I have tried to rescue the canopy, I glued the edge on the inside where the crack started and then worked on the loose section that had fell out, this was glued back in then I did some tidy up, where the crack is visible I will paint a part framework and do the same on the opposing side so they match. Pics show dry fitted still needs painting and fitting. OC.
B-25 Mitchell "Meet Miss Runyon" by Javlin-HK-1/32
Old Collingwood replied to Javlin's topic in Non-ship/categorised builds
No words really - all the best to you take care. OC. -
Hi all, just put on the two wingtip nav lights (just see through plastic) then I decided to have a go at the wing decals, I started with a couple of tiny ones under the wing - I put them down using Microset first then after about five minutes after I had wicked away any moisture - I then brushed on some Microsol and left it to dry, then I turned the wing over and placed the rad warning decal - same again Microset placed wicked away the moisture with a cotton bud, then I did the same with the Roundel, after this was placed again with Microset and wicked away - I then waited about ten minutes and brushed on some Microsol. I guess I need to leave this till tomorrow before putting anymore Microsol on if needed? OC.
What I will do tomorrow - Add the nav lights at the end of the wing then put a few of the decals on the wing - these are the large roundel and the danger panel marks for the top of the engine rad, and any other decs to go on as I now have micro sol and set. After leaving a day or so I will spray over the wing/decs with my Tamiya flat coat laquer to seal it all in. OC.
