Posts posted by fmartins
Having fun is the most important thing! Without fun it's just work and that is no good! Seeing that model in your hands really shows just how small it is and makes this even more impressive!
I couldn't agree more! Having fun is the essential thing in this and in any other hobby... Take that away and what else is there?
Wow! I must sat that this is a very interesting build. Considering you are building such a large ship at such a small scale and scratch building everything this is going to be a cool ship to see completed. You are doing a great job as well and if you can do this on your first build, if you ever get the time to build another at a bigger scale where you can really work in some details I think you are going to be just fine. Looking forward to seeing more!
There's a ton of stuff that will be left out of scale. Without proper tools and materials there's only so much one can achieve. But since I just started this for kicks and giggles I'm kinda satisfied. If I could go back there's also a ton of stuff I'd have done differently, but that's ok. I'm having so much fun building it... I'm atually curious to see how it is going to turn out in the end... Thanks for dropping by!
Well, wales glued... since the gunports are not in scale, I had to start cutting a bit. According to the plans, a few gunports cut into the wales but not so many as in my model... now I'm gonna have to live with it... living and learning...
On my next model I'll be more careful about proportions. These bigger gunports make the boat look smaller overall instead of a larger ship as she was...
With the hull faired, I decided (wrongly I suppose) to glue the wales... I got a bunch of pink cedar strips lying around...
But I was afraid of not being able to curve them properly. I saw a couple bending jigs and tried the best with a plank of styrofoam, a side picture of the Royal Louis (covered in tape so it wouldn't glue to the paper) and a few ball-point pins. No need for water or steam as they are really thin.
A redimensioned side view of the ship to see if it would fit...
So far it looks good...
- mtaylor, Keith_W, seafarermiami and 5 others
- 8
It has been a bit slow going in the shipyard as of late. Too many major soccer (futbol) tournaments that need to be watched! I have been modelling my framework to give me a better understanding of how things will go together with this build. Below are some snapshots. Being my first scratch build there is a lot to learn and research... but everybody here at MSW already knows that. I hope to put an order in for the deck and hull planking wood in the next week. In the mean time I have some bulkheads to finish up. I need to set up my build board and then the assembly process can begin. Enough planning and layout work! It is time to make sawdust!
How difficult is it to learn how to make frames on the CAD software and then print it to size desired? I mean, this could open so many possibilities to me... do you think it'd be possible to do the same with some free software? Congrats again on your build...
As for the gratings, I tried to make them in wood, but even the smallest I could do was so off in terms of scale that even I who don't really care for scale in this size wasn't pleased.
So, improvising as usual, i just printed the gratings....
Some more details added
the same for the second deck (still need to paint the stairs red like the parisian model).
I also started building some more detail at the transom.
More balsa and a few strips of scrap wood to make the arcade stuff (don't know the name )...
The balsa pieces also help to form the gunports.
I totally forgot to take pictures, but I glued the gun carriages in to the their positions in the gunports (two of them may be seen from outside - more pics later...) under this second deck ( stupid me!).
This is was a prototype for the gun carriages (the cannons themselves were not included as I thought I would break them easily - they'll be glued in the final stages of the model - if it survives...)
First try - thick card. Not good.
Second attempt - wood veneer (no idea what wood this is... I just bought a pile of scraps... )
Toothpick for the cannon...
A second set...
Both together...
Ruler for size... (out of scale but still cool!)
And my thumb for reference too...
It'd be much easier to turn the cannons if I had a lathe or a rotary tool (I'll try to purchase one, 'cause doing all these by hand will be too time consuming and time is one of my restrictions lately).
- SailorGreg, -Dallen, Omega1234 and 7 others
- 10
First build? Really? The hull is looking pretty good and you're choice of materials is interesting. I'm gong to follow along to see what's next.
Yes... It's my first build... It's all pretty messed up but I'm loving it... I'm even considering doing something bigger if it turns out "acceptable" in the end... The problem with this scale and all improvisation is that I'm spending a lot of time thinking about the next steps or ways to correct the mistakes I made in the planning...
After a few attempts, I think that the deck planking was not so horrible...
The hole you guys see in the middle section was the fruit of my illusion to add some real miniature grating ... All the gunports were also painted red. Due to the small size, I think I'll have to use CA glue to secure the bow planks in place, so instead of wood, I carved/sanded a plastic piece (to make it easier, I think...).
The same was done with the other decks...
With a bit of improvised weathering (yeah everything's improvised!!! )
To fix the 'flexibility' problem, I also added some wood (balsa - I know it's not the best, but it was easy to find, easy to glue, and really easy to sand) between the bulkheads.
This made all the fairing thing much easier... (improvised sand block in the lastpicture... )
The problem with the wood-covered styrene deck is that it's really flat. I could sand it to give it a more natural curve, but instead I thought of something else...
I had some thick card paper lying around so I improvised some deck planking on top of it... Also, it's not the standard deck planking pattern (I only found a tutorial on deck planking a long way after I had done it).
It's a bit out of scale but whatever, it's already pretty small for me ...
To deal with the fleixibility and to keep bulkheads at a 90 degree angle with the false keel, I glued a lot of rubber blocks between them... I also added the space for the cannon ports...
The decks, however, were not glued. It was just a dry run to see if they would fit. I also started fairing the bulkheads, but with extreme care because, again, it was a bit fleixble ...
Before anything, English is not my mother language so please be kind to my mistakes (there will be too many I'm afraid) and lack of nautical jargon.
Well, this is my first build. You may think it's a pretty bold move for a beginner to model such an intricate ship as the Royal Louis but I fell in love at first sight with the model at the Musée National de la Marine in Paris a couple years ago. At the time, I had no interest whatsoever in ship modeling, which is a pity, and missed the opportunity of taking hundreds of pictures at the museum. Either way, that's the one...
The model at the museum is huge - I think it's larger than 2.5 meters (8.2 feet?). I wanted to build a model ship like everyone in the forum but I live in a small appartment in Sao Paulo Brazil so I had to settle for something smaller. I also didn't want to buy a kit (another risky choice for a rookie) so I got both model ship makers and historical plans to plan my build. In the end, I planned my little Royal Louis to have a 25 cm hull (9.8 inches?) and sit comfortably on a very small shelf when done. Another reason for the small size is that I don't have much time so, a larger model would take too much time preparing the wood, etc etc.
I'm no Lloyd Mccafery so my model will be full of flaws and probably horrible in the end, but I guess it's a nice experience and you can only learn stuff by doing it. I really hope I can learn something from it. Lots of stuff will be out of scale or I'll end up using inadequate materials/techniques, but in the end I'll have fun.
I used POB as a start as you can see in the next pic...
The bulkheads are really thin, so wood was not an option (at least for my poor skills). I tried with a couples different types of wood but all of them felt too brittle to my taste, so the internal false keel / bulkheads were all made of styrene. They do have some flexibility but at least I didn't break all of the bulkheads. So far, so good.
- seafarermiami, mtaylor, Keith_W and 6 others
- 9
Thanks a lot buddy. I'll do it in the next few days! But I still have a question - I'm doing a Royal Louis but it's very small so the bulkheads are in plastic but almost everything else in wood (and a few other parts in carboard, etc.). Should I put it like "PLASTIC/WOOD/CARDBOARD/OTHERS", in the title?
Well, I am more of a reader rather than contributor in here and as such I never even wrote a post (this one is my first, if I'm not mistaken). I'd like to start a build log as I've been toying with a project for a while and I kinda need advice... Are there any pre-requisites for starting a log or should I just give it a try?
- mtaylor and Ryland Craze
- 2
Licorne 1755 by mtaylor - 3/16" scale - French Frigate - from Hahn plans - Version 2.0 - TERMINATED
Hi Mark!
I'm late to your log, but I'm happy I took the time to read the whole build log from the start. This has been a masterclass for me, since I had no idea of the complexity of a plank on frame model. I wish I could do something like this... I really enjoy your detail-oriented spirit. She's just beautiful, no other words suffice. Congrats!!! I'll keep following in the back of the room, just taking notes to myself...
