I have to say - this is the very first proper 1/48 kit I have built and the first go at spray painting, even if it is just Rattle cans, so my routine might be a bit shaky as I am learning as I go a long with the aid of lots and lots and lots of reading up and looking at other build logs for aircraft all over the net. OC.
Just thought - I sprayed the Black first, should have sprayed the two colour camo on the top of the fuselage first, then masked slightly over that for the Black, guess when I take the tape off I will have to gently fine sand the hard edge from the tape, then slightly over-lap the tape on the black for the camo. OC.
Right then - I masked her according to the Black scheme I have gone for, then outdoors I got my Semi-Glass Black Tamiya rattle can out - did what the Pros suggested (sat the can in some hot - not boiling water in a cup) this is supposed to improve the flow from the can. Dear I show you ............. OC.
ICM 1/48 Spitfire MkIX Scrapped.
Old Collingwood replied to Old Collingwood's topic in Non-ship/categorised builds
Wasn't much off a loss - just a bit frustrating - but like I say its in the spares might be able to re build it as another mark of spit, dont know yet. OC. -
Mine will have the same wing as this one had - not the clipped or extended (like in the build James did above) and the pointed rudder as apposed to the more rounded one. OC. -
Thank you James, I will start a build log when It arrives - would be great if you follows along. OC. -
I have a replacement sorted now - its an Eduard Mk IX (Late Version) it comes with a bit of Bressin/Eduard PE and a canopy mask and decals for six models, it should arrive some time this week. OC. -
That looks superb James. OC. -
Hi all, a good day today I did the kind of work where you feel your not getting very far - but in fairness a fair bit was actually done, starting with the undercarriage units I painted therm flat alum then I put them aside to dry - then I added a couple of coats of paint to the wheels, after drying with a hairdryer I then highlighted them to bring out the tread details - after I painted the hubs flat alum. I then studied my idea for extending the front units as the Revell ones sit to low, I dry fitted the two engine cowl units and worked out how the undercarriage sits in place, its is a tight space in there and the legs needed to go in at an angle to fit, I then worked out if I used a 1-2mm strip glued it it and bored a couple of holes - it kind of did the trick. They are not fitted yet just dry fitted as there is a system where the whole wing needs assembling first - but the flaps also need assembling and fitting as they are movable surfaces, this all needs doing before the engine cowl/undercarriage units can be fitted together. I also worked on the inside section of the wing that will be in view - like the inner groves when the flaps are dropped - also the rads in the wings were painted then fitted inside the one section of the wing. OC.
Thanks Mark. OC. -
Yep I have my eyes on one - been doing proper research this time and found a kit by a company called Eduard they are renowned for doing resin and brass stuff - didn't know they did kits, anyway they do a very good Mk IX in the same 1/48 scale - might have some good news in a day or so - will report back, might be starting a new build put it that way. OC.
