Hello to everybody :) .
My nickname is Jack.Aubrey and I was in the past a strong follower of ModelShipWorld, both with my own logs and as a normal, simple but very interested reader . .
I knew some days ago what happened to the old Modelshipworld forum . . it was a big loss, a dramatic loss. I hope for the future this will never happen . . anyway I have decided to participate actively to this new adventure.
I'm working on a model of the french "Le Soleil Royal", from De Agostini.
I started this new project on Sunday April 18, 2010 and I have maintained a personal WIP on http://www.deagostinipassion.com/forum/posts/list/24639.page since that date.
Unfortunately it is in italian language so it may be probably difficult if not impossible for somebody to follow it, so i decided to translate part of it here, starting from the beginning.
In order to have the possibility to post the past and the present, I have decided, if accepted by the forum staff, to split the log in two segments, the first is this one, where I will post my work from the beginning until now and a second one where I will put the messages of the work I will start tomorrow until the end.
In this way I think to show easily my work, without to wait to complete the past before starting with the present and future.
See (or better read) you soon, Jack.
Edited by jack.aubrey
I introduced myself in http://modelshipworld.com/index.php?/topic/1044-le-soleil-royal-by-jackaubrey-de-agostini-scale-170-build-log-from-18042010-to-08032013/
This is the second segment of the Build log about this model, covering the activities that I will start since tomorrow until the end of this project.
Hello to everybody  :) ; before starting another important explanation . .
On December 1st, 2012 I left my home near Milan to come in a small town near Pisa (Tuscany) named Calci. I am still living in Calci and I plan to come back to Cinisello Balsamo, where I usually live, at the end of April 2013.
My workshop is located in Cinisello Balsamo, so, I stopped at the end of November 2012 any activity about shipmodeling and I will resume them in May 2013.
I think the best way to start this building log is to show the situation as it was in November, just to give you an idea of how my Soleil Royal appears now, by inserting in the next messages some of my last messages I wrote in November, just a couple of weeks before I closed the "shipyard".
I will insert in every message the real date the message belongs, this in order to maintain a chronological sequence.
In the meantime, until when I will resume the work, I will maintain the other building log; log that will contain all the work done in the past. This log is located at http://modelshipworld.com/index.php?/topic/1044-le-soleil-royal-by-jackaubrey-de-agostini-scale-170-build-log-from-18042010-to-08032013/
See you soon, Jack.Aubrey
Hi,
I'm afraid I don't speak Italian but the pictures in your other log (via the link) certainly tell the story of an interesting and well built vessel. I'll look forward to the translated version on here.
Cheers Phil,
HMS Victory 1:84
YNWA
Cheers Phil,
Monday, November 12, 2012 - Something last before closing the shipyard . .
Just some days ago (remember the date above), while I was preparing to move myself and my family to Tuscany, I found some free time and I did some new work on my Soleil Royal, with the main objective to achieve new experiences useful for the future, when I will have to do the same on other remaining pieces of the hull.
So I decided to build a segment of the gunwale, more precisely the gunwale just above the third gun deck. This detail is made with metal die cast pillars that I have previously coloured with a red polyurethane enamel. Here below an image of these pillars.
I prepared a specific working plan to achieve this step and I got the conclusion to:
  1. Use the epoxy glue (two-components) to glue the metal pillars to the deck and to the hull.
  2. Adapt a plank (size 2 x 7mm) to the camber of the hull by adopting a trick consisting of using 2 stripes of 2 x 3,5mm glued together over a template reproducing the deck shape. The result should became a final plank of 2 x 7mm having the same curvature of the hull.
Because of the time needed by the epoxy glue to dry, I spent the first day to glue the pillars to the deck and the next day to install the gunwale prepared at the second point listed above. The pillars are glued to the gunwale with the epoxy while the gunwale is glued to the deck with the vinyl.
I didn't found particular problems to solve: the only problem was that the pillars were non all with the same height and, after the first day and before installing the gunwale, I had to level all of them with a mini drill and a lot of care . . .
The third day was dedicated to refine the previously done work and to complete some components of the three boats (rudder, ringbolts, rope rolls, etc.). These small components will be installed soon on these boats to finally have them "really finished".
Here below five images of the work done . .
they also show my Soleil Royal as it is today . . I spent more or less three years to land here . . .
High Definition Images:
Additional five images of the model . .
Any question ?
The model stays on the woodden part of the final display case I have designed and prepared for it. The transparent cover will be in plexiglass but I have to wait for it until I will know the right height of the whole.
The model will be finished as an "Admiralty Board Model" style.
High Resolution Images:
Tuesday November 13, 2012 - Ship Boats
Here are all the ship boats completed . .
The boat in the middle of the images will be installed on board, above a cradle, ready but non yet installed.
The remaining two boats (white coloured) will be installed on the display case basement in the proper location.
Just a very short comment: be patient because there is a lot of material to translate, altough I think to have enough time till now to add messages.
Today I started to add something about the current status in the other log, but soon I will start with this one. Cheers, Jack.
Tuesday December 18, 2012 - Some images from my new location
It is more o less 20 days I moved from the foggy Milan to the sunny Tuscany. There is a big difference: instead of living in a relatively big town (+/- 90.000 people) now I live in a place that counts 5.000 people, near Pisa. If needed, within ten minutes I can reach Pisa and visit and enjoy the monuments and the near sea.
Here below I post some images just to pause this discussion until I will resume the shipmodeling activities in May.
A last comment before I leave the images speaking instead of me: this winter is, for me, the best of my relatively long (!!!!) life. Here the weather is warmer and the food is very good, people are pleasant and kind and a lot of other interesting things.
Kind regards, Jack.
01 - The cottage where I live:
02 - The cottage is located in a wood of olive trees, there are 7.000 of them:
03 - This is the country where I live, Calci, the tower is 9 centuries old:
04 - This is the Arno river, in Pisa:
05 - And this is the famous Tower of Pisa:
De Agostini Soleil Royal
This ship is a model kit that is supplied, on the Italian market, by De Agostini starting from the beginning of 2010 and lasting after 140 weeks . . .
Each issue contains some pieces to build the model, while the booklet contains two different sections: the most important section contains the building instructions, that drive the modeler, step by step, during the building of its own model. A sample is shown here below.
The front side of the instruction sheet (issue n° 94):
The rear side of the same:
The second section contains a very interesting Manual (or Treatise) of Naval Architecture. In total two sheets with a written explanation or introduction and many pictures. At the end of the collection, the resultant book is very, very interesting and covers all the architectural aspect of shipbuilding in the age of sail.
The cover of each issue is like the following:
Sunday, April 18, 2010
The shipyard is officially open !!
Before starting any activity on this model I preferred to wait to have in my hands at least 8-10 issues. This in order to have more informations and materials to better decide how to proceed. In effect at this date I have the issues fron 1 to 9 and this Sunday I decided to start. I prepared in advance my individual plan, with the intention to follow in a customized way the instructions.
The main reason for this choice belongs to the fact that these instructions are prepared in a way to made the beginner shipmodeler to start, since the first issue, to "mount something". But this approach is not what I like, first of all because I am not a beginner and secondly, because there are some minor dangers or problems that can raise if you indiscrimitately follow this intricated approach.
For example I do not understand why I have to mount an anchor today, another within two months, the third after an year and so on. I prefer to build and finish them all togheter, I think it is a more efficient and reasonnable way of working. This is just an example of how the weekly issues approach makes you work . .
Finally, before definitely mounting any component I have "dry mounted" them, to see and test all the joints and to make proper adjustments.
First I would like to list two points about this model that it is worth to highlight:
  • The size of the ship hull, I'm building another model (Dolphyn from Corel) and if I look them together, the difference is very great. The Soleil Royal is fatty, potbellied, rounded. And this makes this ship pleasing to me . .
  • The precision of the pre-cutted material supplied by the kit manufacturer. Some pieces of the pre-cutted material were twisted and I had to spend some time to correct them but after they are very precise. Every joint is right and I didn't adjust anything. I made a lot of controls but everything was perfect. So I decided to definitely glue them. I imagine these pieces were cutted starting from CAD plans.
Now let's start to describe the process . . first, as I wrote, I didn't follow the instructions. This is an approach that I don't suggest to everybody, but only to shipmodelers with a minimum of experience. Personally I follow my instinct . .
  1. The keel is made of up to three segments. At the moment I have only two and I have mounted them together. Great care was made to obtain a perfect alignment. Anyway a simple task.
  2. There is a false deck made up of several pieces . . I have mounted the first two of them perfectly aligned. They will keep in place the bulkheads from number 2 to 7.
  3. Then I have installed all the bulkheads from number seven to three with the vinyl. After each bulkhead I put in place the false deck to keep right positioned the new bulkhead for some 10-15 minutes. Then I repeated the same process for another bulkhead until number 3.
  4. Then I have definitely fixed the false deck and . .
  5. As last task I have installed the bulkhead no. 2 without glueing it to the false deck. This because there was a small problem with the keel (a little twistly, +/- 1 mm) and I think to solve it when I will install the bulkhead number 1.
In this way I have achieved the goal to mount a structure that is perfectly aligned between the bulkhead 7 and 3, alignment that will become my "point of reference" to mount all the other elements. Last: The lower part of the keel has two protrusions that allow the keel to be inserted into an home made "keel clamp" made with two aluminum bars and two iron bolts.
Here follow four images of the work done today (remenber to consider the date on top of this message, not the date the message is published)
y4mMH0h9EifLjHICy0F3fdlQbepbIQecp4vJuSE0
y4mLodxNHdM9qa1WYOR4YJFQGSclqxZJRn17EYcp
y4mZZfSbiVi-Q_QiWC7ck2iCkJXBdGL7i60Q_iB-
y4mQUSlzPiGdrl17oyFjJBUeBt6sw7tbrcAKL29V
See you soon next message. Jack.Aubrey
funny - it doesn't look to be leaning.  In all reality I am completely jealous of your new home. It is so beautiful and looks peaceful. I live 2 blocks from a fire-station...peaceful does not exist.  I do look forward to seeing your upcoming progress on LSR.
-Sarah
Krabbenkutter CUX-87
Harriet Lane
Fishcutter GO-38
In the Wings:
Corel Victory Cross section
Completed Build:
USS Missouri minimissouri.jpgHMS Bounty's Jolly Boat thumbnail.jpg Peterboro Canoe tiny.jpg
Many thanks for your comments and appreciations . . Really speaking Calci and Pisa are nice locations, although I will have to leave within two months. Anyway my younger daughter lives here and I can return here when I like, but not for long periods of time. Kind regards. Follow my log, if you like, about this model for the past here: http://modelshipworld.com/index.php?/topic/1044-le-soleil-royal-by-jackaubrey-de-agostini-scale-170-build-log-from-18042010-to-08032013/
Friday, April 23, 2010
Regarding to some reinforcements to the ship structure: I previously had an interesting experience with the model of the Santìsima Trinidad, by De Agostini. That model had a keel-bulkhead-deck structure similar to the Soleil Royal and I learnt that the false deck, shown in my previous images and having the main function to make stronger the whole, was also a perfect point for seizing in my hands the model during the recurring manipulations I made during the planking tasks.
The experience was that, after many and many manipulations and with the growth of the structure weight, the false deck was beginning to unstick and crash . .
So I had the idea to strenghten this element by applying, as visible in the next two images, a wooden reinforcement. To do so I used a lath of 20 x 5mm, cut to pieces with my Proxxon circular saw, of the proper lenght and glued in the position shown in the pictures.
Result: I believe I will be able to manipulate the whole without any danger of crashing or unsticking and, once it will become unuseful, it will be totally invisible . . and it has also been used to glue definitely to the false deck the bulkhead number 2, that if you remember, wasn't not yet fixed because it wasn't perfectly aligned. With this trick I aligned it to the rest of the structure with complete satisfaction.
y4mWdCxL8zyCNSKgI-eX3_KYUx5wm1TjrdnGcdDl
y4mpPqtfaO4wxIT9dyo32myXUbCTW189flKXKqEU
Then I moved forward and I prepared and installed the needed beams (5 x 5mm) to support the first visible deck. This deck should match exactly with the naval term of upper gun deck, in a three decker. After a preliminary test the alignment was regular and i fixed all of them with glue.
. .  When the glue was dry I have then installed the elements of the upper gun deck (for the moment there are only three pieces available) and I have also mounted the number 1 bulkhead, having once again a lot of care to obtain the proper alignment.
y4m7I-BwMMEHTADRKIqTUDCFnzZCM1EHFKUg2TGi
y4mF_ZGlkdu0Zl2RQlZR2Z51_p4LRf_vZeL9RynQ
As last step, I have installed the small, rounded deck in front of the number 1 bulkhead (i don't know the nautical term) very well visible in the above image. In the next message I will show additional details.
For now that's all. Cheers, Jack.Aubrey.
y4mbrhxkBhSK5IgY3ZCa6qp5KmWJfW24X5KM8LDa
Jack.Aubrey,
I merged both of your build logs for this ship into this one.  Just add to it instead of opening a new topic, please.
I discussed with the site staff about the problems that arise to me by merging the two logs and we agreed to make an effort to quickly align this unique log to actual date and only when this goal is achieved, start showing the new progressess.
To do so I need to add a lot of messages and the only viable way to do it quickly is to keep the comments to the minimum, letting the images speak instead of me.
I will comment only where needed for clarity.
Here below some new images belonging to April 23rd, 2010 with new details.
y4mTJA1W7mMWTPnnDkxp3H-EwMUFetpqAOPqlI6h
y4m99B_HIvXgaNdw-l4T__oMBK7b0a6JKUDvp9m0
y4ms-Bad5YoXhJqdz1VOAlXKl-SofFUbgfwbwq7V
y4mHKbvIUQ-kJs4RwTgkjWqiun4snAdUjBO6I8dQ
y4mxy1HSZtL_Wtg8iTFD-0bE3QSAXVlYHj5WW8BR
Next time I will try to explain the method used to check the alignment of the hull, kind regards, Jack.Aubrey
Check the proper hull alignment
I'll try to explain the method I used: if the hull is well aligned, the four angles corresponding to the first and the last bulkhead should be totally parallel. So if I overturn the hull and I put it backwards on a perfect horizontal plate (i.e. a glass plate or something similar) the hull must be perfectly stable, without any unstability. In practice it is as you take a table or a chair and you check its stability: if it is stable and doesn't move it means the four legs a right.
y4mIQk0d90g2kM7qA0xWrrQfXiYcNsn6tD7tlOd3
Now I check the support of the last bulkhead: there are no points of unstability on both sides . . .
y4mXqJJhgeJ-HS4Nh2JjN6g0ukCdHsN___CYne2Z
Now I do the same with the first bulkhead, Here too the alignments are right . . .
y4mXzRRDUysxmhc__bdqS-mbr7m2tmuPYj44a3RT
In my mind this means that both are parallel and consequently the hull is aligned. And the other bulkheads ? Simple, I have taken measurements of their distance from the plate, on both sides, for each bulkhead and if it is the same (as they luckyly are) it should mean that they are parallel to the first and the last bulkhead . . .
y4mSUHOTK6rxqX7xS4pwM-Nn8-nhgvjo1fRM733Q
Saturday and Sunday, May 8-9, 2010 - Deck planking
New progresses: instead of using for planking the deck the material provided by the kit manufacturer, I have used some laths I had that have a thickness of 1mm instead of 0,5. The main difference resides in the kind of wood I used for this activity: these laths are of beechwood. I preferred its colour to the other, more yellow for my preferences.
Here below three images of the work done. There is a great part of the hull still missing so I had to leave the planking infinished until I will receive new material in the next weekly issues.
y4msaMK72tjPXQzoqbIV0-CBnvIt9rRHK1yl8Mna
y4meqC_DiWNkVcm35iYF4VjO5xbZRVDir5fpA7Ad
y4m2qdjImcTJ9sdGdynPMrpYv7oUdVyhkGLyD6NP
I used the vinyl glue for this task and I cleaned the glue in excess with a wet microfiber cloth.
Cheers, Jack.Aubrey
Thursday and Friday, May 13-14, 2010
Additional activities on the forecastle, now fully planked . . I spent 5-6 hours to plank the forecastle, to level it with sandpaper and to apply a coat of oil for wood to see the deck in its final appearance . .
y4miu5N6zIfPdPRecs1ApoiI_wzpnZYUGLVpu66A
y4m9lw309rQUGSvvDcwgfl6tfpfi5nwkhBbzhSZL
I applied a coat of oil also on a half of the upper gun deck, just to show you the colour difference before and after the treatment with my oil.
y4mb69Mg12DZltmWsvqG4jsC52gr82WqKiluWPDM
y4mWdMR7NSzHSub4SnYUquzQlNdIfeKNIQaTNzcT
I think this difference is perfectly visible in the next image . .
y4mXf0wwSeAc7n_57sptYN_iRuBNa5u82pFFLuOO
Cheers, Jack.
Saturday and Sunday, May 15-16, 2010
New pieces added to the hull: the last piece of the false keel and three new bulkheads.
y4mdMDxtIIRP9wZGo1Swyd82XbzYC7ZG1ruLNKlw
I connected together the three new bulkheads with some laths of hard wood to avoid crashes. They will stay in place until I will install the last piece of the upper gun deck
y4mp8iF7VrpwiRZ3noN6AoMrGNtgCp4jhLhKk4U_
A couple of views of the false deck from poop . .
y4mi70tgJwXRhM0YaeRZjPzOLQOhBLwFZ7MFzbGg
I have also checked the hull alignment after the installation of the three new bulkheads . . . it's right !!
y4mK3r15va8Jrc47AWJz5Ki5PIVKkB1M81Vsch0w
Last, a removable reinforcement of the keel with clamps, always with the objective to avoid crash problems during the handly manipulations . . note also a new keel clamper.
y4mLFe89v0vjsHsgrLNLtFnreCylTHJ4Y0hVFBGc
Kind regards,  Jack.Aubrey.
Here follow other photos of the Soleil Royal hull skeleton. The wicker basket has tasted the claws of my two cats . .
y4mBd0byKZEQ9ZtdzLOIt1-ZzxK9euERqqBgjVmr
y4mxYeLgPtXwlnUPtnqWnNHPS8aB2eZm7NJgCR6C
y4ms-o7-JOmwQ7rAHebRqbdLPZG7FaZBCC4u6vTp
y4myyw8oVA24CDht9WrXNGSrTOu_gsl2aMhx63JX
y4mesaxCp2h53DrXWWgn8b3AA-iVeLtQFwHPz51j
Cheers, Jack.Aubrey
Saturday July 24, 2010 - New updates
With the issue n° 14 were distributed new pieces to complete the upper gun deck.
The new components are pre-cutted without any defect.
Once installed, without problems at all, the ply pieces of the upper gun deck I completed the deck planking. I remember that for this planking I use laths of beechwood 4 x 1mm. A final refinement with sandpaper of different grain and the final coat of oil and the work is done.
Here are three new images of the first two decks completely planked.
y4mIO9sBtV_qoSnn_dsSqivt-YjLgnsJ76I0yGqb
y4mxGKCyUsMaOLj5kt4K0jQd2l1eAEfeCFnWNfml
y4mi_-jBq1rNjocnKabtcnPqA4yCfLd6UL4ttXJy
Tuesday July 27, 2010 - Another deck near poop
Within the 15° weekly issue there is another bulkhead to install (n° 11). I decided to reinforce a part of the keel near this bulkhead to avoid risks.
y4mPIEQoHnGSOMmRc-wzXUEj79TEbkV1wY-W402j
But the main task is the installation of another deck above the upper gun deck. This deck partially hides a portion of the upper deck.
Fisrt I have installed the ply pieces before planking them, installation made with some reinforcements where I judged useful.
y4m9hVvXuFfxJ0X3cI3vGH8JNp-u6IWKFBTofZZe
y4mkZ9LJhJUBuEEJ5I7ZWo5oG1BPFYStE2dASnUU
Here below all of you can see some of these reinforcements.
y4mi17ME9BJKK2slIwxQrMNSBAd9rdyVtXDZHeut
y4mE1fOk-HPc4xbUHOp4Z9-MfJlHsvHZXNJTMFPO
Once finished this quite simple installation I began to apply the deck planking, using the same beechwood of the other decks. When the work related to this task will be finished I'll post new images.
As I wrote some message above, I'm trying to put into each message very condensed comments to let me able to describe as quickly as possible the past activities on this model. If anyone has questions, or wants to discuss more in deep some topics, I will be honoured to answer him or to explain more in deep some tasks.
That's all for today, Jack.
Sunday, August 1st, 2010 - Decks again . .
After a pause due to lack of pieces to work on, I restarted by installing two new decks in the poop area. The quarterdeck is not yet 100% finished. All the other decks are treated with oil for wood. At every new coat of oil the colour of the wood becames better (at least this is my sensation).
y4m68B3bUf7c5lvgrCa73zXeIzOvZJxBzS90Qy7l
y4moGeMnWCbUsLllLfYMxM9VFDpnQUtTYWFcI42j
y4mCLXioJg2nXoypHWc1te6bgcitku3zUeXqL7w7
y4mKaPvW0qWqTlWJVzWb7jBsHtLoYkChRlRsJH4M
y4mhvl3LRhXpWeimKBMONsl7kK2zVAngPzDwel7b
Friday August 6, 2010
This week was spent in the vain waiting of new material from the kit manufacturer. I have used all the material I have and, if nothing arrives, I will suspend this shipyard. I will not become an unemployed ship modeler because I have another model that I use to fill my dead time but . . .
I have made some enhancements to the original project, by using some boxwood as finishing of the decks, well visible in the images.
y4mhFY0O11itDGnwzjZLicSYAXZaGg1iH4YXQ6Au
y4mUX58gDsweeLsmUOXnC0EAoNebJlhUYUzBoYwJ
y4mURwFSF5Yw6qA1sdA8Qb9hFtXLb2loMi6enIgM
y4mORoGHzIiVYgQ7IXaKqT3xtoE7dq9sD1s8M4rx
y4mM2IVWa0r9hwVoMFrbBkbM55d8KuEKNUSj9V9K
As you can imagine reading my last messages, there are some problems with the shipments of the weekly issues and the bad news are that it is not possible to understand who is the guilty party: italian mail service or De Agostini ? In doubt, the result is, anyway, that I'm not receiving what I need to continue . .
Cheers, Jack.Aubrey
Friday October 15th, 2010 - Some new material is finally arrived, shipyard restarted
I finally received the no. 5 and 6 packages (issues from 18 to 25) and I  immediately restarted the work on my Soleil Royal. I have put in an idle state my work on the dutch privateer Dolphyn (Corel). It may be I will open also for it a build log in the future.
With the new material I was able to complete che hull skeleton, by installing the last two bulkheads and the last poop deck. Again I have to recognize that the material distributed is of good quality, specifically regarding to the precision of design and cutting.
Again I followed my instinct of shipmodeler instead of following the building instructions, these instructions are good but it is possible to work better.
Here below some images of the poop area just finished . .
y4mi2dJl52QEa6P_rcfIP6DEJsiQzqNmVexuANSt
y4mD5dp8tH3F3QVUNmiOMS0-g6m-6WDr8CuSek_3
y4mLFUH4mWWiqSi2CU6rqb-osWKn6YqpQT-zcamZ
y4mPXVPLtvX_-DoYoVIhrqmS1gj-XCw8jq9Cna-2
y4m3JgwiW_fHYuM9Kk5COknzVx165PoULB0euuiN
Additional images of the whole ship hull. I have to recognize that it is huge and bulky , , I'm a little worried where I will find the space at my home to keep it, if I will succeed to finish it. I'm thinking to alternative finishing ways . .
y4muTkcOR_ZRo7vYCaEc2S-obF1uslMoVuUDFxrR
y4mea8wKkNisnD5kHF3ij_4XAmuRBsO1ovl5t_CN
y4m8gNOQmHPuFtqiqN2HQMe8c2Va6Fjrsf-dsWpk
y4m8YUss_HkaXgjm6czVUjy43sd9sVeN18kWbdNh
Kind regards, JackAubrey
Saturday October 23rd, 2010 - Gratings
One task planned in the building instructions for issues 18-25 is the construct and the installation of some gratings, on the upper gun deck and on the quarterdeck.
The only change I made was the wood used for the frames: instead of walnut I used boxwood.
Here below are shown the gratings I build and I have then fixed in place . .
Gratings installed on the upper gun deck:
y4mfAh4so49vT8bp46G-AGDQvrZcyH-nVI9XGK2k
Gratins installed on the quarterdeck:
y4mi2TpnIoZYqJecVovS7lGi2tdjhpJ3yrW0X6bN
An overall view:
y4mOdQGGvX4s9YFmbTwPUuOaqpwT7mftySL3oSUw
With this further work I have completed the material I have, but, in order to continue, I decided to build the doors and the windows that will be installed in the vertical walls between the decks. Having no ideas of the layout of these doors and windows I based my work on Mantua Models plans, just for reference. I'll show in the next messages.
Cheers, Jack.Aubrey
