Everything posted by MrBlueJacket
Just a guess, but I've seen numerous examples of lines going to blocks on the deck, then up to a belaying point. I think it is because you can pull up with more force than you can pull down, being limited by your weight.
- 602 replies
- Flying Fish
- Model Shipways
We already have the USS Perry, similar in size and complexity. https://www.bluejacketinc.com/shop/model-ships/kits-model-ships/naval-vessels/uss-perry/
- 121 replies
- Newsboy
- Model Shipways
- 121 replies
- Newsboy
- Model Shipways
It was a B***h to get the double sheet block tucked behind the wheelhouse. Attached with fine thread into an eyebolt.
- 121 replies
- Newsboy
- Model Shipways
Prepping the boom and gaff with blocks. I used 1/8" blocks, painted with dark tan and stropped with .010" wire.
- 121 replies
- Newsboy
- Model Shipways
- 121 replies
- Newsboy
- Model Shipways
Good start, Tim. Look for a PM from me. Nic
- 72 replies
- Seguin
- BlueJacket Shipcrafters
Eric, we have listened to your comments. Since you finished the model, your customer file now shows a 10% discount on the next kit you buy from us. We have plans to build the Cairo in 3/16" = 1' scale (3x the size of this one) and it will be a longitudinal cut-away to show interior details. Nic
- 113 replies
- Cairo
A little putty and sandpaper will make that hull nice and smooth. Stay away from the hard carpenter's fillers, use softer ones like auto glazing putty, bondo, or even wall spackle. Nic
- 54 replies
- Spray
Congratulations! Under Daniels name, it now shows a 10% discount on the next kit you buy from us! Well done!
- 11 replies
- herreshoff 12 1/2
- Finished
- 121 replies
- Newsboy
- Model Shipways
Over the weekend, got the first pair of shrouds done on each side and started the second set of starboard shrouds. Then will come the forestay and more ratlines. notice the temporary forestay to keep the mast from leaning backwards as the shrouds pull in that direction.
- 121 replies
- Newsboy
- Model Shipways
Although it looks like a lot of leaning to port, when the shroud is tightened up on the starboard, it becomes perfect.
- 121 replies
- Newsboy
- Model Shipways
Now for the lower stays. To get the masts parallel, I must first pull the mast to port, so when I attach the starboard stay, it will pull back to where it should be. View from the bow.
- 121 replies
- Newsboy
- Model Shipways
- 121 replies
- Newsboy
- Model Shipways
- 121 replies
- Newsboy
- Model Shipways
You are correct. We sell parts all t he time. Nic
- 19 replies
- Putnam
(and 3 more)
- 121 replies
- Newsboy
- Model Shipways
Keith, thanks for the tip. I wet the last inch of thread in CA glue, which makes it stiff, like a needle threader. Works great.
- 121 replies
- Newsboy
- Model Shipways
- 121 replies
- Newsboy
- Model Shipways
