Hello, I am going to start my Triton made!
First,I have downloaded the "TritonKeelPlan@48-1" and find a printshop to printed with "actual size"
and this is the detail of the drawing
print another drawing and cut down some piece carefully
this is all I have done, my confusion is the keel wood's choice "Beech" or "Pear wood"
Beech is bright and easy to cut
Pear wood is hard and tough but more dark and red
If decided which wood is more beautiful. I will cut some piece to start the making. What‘s your suggestion? :)
sorry about my English.... :huh: ,can you read it?
I would go with the pear wood. I personally don't like the darker points in beech
Regards Christian
First of all good luck on your build. You can use whatever you want after all you are the captain of this build. I like the pear better, and as Daniel and Pete said you can use the pear for the keel and stem and the beech for planking I think is the best choice. The beech is not that bad because the look of  it is like "small" scale oak (the wood used on a real ships).
Greetings, Sinan :pirate41:
Build log:TRITON POB 1:72
Looks like you're off to a great start. We can read your English just fine. :)
Way to go Muggle!
Nice color of the pear timber. Is it enough dry? Good work.
Best wishes!
Daniel.
It's dry enough,but so busy this days.I haven't work on my ship :mellow:
Hello Muggle,What is the name I should call you? Are you in China?
My name is Larry And I started this build a short while ago.The thickness of the Bobstay and the Eaking is 8 mm.They will be tapered later.
Your picture of the chocks shows only 3 and there should be 4.The timber you chose is nice
Best of luck Larry
With Age Comes Wisdom,I'm Still Waiting!
Current Builds:Syren.Triton Cross section.
Completed Builds: Virginia by AL
                           King of the Mississippi by AL
                           Constellation by AL
Best of luck Larry
Thank you !~Yes, I am in China.and you can call me "zhongYang". Thank you very much for your information,I will use the sandpaper to make it at 8mm and tapered as the drawing. :P
There have to be some drawings with every piece for the Knee of the Head, Deadwood and so on in the collection of the MSW drawings.
Regards Christian
Yes there are drawings for Fore Deadwood, Fore Pieces - side view,and  Keelson pieces - side view. all the rest will have to be taken from the keel plan. I am glad tosee so much interest on this subject from China and the world for that matter
Cheers, Guy
The Learner
Current Member NRG,SMA
Current Build: HMS Triton 1:48 on line
