Hello Chaps,
Just a quick update on Sherbourne and the Display backdrop....
Painting of brickwork is complete, not the tidiest job, but I have a cunning plan to tidy up the grout lines! I need to find Tipex/White Out pen and trace round every line to add a bit more definition to it. I'll head to the hobby shop over the weekend and buy some mossy plants for seaweed and gravel/sand ballast for the beach below. I've used the foam board to add a gradient to the base, and in doing this the Hard/Stone wall sits about 15mm above the top of bulwarks on Sherbourne, so gives the impression of the Cutter being maintained at low tide in a deep port.
I need to head out to the DIY Store tonight or tomorrow night to buy the base board for the Model,I need to find something 540mm in length and 240mm wide, but I'd rather not pay over the odds for it!
Cheers
Jonny
Caldercraft HM Cutter Sherbourne Kit Bash - Scale 1:64 - http://modelshipworld.com/index.php/topic/10547-hm-cutter-sherbourne-by-jonnyamy-caldercraft-kit-bash-scale-164/#entry317289
!!!ON HOLD!!! Mantura/Sergal HMS President - Scale 1:60 - http://modelshipworld.com/index.php/topic/5589-hms-president-by-jonnyamy-circa-1760-sergal-160/
In the Pipeline:
18th Century Longboat - Scale 1;48 - - http://modelshipworld.com/index.php/topic/11273-18th-century-longboat-model-shipways-by-jonnyamy/
Completed Builds:
40 Foot Gaff Cutter - Solid Hull Concept Model
Caldercrafter HM Mortar Vessel Convulsion - Scale 1:64 - http://modelshipworld.com/index.php/topic/8593-hm-mortor-vessel-convulsion-by-jonnyamy/
SCRATCH BUILD - Vagabond 19 foot Sloop - Scale 1:20 - http://modelshipworld.com/index.php/topic/10172-vagabond-19-6-keel-sloop-pob-scale-120-by-jonnyamy-small/#entry302726
Hi Chaps,
I went to the DIY Store last night and found a great piece of oak with minimal knots and splits in it, and at 25mm had a nice weight to it (4.8 Kilos)... At £21.00 for a 900mm x 300mm length, I thought it was too good of an opportunity to pass up!
So I rashered that down to 540mm and 260mm wide (to fit on the mantelpiece) and tidied it up with a plane, rasp and a bit of sand paper.
I glued the backdrop down to the board and coated it with some PVA glue and large stone chippings I bought from the model shop. I used the remainder of the railway ballast from Convulsion to layer on top of the board. I'll head to the model shop tonight and pick up some fine sand material and moss/seaweed for the board.
I have the day off on Friday, so I will head over to the DIY Store and pick up some Perspex for the display case. I need to make four sides of Perspex and can use fibre board for the back panel.
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Hi Jonny,
That's looking very impressive! :)
How about the mooring lines? Bow line, stern line and a couple of springs should do it. Perhaps also a few bollards or rings on the quay to fasten them to.
Kester
Current builds: Sherbourne (Caldercraft) scale – 1/64th;
Statsraad Lehmkuhl (half model) 1/8th" – 1'.
Victory Bow Section (Panart/Mantua) scale – 1/78th  (on hold).
Previous build: Bluenose ll (Billings) scale – 1/100th.
That's the plan for this evening!
Those will be the final touches for the model, but I will build them on to the display now so that once the rigging is started (and eventually finished) I will be able to finish the model off with bow/stern lines and springs.
I'll take more photos tonight of the rope work tonight. As for bollards, I'm not sure if they were used in this period of history, so I'm going to cheat and use brass rod to make a series of bars sunk in to the stonework as tie down points.
Cheers
Jonny
In the Pipeline:
Completed Builds:
Hi Chaps,
If I get some time today, I will post a few photo's of my progress from last night.
I'm out for a curry tonight with the lads from work, so I'll be back on Sherbourne tomorrow!
Cheers
Jonny
In the Pipeline:
Completed Builds:
Hi Jonny.
Excellent progress with the Build and extras.
They used to use old or damaged cannons in harbour walls as ballards as well as timber.
Still many around the Cornish and Devon harbours.
Photo of example.
http://www.edwarddowden.co.uk/sale_paint4.htm
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Antony,
50 gold stars for you! Thanks for answering my question on the bollards! I have the kit supplied cannons left over so I was hoping to find a use for them. Thanks for the kind words!
I have made serious headway on Sherbourne this weekend, having run all the Shrouds, Running Backstays, and Forestay. I also build up the main sail that will be lashed on to the gaffboom and brass rings around the mast.
I still have to build the yards and rig the bow sprit, but the lower mast is almost there!
Cheers
Jonny
In the Pipeline:
Completed Builds:
Morning Chaps,
This weekend was rather busy in the Shipyard, with the rigging of the standing rigging and construction of the display cabinet!
So it is photo-update time on Sherbourne before a "Pupdate"!
Standing Rigging Photos....
Display Case Photos...
There is still a lot to do in regards to the rigging and the display case. I need to find a way of removing a few superglue stains from the Plexiglass and I need to trim a few corners down for the brass corner pieces to go over the top of them. I could also use my Dremel to neaten up the back of the case, but I can only do this one the model and backboard are in place.
PRESS RELEASE..... Time for a Pupdate!!!
I'd like to introduce Lily to you all as the new Shipyard Surveyor and Master Shipwright. She will be taking on this role from 21st August 2015. The Admiral has ordered all Ship Building to cease from 21st August for one month to get the new team member used to her new surroundings! Sherbourne is to be near to completion by this point.
As you can see, she will need a good wash before she starts Surveying!
Cheers
Jonny
In the Pipeline:
Completed Builds:
Brian,
The intention is to have the model dried out against the wall in a tidal harbour, for example St Ives, Cornwall, or Gorey in Jersey. I had thought about using the water gel stuff, but have had less than decent outcomes from using it. The last attempt I made using the stuff, it cracked and split so badly that there was not fixing it.
The photos below are the sort of look I'm heading for.....
Cheers
Jonny
Edited by jonny.amy
In the Pipeline:
Completed Builds:
Hi All,
There's been little progress to speak of in the last few days, apart from making the mainsail (same fashion as the sails on Convulsion) and stitching that on to the drivergaff. The one thing I have done though is add the reef lines to the sails, so it can be furled properly. I need to add a bolt rope and block to the end of the boom to act as the clew and outhaul. This would mean the sail is rigged correctly.
I probably will not bother with rigging a Cunningham or downhaul, just the outhaul and reef lines as they are more than likely to be seen on a ship of this period.
See the PDF for a quick sketch...
Reef Line Sketch.pdf
Cheers
Jonny
In the Pipeline:
Completed Builds:
Hi Chaps,
Again, progress was a bit slow last night. I finally got round to painting the Forecourse Yard and adding the outhaul to the spanker boom.
I also made the Staysail and the Forecourse using the curtain lining I found at the Haberdashery whilst building Convulsion. I'll draw on the sail patches, and stain these with a weak solution of tea, and leave them to dry overnight.
We have a team coming in tomorrow to fix the boundary fences on the property tomorrow and the Landlord has requested that one of us is present in the house the whole time, so I've got the pleasure of a full uninterrupted day in the Shipyard tomorrow!
I plan to get the ratlines started this weekend and maybe if the process smoothly, I might get some other bits of rigging done.
Cheers
Jonny
In the Pipeline:
Completed Builds:
Afternoon Everyone,
Yesterday's "uninterrupted day of ship building" was more of an uninterrupted day of house work that included washing clothes, mopping the floors, tidying the bedroom, tidying the lounge, cleaning the kitchen, occasional cigarette break, and then washing the dishes. Starting at 7am and finishing around 5pm, I had no time to build the model.
Next on my list of chores today, is hang out the washing and tidy up my build area (the dining room table) before I can build any further.
Oh and the best news of it all is that the model must be finished, or near completion in 3 weeks, so I've got full attention on the puppy!! I'm a little bit worried now!!
I'll keep you posted on all developments with Sherbourne in the next 3 weeks.
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Morning All,
A big update will come later on, with a significant change in appearances for Sherbourne in the last 48 hours!
I will hopefully post the update later on today, but I have to get a rejected drawing reissued and translated in to Russian before I can think about posting the update!
Cheers
Jonny
In the Pipeline:
Completed Builds:
Hi Guys,
I've managed to get some time now to update you all on Sherbourne.
This weekend saw a hive of activity on Sherbourne, with mostly all but the ratlines complete. There are still a few odds and sods to get on with, and I need to stitch the topsail to the yard, and rig the reef lines and blocks.
One thing I've noticed is that there are no stays on the Topmast and no shrouds to the topsail yard, I assume that the Topsail is the main driving sail so it rarely reefed in or furled. And my other assumption in the furling/reefing process is that the yard would be dropped to the Forecourse yard and reefed from there. Am I correct in assuming so?
Any way, here are some photo's of Sherbourne so far...
That's all for now folks!
Cheers
Jonny
In the Pipeline:
Completed Builds:
I'll get the Topsail in place tonight and grab some photo's of her up against the quay wall.
Cheers for the kind words E!
My question is a perplexing one now...
How do I clean up and remove CA glue from plastic? I've used Plexiglass on the Display Cabinet, and I managed to get a few runs of the CA glue and "Plastic Weld" glue on the glazing. Do any of you know any methods of removing CA from plastics?
I've tried using an industrial strength glue remover, but it's let a rather cloudy finish to the Plexiglass! I'm not sure what to do now, as I'm reluctant to break out the panel and replace it, or scrape the material to clear it away...
Cheers
Jonny
In the Pipeline:
Completed Builds:
Jonny, you may have to scrape some and then polish it out with finer and finer sandpapers. Most solvents that remove the CA will probably mar the Plexiglass.
Look for a company named Novus.http://www.novuspolish.com/
They sell plastic polishing kits with some liquid cleaner and polishing pads. Their website says they have distributors in the UK, Europe (Holland) and France. I've used the liquid on watch crystals and it cleans up light scratches well. :)
Ken
Started: MS Bounty Longboat,
Ken,
I've looked at Novus and I'll more than likely go down that route, but I was hoping not to scrape any material off.
What I didn't realise when I used the Solvent Cleaner is that with CA glues it just thins it, makes it pliable again and you have to scrape it off with a blade. I might give it another go tonight, but worst case scenario is to scrape it away, wet and dry the plexiglass, and then polish the plexiglass.
Cheers
Jonny
In the Pipeline:
Completed Builds:
Hi Chaps,
I have another update for later on today! I managed to get the Topsail on to the yard last night, and I also got it on to the model. The next phase for the topsail is to rig the reef lines, but I'll have to dig out some spare blocks from my President stash to finish her off!
I'll post photos later on!
Cheers
Jonny
In the Pipeline:
Completed Builds:
Photo Update time...
Sherbourne is moving on very quickly currently, and the final touches are being applied before the model is completed, but that will more than likely be in the next two weeks.
I will reef the topsail tonight, but with the Admiral being sent home from work with flu-like symptoms, I may be on duty in the sickbay.
Here's a few photo's on Sherbourne flying her Topsail up against the harbour wall.
Note in the first photo you can see a hazy patch on the display case, this where the CA Glue has run and I've tried (and failed) to clear it up. I will use my day off on Friday to clear this up, after my trip to the Physiotherapy Department at the hospital.
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Cheers Eamonn,
I was going for deadly!! Haha, last night was the start of Great British Bake Off (Lucy's favourite program), so I had to down tools rather prematurely last night because I "would make too much noise" if I continued on the model. So I just managed to paint the Marines on the Quayside and get them glued down in place before the start of the TV program.
Here is a photo of what I could see from the sofa last night!
I agree, from that view, she does look deadly!
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Haha yeah it's not the most riveting of watching, but it keeps her happy and I get the occasional cake out of it :D
Thanks buddy, I was hoping for savage! It's an Englishism too!
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Hi Chaps,
Puppy proofing the house has taken priority of Ship building this weekend, but saying that, once I have cleared my tools away for the puppy, I'll be on to the ratlines tonight.
We're seeing the puppy this afternoon and then after that it will be all go on the ratlines!
Cheers
Jonny
In the Pipeline:
Completed Builds:
