ship. Glenn
  22. Hi David Happy New Year to you and your family. You have done an amazing build so far. Congratulations. Many thanks also for your support and valuable advice. Glenn
  23. I have been able to move back in to the shipwright's office tonight. I thought I would make a start on the small boats whilst I wait for the replacement parts. I though this would be easy, but its presents quite a challenge. The bulkhead and deck slots took a lot of filing to ensure they fitted correctly. I did manage to split bulkhead two but it was simple enough to repair. Keel, bulkhead, deck and plank terminations fitted and glued Launch assemble now ready for first planking. Whilst waiting for the launch assembly to dry I started work on the barge. A great tip is to file the slots before removing them from the plywood sheets I found it so much easier. That all for now folks, fingers crossed I get the new parts tomorrow so I can catch up over the weekend.
  24. It's good to see the progress you're making. I hope to be up and running again in the next few days. Happy New Year.
  25. If you search this site there is plenty of information regarding planking. It is an acquired skill but I found it was not as bad as I first feared. I just ordered additional wood materials from Cornwall Model Boats as the build progressed. Enjoy your build.
