giampieroricci
Everything posted by giampieroricci
  1. Your work is simply perfect!!!
  2. The wax is applied on the outside of the lantern, warming it slightly to be modeled. Then I mixed the two components of the resin and I filled the lantern. The resin takes about 12 hours to dry. When the resin is hardened, it is easy to remove the wax with a bit 'of hot water
  3. for the lantern glazing I thought of a transparent resin that use rail modellers to reproduce the water: I prepared the lantern covering it with wax, to allow casting of two-component resin
  4. Some small step forward; there is nothing yet fixed, everything is provisional: I would try to do the glazing, but I do not know if I can!
  5. I removed the counter-shaped timber with a small tip mill, patiently!
  6. I remade the central part of the light, with a different technique. I didn't like the previous light. I made a wooden counter-form on which to secure the uprights of the light of two brass supports; I also used a thinner wire, 0.8 mm for the uprights and by 0.4 for the spreaders:
  7. some progress. This work is really difficult. Especially I can not get the little crosses at the bottom of the third lap; I don't like how it is coming. I'm afraid that I have to look for alternative roads ......
  8. Continue I realized that I have mounted the hat of the light on the contrary, but fortunately it's only temporary, to make pictures....
  9. These days I am trying to build a sternlight. I began by its cover I first made of wood, in order to understand the forms, and then I tried to make brass.
  10. Great job!!! Pure art!! Could you show a little more detail the implementation of the ruling wheel?
  11. Thank you for your likes, friends! I also completed the serpents of the starboard side
