MrBlueJacket
Everything posted by MrBlueJacket
  1. All the standing rigging is almost finished (just the last shroud on the mizzen to go)
  2. Congratulations, Sarah! Your customer file now shows a 10% discount on the next kit you buy from us. Nic
  3. Is your hull shiny or dull? If dull, then a coat of flat clear will hide the shiny glue, but not the bump. Perhaps some careful sanding will help. I would worry about debonder, try it on a prepared piece of scrap first. Nic
  4. Painted the caprails, added the masts. Fore and main were in halves, so I stiffened them with brass rod. Still pretty bendy.
  5. Nice work! Your customer file now show you will get a 10% discount on the next kit you buy from us. Nic
  6. you will notice that by splitting the false deck and having each side butt against the keel, you are assured of a straight hull. Nic
  7. Next is to add the lower deadeyes, then I can put the afterdeck in place.
  8. Don't know. It would have to be thick, like clear flex-seal, but I think it would look terrible. Nic
  9. With overlapped plates, there's not much to protect the edges. Be careful handling the hull, and when the model is finished and in a case, then no-one will be able to touch or brush against it. butt joining the plates reduces, but does not eliminate the problem. Nic
  10. I suggest you contact the Tampa Bay Ship Model Society: http://tampabayshipmodelsociety.org/
