Your doing some amazing work Kevin, so much attention to detail is going into her. OC.
- 337 replies
- finished
- mountfleet models
HI all, I had a battle on today - trying to manipulate the engine/undercarriage nacelle to fit the wing (its a notorious bad fit) I had to dry fit - dry fit - dry fit etc etc etc and file/sand away till I managed to get it to fit requiring just the smallest amount of filling. Firstly I glued the front end and aided by the hairdryer and some gentle pressure it glued down, then I pushed down the back end and secured with a seam of fine glue. The idea with the hairdryer is to make the glue mimick a heat gun by where the glue sets quicker by being hot, and cools quickly as set. OC.
Good day all, more work on mossie, - I assembled the other wing starting by fitting the flaps together, at the same time I painted and placed the wing radiator in place, then after cleaning the seams up - the wing was joined together with the flaps trapped inside. I also cleaned up and painted both engine nacelles. OC.
Bell UH-1H Huey By lmagna - Dragon - 1/35 - PLASTIC
Old Collingwood replied to lmagna's topic in Non-ship/categorised builds
Not your fault bro, no need to stand in the corner - take a seat on the hammock instead, OC. -
Very similar 707/DC8 esp if they were the short body DC8 later on they lengthen'd them to near 180feet, the 707 was still a heavy-er plane though compared to the shorter DC8. OC. -
The 707 never was renowned for its power to weight ratio - quite a heavy beast for its size and engines the JT's were not all that powerful think they needed at least 5000ft hot and heavy min runway for take off. OC. -
Its not the quality that matters lou - its the content and memories. OC.
