I'm just so off the idea of having to have to re mask the whole thing all over again - it feels like a chore (even a head ache) almost dont have the interest tempted to just spray over it in one colour and pretend it was ment that way. Thankfully the seafire is more straight forward just Sky underneath and dark grey ontop. So glad my other builds I brouht ages ago are single colour builds no camo patterning. OC.
To be honest I was very dissapointed by the finish and without a doubt its down to my less than clinical masking as there are some quite tight turnes using the blue tack - the idea is to roll the it into long worm shapes then press it down onto the fuselage/wings, then cover the part not to be sprayed with either paper or tape, the other difficult thing is the holding the plane without touching areas to be painted - for this I try to attach a stick underneath held in place with lots of tape, then there is the control paroblem using a blast from the Rattle cans, its too fierce and if you go to close to make sure the camo lines are filles - then it can buld up causing runs. In hind sight it would have been better if I could have masked and painted the fuse and wings seperate like I did the mossie as there was more surface area to work from that way. I guess I am Always going to have these issue having to use the methods and equipment I have to use - its a viscious circle with no rememdy. I see people using fine air brushes and I am so jelous and envious and know its whats holding me back - that and not having a man cave or even shed to use use. OC. OC.
Evening all, more work on the Spit - first I stripped off all the masks and examined the camo closely, I decided to use some fine wet and dry and give the whole thing a gentle sand over - I then noticed that I was fading the camo and giving the whole surface a worn appearance with a few areas where the primer is showing - question does it look normal or should I touch up the paintwork, not forgeting I will be shading the panel lines and high lighting, after the decals are on. OC.
MRAP ATV by CDW - FINISHED - Rye Field - 1:35 Scale
Old Collingwood replied to CDW's topic in Non-ship/categorised builds
Superb - so much detail. OC. -
I have been into cameras for many years probably had more cameras than my age 😲 I have inherited a camera off my neighour but to be honest my best tool for model photography is my mobile phone camera, as it slim and can get it underneath the actual plane to get shots looking upwards (you could not do that with a lens) but no doubt any decent camera would take better general photos of the model due to quality of optics / pixals etc. OC.
Slight update on this - I de - masked the camo, it didn't come out too bad but neded a few areas of gentle re spraying - so it was a case of stage by stage re masking where I dont want over spray to go, I started by covering most of the plane in a plastic bag then ran some lasking tape to trap it - then more tape and Blue Tack to get a smooth line, then I touched up around the tail using Grey first. I will remove the bag and move over the plane doing the same as there are a few areas that need the same work, practice makes perfect they say. OC.
She is looking splendid Kevin - all that hard work is deffinatly paying off. OC.
- 337 replies
- finished
- mountfleet models
Evening all - more progress this eve, I masked off the top edge of the wings, then the front slope on the cowl and the rear lower fuselage, then I used my Tamiya flast Sky and proceeded to hand paint it with my largest brush, I put about Four layers down dried in between layers with the hairdryer, will need the edges lightly sanding to get rid of the ridge. OC.
Looking smart mate. OC. -
Hi all, a bit more work on the Seafire - like I said above the front under cowl needed some shaping as it was a bad fit, I attacked the area with a sanding stick then a bit of wet and dry followed up by a bit of putty, I also test fitted the spinner plate - I drew a line around the outside edge then after removing it I sanded the nose back to the pencil line. OC.
I would say thats Right up there with the likes of Accurate Armour with thier resin kits - extremely good start Craig. OC. -
Hi all, more progress with this as I am waiting for the paint to harden on the IX, I gave the joins a tidy up then added some putty to the join line where the wings meet the fuselage, I then fitted the nose under belly section that will need some shaping as there is a fit issue with a difference in shape where it meets the fuse. OC.
Lou is on the left and Lou is on the right easy to tell the difference because Lou is not on the left he is on the right and Lou is on left, yep thats right.🤪 OC.
