HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
That belt does look like a .50 Cal belt...  :)  Nice work on the turret.
Mark, thanks for the nice words.  With some luck and more time at the bench, perhaps she will to look more like a proper PT Boat!
Cheers,
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
At this point I need to be sure the chart house matches the camber to the deck.  I have applied a piece of 150 grit sandpaper to the deck where the chart house will be glued.  I'll work the chart house back and forth until it matches the deck camber.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Thanks Alfons, actually this wont be the final color, what you see now is just the primer coat.  I still need to decide which color to go with, I'm leaning in the direction which they were delivered from ELCO to the USN which are two shades of gray, one for the hull and one for the deck and above, this measure was known as "Standard Gray."
 post-260-0-96870100-1391105443_thumb.jpg  post-260-0-18922600-1391105442_thumb.jpg
Cheers,
Tim      :cheers:
Edited by Timothy Wood
Tim
Future Build:
Completed Builds:
Member:
Wow!  I never dreamed of claiming color blindness, that's a great idea!  I'll be sure to use it in the future!   ;)
Cheers,
Tim          :cheers:
Tim
Future Build:
Completed Builds:
Member:
John,
I would normally agree with you except I have a very steep learning curve when it comes to my airbrushes.  I surly don't want to mess things up beyond repair!   :huh:
I do like the 41/20L camoflage measure though.  Actually I have been batting this idea back an forth, see below!  I may be able to handle this paint scheme.
I'll make a deal with you.  I'll do the measure 41/20L, if you do the one posted below?  Do we have a deal????
Cheers,
Tim     :cheers:
Tim
Future Build:
Completed Builds:
Member:
Alfons,
There's a 50-50 chance!  Still a long way to go before I get to that point!   :)
Tim
Tim
Future Build:
Completed Builds:
Member:
The next step will be to install .020" molding along the plywood spray shield.  The instructions state "Cut and glue the .020" plastic moldings to the top of the 1/64" plywood spray shields. The moldings should be flush with the cockpit (inboard) side of the shields and overhang them outboard (sketch #13)."
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
:D :D I was going to do a shark's mouth on my lobster boat......but john talked me out of it.   I have some decals from a P-51 Mustang model :D :D    I wouldn't think there's a better way to get the proper camber for the structure.........that is a pretty sweet idea  ;)  great update Tim.......she's looking swell.   camo would look cool....but no.....they didn't all look like that.......did'em in the field,  as they saw fit.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Tim.
As for painting schemes, have a look at the swedish combat boat 90 at the picture below. This vessel is used by the swedish naval infantry since the early 90:ies, mainly as an assault craft, but aslo as med-evac and battalion combat command post. The boat is equipped with three 12,7mm machine guns and one 40mm grenade launcher. It is quite an impressive boat, which I have hade the opportunity to board a number of times.
http://en.wikipedia.org/wiki/Stridsbåt_90
/Alfons
Current Build: Gloucester Fishing Schooner - Blue Jacket - Scale 1:48
Next Project: Riva Aquamarine - Amati
Tim,
I'll have a think about it - just as soon as I can figure out what it is!
John
Thank goodness it isn't a jigsaw puzzle!   :D
Tim
Tim
Future Build:
Completed Builds:
Member:
Alfons,
What a neat looking Patrol/Assault Craft, It sounds like they can really pack a punch!  You are fortunate to have had the opportunity to be onboard for a "close-up and personal" viewing of them, were you able to get aboard one while underway?
As a U.S. Navy Photographer I was lucky to have many of the same type of opportunities as you have had,   We normally had full access to all parts of the ship we were stationed on.  I was lucky enough to get into the reactor compartment of the USS Dwight D. Eisenhower (CVN-69) and view the reactor through the leaded glass viewing ports.  It was one of my many experiences I'll never forget!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Popeye,  I believe I can duplicate the shark's mouth, I may have to experiment with it some first!
I agree about doing them as they saw fit, also they often did modifications out of necessity.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
Ok, I admit it, I didn't finish installing the molding along the spray shields before I added a coat of primer to the chart house.  I have a new air brush I wanted to try, so needless to say I justified it to myself!   :)  The airbrush is a Vida,  and at this point in time after my first try, Im very satisfied with its performance.  You can clearly see a fresh coat of primer reveals a "world of sins"   :o  which I'll have to fill and sand before it's even close to the next step.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim.
The firepower of the CB90 is impressive, the swedish SEAL team uses them for surpressing fire once the platoon has unloaded. One other feature is that you can come to a full stop in less than 3 boat lengths, from 45+ knots! There are videos of this on youtube. So far I have not been able to come onboard underway, but there might be opportunities ahead. One funny thing is that during my last visit of the CB90, I actually bumped in the the swedish foreign minster and his son.
You actually got to see the reactor compartment of the CVN-69! What I wouldt do for a full tour of a carrier.. i don't suppose you have any pictures :) I have read one very thorough book of the Eisenhower class, can't recall to much information about the reactors though.. seems to be a lot of top secret surrounding that area.
Your PT Boat is coming along nicely, keep up the good work.
/Alfons
Alfons,
Thank you for the kind words!  I just finished more filling and sanding on the chart house and I'm just about read to apply a second primer coat, hopefully I've made some positive progress!   :)
I'll add a couple more progress photos when that's complete.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
This is my second of primer after some more filling and sanding and it's revealed the need for more filling and sanding, just not as much as the first step.
You can see in the view from the final photo which is back if the chart house, I still have lots of finish work to complete.  I need to pay more attention to the fine details in the assembly of the day cabin and main engine room hatch.  Hopefully it will save me time on the backside!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings Tim,
Seeing your Elco in progress brings back memories of when I built mine several years ago. I resisted making her another reproduction of PT 109. As you probably know, there is a wealth of information about PT boats on the 'net. One site listed all the PTs by number and how they ended up. I choose PT 164 which, of course, was an 80' Elco. She was sunk at Rendova by the Japanese Navy on Aug. 1, 1943 - approx. 11 months after her keel was laid.
I just finished the BlueJacket 1941 17' Chris Craft. I think BlueJacket makes outstanding kits. I've also built their Jefferson Davis revenue cutter and Charles P. Notman 4 masted schooner.
wq3296
Greetings Tim,
wq3296
Greetings wq3296,
I agree with your observation that BlueJacket Shipcrafters does an excellent job with their kits!  I also have their kit of the Fletcher Class Destroyer USS Kidd DD-661, they were hansom ships!  I think I'll be building my ELCO as PT-124, Tom Freeman did a rendition of her sinking the IJN Destroyer Makigumo in 1943.  I plan to order a copy of his print when I've finished the kit.  Here is the link to his website and the painting: http://www.tomfreemanart.com/10.html
Do you have any photos of your build or the finished kit?  I would sure like to see them!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
I have sinned!
I've spent too much time away from the building bench!  My goal it to attach all the photo etch on the chart house today, below photo shows the marks I have marks I have made for the placement of those parts.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Ouch.  The good thing about using a primer it shows you all the mistakes you have made.  I think you are doing a swell job.  Keep up the good work.
David B
it looks great Tim..........if your only sin was staying away from the bench,  then your forgiven.   there's no time limit  ;)    an easy way to repent,  is to get that detail on there!   looking forward in seeing what it will look like!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank's Popeye,
I working on it!
I've learned coffee and photo etch parts aren NOT compatible!    :mellow:
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
interesting.........I'll have to see what the combination of these two products caused :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I also learned Model Expo un-cure is an excellent paint remover, (all the way down to bare wood).   :o
I may not make my goal today!   :(
The most important thing Ive learned, is that it all can be fixed 'Don't sweat the small stuff'.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
