I'm doing a combination hand-building some things, and using some of the cast-metal items supplies with the kit, such as the windlass, binnacle,
galley stack, and figurehead.  The windlass will be improved upon with hand mixing and painting for the impression of Oak, then weathered a bit...
Current Build : Sultana Schooner
The transom is next - I've added height to the overall shape as Mr Passaro outlines in the practicum, and I too, will give depth and dimension by
stacking two 1/32 sheets together (the first layer will hold the window detail, the outer layer will show architectural details...
From posting these pictures right after a day's work, I've learned that maybe I should make some pictures, and then study them to see what details can be finished in a better way before I post them for all to see.  It gives an honest perspective that I don't have staring at the project all day on my bench...
Are your gratings finished or dry fitted?
I ask because I believe they should be set into each other (like egg crating or those divider cardboard sheets between bottles at the liquor store) so the top side and underside are flush.
Alan O'Neill
I wasn't really sure how to make gratings without those notched pieces that I saw in the practicum that were purchased separately. Maybe I should slice some openings in each piece of wood, and push them together so everything finishes on one plane?
This will sound easier than it is...
Practice on two or four scrap pieces  first.
Take all your pieces (top and bottom) and use CA glue (a very extremely small dab) at a similar corner at both ends and secure them to a base board, side by side, in line, solder style to look like one solid piece,
Let this cure.
Mark off the thickness of the pieces with a very sharp pointed soft HB pencil and a 90° square perpendicular (across) to the joints
Cut into the pieces (straight down, light cuts) with a sharp thin blade (exacto) knife to not more than half the thickness of the pieces following the lines
Chisel out the notch making light diagonal cuts
Fold some sand paper and using the edge sand out the humps... or use the edge of a nail file if it will work
Use rubbing alcohol on a cotton ball to wet the glued ends of the wood, let this soak in for some time to free the glued ends. Do not force the pieces apart however tempting this may seem.  The rubbing alcohol will dissolve the glue and you should be able to twist them off.
Dry fit the notched pieces together
If they look reasonably good glue them together to make your rough grating
Very lightly sand top and bottom sides to be flush and you are done
There is no better feeling then having done it yourself!
Edited by AON
Alan O'Neill
I got on a scratch-building kick, before opening the kit bags.  I'm gonna go back and use the cast gratings supplied with the kit. I think I can detail-paint to make those appear to be wood.
Check out the grating kits offered by Chuck P's SYREN Ship Modeling Company. I have made my own in the past, but just finished up one of these. Very nice!
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Hi Bob,
Check out THIS LINK in my build log where I'm making Parrels - lots of them! You can use the same technique for making your gratings.
:cheers:  Danny
Cheers, Danny
