Everything posted by Maury S
Back in the shipyard for a while. Working on lettering and scroll work for the trail boards. The name boards and trail boards are cut from .015" laser board. They are painted gold so the color shows through the decal. The surrounding areas will be painted flat black. The two names on the right are still on the decal backing and have not yet been attached. Maury
It's time to take her off the building board. The support system is a pair of cradles similar to the cradles for my Centerboard Schooner Post 302 March 21, 2021. I start by tracing the #4 and #17 frames from the plan sheet and transferring that pattern to card stock for rough fitting. The lower part of the frame is close to the shape of the hull at the points where the embedded nuts are located. After that, I copy the shape to some 1/32" box for final shaping. Since the ECB is built on a sloped jig, I measured the distance from the top of the jig and the building board at the two mounting points and transferred that measurement from the keel slot to the bottom of the rough cradle. The scroll work will be done later. Maury
Scotty, ...and of course you're going to serve the ring, right? Maury
I too am waiting for my recollection to improve. Maury😊
- 3,618 replies
- young america
- clipper
Using a serving Machine. ( Syren Serv o matic)
Maury S replied to DaveBaxt's topic in Masting, rigging and sails
see post#244 for use of Serv-o-Matic: https://modelshipworld.com/topic/28039-emma-c-berry-by-maury-s-148-scale-pof-rigged-as-schooner/page/9/#comment-974182 -
Serving the shrouds: I have been using Syren's Serv-o-Matic for years now. The only modification I've done is to put a key into every place where the brass tube goes into the gear to prevent slipping. Easy to use, and I can only do about an hour at a time due to eye focus strain. I run the serving thread through the rope (with a needle) near the left side, tie a couple of overhand knots, then serve to the right. The rope is held in the tube with alligator clips (with heat-shrink tubes over the teeth). I make sure the serving is going the opposite lay of the rope threads and maintain a mild tension on the serving thread. Maury
Allan, I don't know. I have a Nickel blackener that I'll try, then it's paint. Maury
My partner gave me a kit of small nuts and bolts (washers, etc.) for watch and glasses repair. It comes with 6 drivers that is all he wanted. I haven't tried to blacken anything yet, but for about $20, there must be hundreds of these things that might be useful. Label reads "King'sdun" Maury
More work on the mast iron work. The background is a page from Chapelle's American Schooners...where most of the details are documented The rods sticking out will be the supports for the bail and will be trimmed back, but holding things in place for soldering has to be thought out as well. Keeping in mind all of the parts that have to go on in order is important like the mast hoops on the top mast before the wyes are installed. Maury
A sled does not have to be fancy, just stable (thickness). Like Greg, I used 1/4" Plexiglas. This one has been used for years and is beat-up but still fits the bill. If the piece I'm working on is too short, I might use double stick tape to hold it. I've been advised, to rotate side to side and end to end when thickness-sanding. Maury
- 1,129 replies
Kevin, create a simple "sled" for the sander. I use a piece of1/4" "Plexiglas" about 12" x 6". I think you will find it much better than just feeding a piece of wood through. Same technique...push stick and thumb pressure on the output. The sled also gives you a longer table. Maury
- 1,129 replies
Wire rigging for 1885 Puritan by Mamoli
Maury S replied to bridgman's topic in Masting, rigging and sails
Even wire shrouds would have been served. Maury -
Kevin, A small supplement to your very good treenail video...I mount the draw plate in a bench vise and pull the bamboo through with a set of parallel pliers (they do not crush the ends like regular pliers do). Maury
- 1,129 replies
Thanks to everyone. Still not settled but more information helps. I have all those photos of her taken in the 1930s but wondered if the late 1800s were different. Dutch example is informative. Maury
