Sultana Post 18 begin photo 73
Task is to lay the deck and margin plank.
I milled the deck boards out of soft maple. In the future I’ll use bass wood or Swiss pear because soft maple is hard to work.The margin plank was made of 2 plybirch plywood.
Photo 73
Photo 74
Photo 75
Photo 76
Photo 78
Deck prior to adding treenails
BFN
Cheers,
Hopeful aka David
“there is wisdom in many voices”
Completed: Sharpie Schooner (Midwest) Posted in kit build section of forum
Current: Sultana (MSW) Updating the build log and continuing on with the build
Next: Lady Nelson (Amati Victory)
Edited by hopeful
Post 19 of my Sultana Build
Task is to treenail the deck. Used an awl to mark the location of the treenails.
Photo 79
Photo 80
Used a size 73 drill for the treenails holes.
Photo 81
Finished deck with treemails.
BFN
Cheers,
Hopeful aka David
Hopeful David,
Have you ever used Cherry before?  It is a great wood to work with especially if you decide to sstain it ot use paint.  Cuts well and holds sharp edge,
David B
Note to the forum.....
David B: I have used cherry but not for boatbuilding. You have encouraged me to take another look. You are right it machines and sands well. What are the best uses for cherry?
Bob (hexnut): Thanks for stopping by. Thanks for your kind comments. One of the challenges with the Sultana is that it is in 1:64 scale and very detailed when using Chuck's practicum, priceless. I will start putting something in the photo to give one a better sense of scale. Hull is 10" between the perps, if memory serves.
 I looked at your "smack" build....nice work, Bob. You must be an illustrator as your drawing is very professional.  Wish you well as you move along.
Patrick:  Thanks for your kind words about my build. I'm building the Sultana to get solid hull experience. Some aspects of the kit have given me problems but that is how we learn.
I have and continue to follow your Niagara build, just terrific. Two vessel I really like are the Niagara and the Syren. Ready to enjoy the rigging part of your build!
BFN
Cheers,
Hopeful aka David
Edited by hopeful
Several members of my model club swear by it.  From framing to planks.  Cherry's tight grain makes it an ideal wood for almost everything.  And it maybe more easier to get that pear.  Your Sultanna is coming along nicely.
David B
David:
I have used cherry for framing, planking, belaying pins, deadeyes, blocks, etc. I made a binnacle cabinet on my battlestation model, granted at a larger scale, but it worked really well.
Note to the forum:
Russ & DavidB:  Thanks for the update regarding cherry. Did not realize it was so broadly used in boat building. I have a real good wood store close by and will go there and buy some cherry for my wood bin. Good to know, Russ, it has application for making blocks.
Have a great weekeng guys
BFN
Cheers,
Hopeful aka David
Post 20 Of my Sultana Build Log
Next step was to add the remaining strakes above the wales and fair the hull.
Photo 82
Photo 83
Planked the counter.
BFN
Cheers,
Hopeful aka David
Edited by hopeful
Post 21 of my Sultana Build Log
Task is to plank and paint the inner bulwarks. Bulwark stanchions are not required with this build.
Photo 84
I used the bending plank to prepare the wood for the bow portion of the bulwarks. The planks were painted with a gouache paint. It is water base and dries dead flat....no sheen.  One can overpaint easily if touch-ups are required. I went for the paint because of its dead flat character.
Photo 85
Am continuing to protect the deck with low tack painters blue tape. The paint work is done with the exception of the interior transom which comes later in the build.
Will add the verbage as an edit.
BFN
Cheers,
Hopeful aka David
Next: Lady Nelson (Amati Victory Kit)
Edited by hopeful
Task is to make and assemble the stem, keel and stern post to the vessel. Parts are of soft maple. Will post photos and follow with dialog later.
The stem, keel, and stern post were made of soft maple. In my first build the those parts took a real beating while I was building the vessel. I wanted tough wood for those parts on my Sultana.
I decided to make the stem in one piece rather than multiple parts. I took my time to make an almost perfect bow template before cutting wood. I cut the inner part of the stem piece first, and then placed a wider line than required to represent the outer portion of the stem. On the first pass the stem fit the hull almost perfectly. A bit of planning and patience really pays off.
I also made part of the bowsprit in order to determine if the stem was high enough for it to rest of the stem This turned out to be a good idea as I had to add a 4mm piece to the inner part of the stem to get it to the right height.  You can see the addition in Photo 89
Photo 86
Photo 87
Please notice that the stem was thicker than the keel by a few mm's. I did this on purpose because I new I would never be able to get the two piece to mate perfectly when gluing them together. Once the two parts were glued together I had only a small bit of sanding to do in order make them the same height.
Photo 88
Make certain the bowsprit is at the correct angle per the drawings before adjusting the stem.
Photo 89
Note an additional piece was added as a place to rest the bowsprit on the stem. Final fit of the stem to the bow.
Photo 90
To glue the stem and keel together perfectly flat and true I placed them on a sheet piece of glass. Once the glued dried I only had to sand the joint lightly with 200 grit paper on a wood block.  I learned this and many other building techniques from Danny.
Photo 91
When fitting the keel and the stem to the vessel I noted that a little putty needed to be added in several places as well a some sanding.  With this in mind, I covered the keel and stem with blue tape to protect the parts. Here the keel and stem are glued to the vessel. Pins keep the components centered.
Photo 92
Words to follow.......
BFN
Cheers,
Hopeful aka David
Edited by hopeful
Post 22 of my Sultan Build Log
First, Thanks Randy for stopping by. Note you have finiished planking your SF II, nicely done!
Repost continued.....
Next......Making & fitting the rudder before adding the transom.
Photo 93
Photo 94
Photo 95
Must taper the rudder from front to back. Test to see positiong through the deck at this point.
Photo 96
BFN
Cheers,
Hopeful aka David
Post 23 of my Sultana Build
At this point in the build I made a pine display base for the vessel. I used a base of a model featured in the National Maritime Museum (NMM) as inspiration.  This was a fun project.
First I drilled three (3) holes through the keel and one inch into the hull 1/16” in diameter using my drill press. The holes will be fitted with 1/16” diameter brass pins 2” long. No need to glue-in the pins, they are to be friction fit only. Do not use tube for the pins as they will break off if you need to make hand adjustment to the hullk to make it straight once mounted.
Photo 96
Photo 97
Photo 98
Photo 99
Photo 100
Photo 101
Inorder to get the slope of the base parallel to the water line, I placed a block of wood to the underside of the bow end of the mounting board.
Photo 102
When I finish painting the monting board later in the build,  I will return to this post and show photos how it was done.
BFN
Cheers,
Hopeful aka David
Edited by hopeful
Post 24 of my Sultana Build Log
Task is to add the wales.
First step is to paint the hull an off white from the bottom of the first applied strake consistent with the practicum.
Photo 103
Photo 104
To afix the wales I first applied blue tape at the bottom and Timiya tape at the top of where the wale is to be glued in position. The method prevents the glue from sloshing around. End result is a prepainted wale glued to the hull without any hassel what-so-ever. I followed my presious practice of applying a one inch strip of PVA followed by a dot of CA to help the wales stick fast to the hull.
The pins hold the wales is place when guled to the hull.
Photo 105
BFN
Cheers,
Hopeful aka David
Edited by hopeful
Post 25 of my Sultana Build Log
Task is to build and add the transom
There are two ways to build the transom. One is to built it on the vessel, the second is make and assemble it off the vessel, then add it to the stern as a completed assembly. I decided my best hope was to work off the vessel and add the components to the stern later once finished.
This step in the build will really test your patience, it did mine!  Go slow.
Photo 106
Photo 107
Simple drawing made from my  stern. Wood part over sized for now.
Photo 108
Material is 2-ply birch plywood. Note the two holes between the 1 & 2nd and the 3rd & 4th window frames. These holes act pilot holes to enable the builder to assemble the three main components together for a perfect overlay of parts later  in the build. Take a peak at photo 111 to see the 3 component parts.
Photo 109
Dry fit to make sure I am on the right track.....
Photo 110
Applying lower moldings.....
Photo 111
Three components made to complete transom. One places and glues the components on the vessel one at a time using the guide holes. It is not possible to bend the entire assembly in one piece to the transom.
Photo 112
Three components glued together and added to transom prior to trimming edges to final dimensions.
Photo 113
Black behind windows is a piece of black film from the center of a comyter disc.The film is very thin and was given to me by Kip (Sawdust). Aternative is to paint behind the windows prior to assembling the transom.
Thanks for looking in on the build. Reposting of log almost completed, yeah!!!
BFN
Cheers,
Hopeful aka David
Edited by hopeful
Post 26 of my Sultana Build Log
Adding the cap to the transom.....
Photo 114
Covered the transom with Timiya tape to protet it while adding the cap.......
Photo 115
Bending jig the same radius as the transom....
Photo 116
Testing the fit.....
Photo 117
Cap only goes to bottom of lowest part of transom molding. Later a fashion piece will connect the transom to the wales, see drawing in photo 106 in post 25 above.
Photo 118
Shows  inboard side of transom with cap and finished paint.
BFN
Cheers,
Hopeful aka David
Edited by hopeful
Dave - that's a nice simple jig - and it certainly does the job well.  Looking forward to your log resumption.
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
Beautiful job on your build. I had forgotten how nice a job you have done on this. It is looking great.  :dancetl6: This will be one of the best Sultana build there is. Something for the rest of the builders to try an accomplish. Keep up the great work and thanks for reposting
Edited by Pete38
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Bob...Thanks for checking in.  I am a few days from restarting the build. Need to finish up the repost log and update my photo editor. Then I am good to go. Thanks for the encourgement.
Pete...Nice to hear from you. My build is coming along. Ready for the restart. Mindset is good. Thanks for your kind comments. I had the benefit of readiing all the Sultana logs including yours and mostly applied all that I learned from them. Miss those logs!!! I am following your Triton Cross Section Build. Seems you are having too much fun to ever repost your Sultana Log.
BFN
Cheers,
Hopeful aka David
Post 27 of my Sultana Build Log
Patrick & Randy: Thanks for stopping by the build. One of the great things about the forum is the learning experience made possible through all the build logs.
Next......Wanted a change of pace so went ahead and made the bowsprit and jib boom, great fun. Material used was soft maple.
Photo 119
BFN
Cheers,
Hopeful aka David
Edited by hopeful
