alross2
Posts posted by alross2
  1. More as-yet completed drawings.  The image with the spacing of the lower deadeyes shown is probably the most useful one.  On the rigging drawings, they will take the appropriate angles to match the stays and shrouds.
  2. This week and next (at a minimum) will be spent drawing.  I've been creating the plans by importing the laser drawings as a base which speeds up the process and also gives me another fit check.  These two will probably be rearranged several times before they're done.  These are the 24" x 36" sheets.
  3. That’s it. After laying on the 1st layer, it’ll be a coat of Durham’s Rock Hard wood filler and sand sand sand. It’s early days, but it’s got the shape of a ship now.
    You might consider a different filler as Durham's is usually much harder than the woods (such as bass) commonly supplied in kits.  I've used auto body filler (bondo) for decades.  It's the same relative hardness as basswood, so it sands and feathers well without scouring out the wood on either side of the patch.  In addition, as it is a polyester resin, it is an adhesive and locks the planks in place.  One water-based filler I've had success with is Famowood which I purchase online.  It is similar in hardness to basswood and sands well.
  4. I love our laser.  This is one side of the forward house.  The top piece is .015" laserboard and has the mullions for the windows.  It will be laminated to the inside of the bottom piece which is 1/32" basswood.  The square and rectangle on the bottom piece are the window frames which are .015" laserboard.  When the house is completely built and painted, .010" clear styrene with its back side painted black will be glued to the inside of the inner lamination.  Both houses will be built this way.
  5. Starting to look like a boat...but still lots to do .  Hull is painted and needs a couple spots retouched.  Nothing is glued down to the decks although pieces are in their approximate locations.  Right now, I'm putting the window frames on the deck houses.Downdeck.thumb.jpg.216f9b4664b4e499283c2c504ca3ec3a.jpgForehousestbd.thumb.jpg.25025c4d85ecf63a106e8fd1c3f1ba1f.jpgPortpbique.thumb.jpg.0f272c513c59a925dc2c743b09df3467.jpg
