Everything posted by Stuntflyer
I've finished up the starboard hull planking and I must say that I'm quite happy with it. So far it's been sanded with some 180 grit sticky back sandpaper attached to soft sanders. You can find them here, just search for "soft sanders" https://www.woodcraft.com/ I prefer the coarser grit as it allows me to even out the undulations in the wood more easily than if I went with a finer grit. I'll finish up with some 320-400 in order to remove any scratches that can be seen. I still need to add the hance piece at the quarterdeck. Once that is in I will final shape the shear of that last filler plank. Mike
Looking really nice, Chuck. Your progress is amazing and the ship looks aesthetically pleasing, at least to my eye. As I recall, when I did the scuppers on Cheerful, I started with a small diameter drill that was large enough to get the point of a round needle file inside. Then I just rolled it to increase the hole size. Once the hole size was close a final drilling to even out the taper worked nicely. Like I said, as I recall. To be honest I'm not 100% sure.
Hull Planking, cont. . It seems like forever since my last post. I had some personal matters to attend to amongst a few other things. Anyway, I'm looking forward to getting things back up to speed. I'm working on a tricky part of the hull planking, those cutouts around the gun ports and sweep port lids. I really had to take my time here in order to avoid re-dos. The reveal around the gun ports is somewhere between 1/64"-1/32". A pillar file comes in really handy. It only cuts on one edge thus allowing for clean corner cuts. https://contenti.com/grobet-extra-narrow-pillar-files I use either a "0" and "2" cut. I haven't done any sanding on the planking and as you can see it's a bit of a mess. The red color is Winsor & Newton "Crimson". In the past I would add a bit of Burnt Umber in order to darken the color. The two colors would often separate which I found to be a pain, so I decided to keep it simple this time around. Mike
Maybe! I have to see what the run of the frame joints look like. If the run is irregular that would not look so good. I would think that the laser kit builders would be in good shape regarding this. At some point I will get to checking out the run on my build. Right now I'm still working on the planks which go around the sweep ports. Mike
Chuck and I like to use a number 2B pencil on one edge of the joined surfaces. It leaves a strong glue joint and a clean line once sanded out.
- 90 replies
I like to use paper templates held down with acid free rubber cement or even Elmer's School glue. I have always found that it's better to leave a little wiggle room when cutting the outline. In certain cases, rather than shaping each section individually, I just cut the joints accurately and then join the various sections together. After doing that it's easier to get a more accurate outline of the joined parts while the templates are still attached. I'm not suggesting that you would do that with the stem and keel pieces. Just something that you might consider doing in the future. Here is an example of this from my Speedwell build. Mike
- 90 replies
Mast steps Over the weekend I completed the two mast steps. The location of these is very important and the plans really helped me out here. Mizzen step: The first thing I did was to tack glue the three sections together with a spot or two of school glue. Then I milled the notch which goes over the keelson. After breaking the pieces apart, I milled the notch into the top of the middle piece and glued the aft and middle sections together permanently. Next, I angled the bottom edge about 5° to account for the upward sweep of the keelson. I worked the two sections until everything was sitting flush with the limber strakes and keelson. The fore section was then positioned over the keelson, against the first two pieces, and shaped accordingly. You might be asking, why didn't I just glue all three pieces together from the start? It wasn't long before I realized that the shape of the fore and aft pieces were not Identical. The aft piece had a slightly different angle at the foot than the fore piece. This is due to the twist in the limber strake, I think. Doing this in stages allowed me to get each piece angled correctly without the hassle of trying to work the whole piece at once. According to the plan, the center of the mizzen step sits .151" (approx 5/32") in front of the aft edge of frame 11F. I glued the step into position using a cross piece and shim to account for that distance. This also helped to get the step perpendicular to the keel. Main step: This was made basically the same way as the mizzen step. It sits over frame Ba. Unlike the mizzen step, I didn't need to taper the foot. The distance between the centers of the two steps is approx 9-5/32". For the pins I turned down a 1/16" dowel using the Dremel tool. They are press fitted without the need for glue. I've had so much fun making these that I almost forgot that I need to finish up the outer hull planking.😏 Mike
Limber strakes I guess these strakes are for the most part hidden. Still, having never made them before I decided to give these a try. I used the plan drawings as usual for the templates. Rather than shape them exactly to the template, I left some wiggle room in case adjustments where needed. The rabbet on the inside edge was cut with a simple scraper made from a hacksaw blade. After adding the center section, I proceeded to add the fore and aft sections while trying to maintain as smooth a run along the outer edge of the strakes as possible. Both the aft and fore sections have a twist which needs to be taken into account one way or another. I was able to twist the aft section with wet heat and hold it in position while the slow drying CA set. I couldn't get enough twist in the fore section. If these were made from AYC rather than boxwood, it wouldn't have been a problem. Rather than torture myself, I went with some very expensive and exotic tools in order to give me a helping hand. Mike
Drawing center lines
Stuntflyer replied to Stuntflyer's topic in Modeling tools and Workshop Equipment
Thanks everyone, Issue solved! I can make a miniature version of the Pioneer marking gauge. -
Fixed blocks This weekend seemed to be a good time to get started on the fixed blocks. Six are on the ship with the two really small ones near the transom completed, but off the ship. I'm not sure if I will add them before or after planking that area. I decided to scratch them, using the mill to make the slot between the two holes. When I originally drew in the upper wale location with the hull template, I also marked the location of the blocks. I could have gone with that and it would have been fine. However, since I started the build I've tried to measure off the plan sheet whenever possible. So, here again, that's what I did. I only needed to measure and drill the position of one of the two hole locations for each block. Then it was just a matter of establishing the distance for the second hole while aligning the top of the block parallel to the shear. Here is how I made the tiny rounded shape representing the sheave. It's only .020" deep. Mike
