Good Morning everyone
On my Endeavour the waterline and wales positions are not drawn.
Should the plans show these? Or is it up to the ship builder to position the wales in
a line that looks good?
I would have thought that the waterline is something that would have been
decided when the ship was being designed.
I see that the wales can be worked out by evenly spacing down from the gunwales
and working out the heights bow and stern. But on the pics of the Endeavour the bottom
of the wales seems to be at the waterline, which I don't have.
All help much appreciated Thanks Chris
Edit I should have said it is an Artesania Latina kit
Edited by Cabbie
Chris,
Go to the Kit Build Logs and search on keyword: Endeavour.  There's 7 logs it looks like for the AL version.  One of them might have run into this problem and solved it.   I've not done this ship so I'm no help.
There is a book
Captain Cook's Endeavor (Anatomy of the Ship) Hardcover – April 6, 2010
The paste in is from Amazon  -  Using the book,  you should be able to derive just about anything for this vessel.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
While not able to answer about the wales, I can discuss a bit about design waterlines. Regrettably, they were more art than science. The designer showed where the ship should float, but it all depended on lading and ballast to achieve. The British didn't adopt more scientific methods of calculating displacement until mid-1800's, even though early (approximate) methods were known in the mid to late 1600's.
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
It is strange that the waterline and wale positions are not on your plans, I built the AL Endeavour (a long time ago) and there was a plan showing the side view. Here is a photo of the original draught maybe you can judge from this where the wales and water line are. I think that its very important to get the position and curve of the wales correct as it determines the whole look of the ship.
Current Build: HMB Endeavour 1:51 (Eaglemoss part work)
Previous Builds: USS Constitution (Revell plastic) HMS Victory 1:96 (Corel) HMB Endeavour 1:60 (AL)
