barkeater
About barkeater
  • Birthday 02/18/1953
Contact Methods
  • MSN
    barkeater@msn.com
  • Gender
  • Location
    Howell, NJ
  • Interests
    I enjoy fly fishing and fly tying, bow hunting and reading historical fiction and historical non-fiction usually concerning the 1700's
3,512 profile views
  1. I don't know if this has been mentioned before. It is on YouTube by Epic History. There are 5 videos and are worth your time. Rich
  2. I agree with Johnny. There are multiple ways to finish, and it depends on the look you desire. For example, I use Testors Dulcote for my finish which gives a dull finish since I do 1700's ships, and I want them to look dull and weathered. If you were doing say a Chris Craft speed boat, you would want a shiny surface. As to milling, if you rip your own planks from purchased wood, I recommend you get a thickness planer/sander. I've purchased wood in the past and after having ripped planks, discovered that the boards varied a couple mm in thickness at different places. This made planking more of a challenge since the resultant planks varied in width. I do hand sand with fine grit once the planks are installed. I also use shape scrapers for detail. Finally, I use walnut for the hull which other people don't like. It varies considerably in color and shade unlike some other choices. This gives a patchwork appearance to the hull which brings out the planking detail including the use of trenails. I should mention that I only paint decorative components such as the figurehead and any carvings. Another "to each his own". Rich
  3. To strop your block, take your line and lay it around the block. Pull tight and place the block in a spring clamp to hold tight and maintain tension. Place the two line ends in another clamp to maintain tension One end of the line cut to about 1/2 to 3/4 the desired length to your bolt. The other end keep long for the moment. Using thread tie a series of square knots, 3 or 4, to fasten/splice the two ends tightly together to fix the block in place. Hit with pva diluted 1 to 1 with water. Let dry. Then take your long end through the bolt and turn back towards block. Fasten with 3 to 4 square knots. Hit with the pva water mix and let dry. Trim as desired Your done. Rich
  4. Janne, What scale is your project, and do you mean taper when you say splicing. Rich
  5. Have fun. Rich
  6. The second planking is coming along. For scale 1/48, maximal length of planks is 5 inches. This would be 20 feet. My trenails ae .6 mm or #72 drill bit which would give me to scale just over an inch. Rich
  7. Wax before using and use white glue to secure knots or stiffen after. Depending on your thread you may or may not need to wax, Cheaper thread tends to be fuzzy in my experience while well-made thread does not. Rich
  8. The model is now ready for the second planking. Any rough or low spots have been filled and everything sanded smooth. I have penciled lines where the bulkheads are. These will be where the butts of planks are placed. I use trenails throughout. I also measure along each line to figure out my overall taper. I'll do 5 to 10 planks and then remeasure and adjust rather than breaking the hull surface into smaller divisions. This allows me to deal with any problem in tapering before it is apparent and so do a milder taper over a longer stretch. Rich
  9. You can fix it in either of two ways. First option, take an EXTRA piece of wood strip for planking and either run it up the bulkhead and glue with pva or cut several small pieces and place these across the bulkhead so your planking will have contact wood continuously to glue to. You probably will have to sand down or file it down at least the end to taper depending on your situation. If you run it up long ways, then you probably are going to have to clamp or heat bend in your case. Be careful you don't snap off the bulkhead as they can be somewhat fragile. If you ever do break a bulkhead, you can just sister brace them with a piece of wood. Finally, it looks like you are going to have to add some wood to the bulkhead below the deck as well from your picture. Second option, you could shave the extra wood from your false deck, so it doesn't stick out. Just lay a plank across the bulkheads from for to aft and slowly and carefully trim away the excess wood so that the plank you are using as a reference can slide up and down over the deck. Rich
  10. I realized that I had not put up a good picture of the stern plans. On the pictures of the model, I have to curve in the upper bulwarks which I forgot to mention. Also, the reason I did not steam bend is that the stern has two windows which along their bottom just have a sill. I felt that my chance of getting a smooth curve throughout the plywood would be significantly decreased with the window cutouts. Rich
  11. Here are a couple pictures of the stern. The stern in this ship is unusual as I'm sure you noticed. Before I start, please excuse the appearance. I have a lot more work to do sanding and smoothing. I had two options in forming the stere. Either I steam bent a piece of plywood which I've done before or file the plywood down to give the proper angle, so I cut curve the stern forward. I decided to go with the latter. This meant that instead of running the first plank to the outer edge of the plywood I needed to tuck it in behind which is what I did. I've indicated on the side view how I will run the trim forward to give the appearance of a curved stern. The trim will be applied over the first planking, so I have a little leeway in fitting it flush and then I'll bring the second hull planking up to it covering any small gap. For the stern itself I'm thinking vertical planks in purple heart and yellow heart which should give a nice decorative appearance. For the upper stern counter, I have not figured out my plank pattern or color scheme yet. Rich
  12. The gun ports have now been framed and the first planking completed. I have penciled in the gun ports on the aft portion of the ship. These will be depicted as closed on the finished model, so I did not need to frame them. I have left holes (1 each side) where the cabin windows will go. The window frames will be applied after the second planking. Also, the gun ports are slightly larger than will be present on the finished model as these will be lined in this case with red heart. Next up, a lot of sanding and a bit of filler. Rich
  13. There was some variation in length for a given ball weight. Larger canons were longer and would be placed on lower decks for stability. I have never heard of shorter gun barrels for small vessels in the same shot weight. Rather the shot weight determined the length with some manufacturing variation. Smaller vessels naturally had smaller weight canons and larger vessels would have multiple canon sizes with larger on the lower decks Rich ty.
