thanks Carl and Augie :)
when I am spray painting I am wearing eye nose and mouth protection, already have enough problems with allergies ;)
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
You could make a spray box with a ventilator used in e.g. a bathroom, or an old hood from above a kitchen stove and lead it outside through flexible tubing. You won't get that spray smell either ...
P.s. I have to admit I use the same unhealthy setup as you ... :huh:
Carl
yea......winter is hard for me,  since I don't have a booth either.........I just spray in the cellar.   warmer days are much better,  when I can do it in the Garage  :)     wide open spaces is my booth!  ;)    any progress is good progress.....good to see your back!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
little or no progress and I have a dilemma
the picture shows the instructions for the little structure where the doors need to be fixed above the green border
however in real this would mean the doors will go all the way to the top which would be impossible in real
so I can either shorten the doors (they are metal so wont be easy) or I cut slots in the green border so they sit lower
haven't decided yet
If the door is that cast white metal, it should be fairly easy to sand off some from the bottom using a sanding belt.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
What Augie said.. sand or file away.  The white metal is soft.
Carl
thanks for the advice guys. I don't have a sanding belt Augie. might be the next tool I buy but no budget at the moment so I ll have to do it by hand :)
Adrieke,
Nothing wrong with some manual labour ... we are just plain lazy ;)
Carl
That'll work.  Make a little sanding block and start with probably 100 or 150 grit.  Keep it straight!
Augie
Previous Builds :
you may not have to cut the doors.......the green border is an edge molding.  it can be trimmed away to install the doors.......the top of the door will be lower to show more head room in the cabin ;)  I be surprised if the actual pictures of the ship didn't show them this way.   glad yo see your back at the table >big thumbs up!<
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye might be right.  Any pictures of this area on the real ship?
I did do some checking into it.  I did find models of this vessel,  with the doors raised 1-2 mm above the deck........but with none of this molding.  you still can get away with it though......cut out the molding leaving this difference,  and you should be good  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I don't know, Popeye.  A door sinking down halfway into a molding?  Think I'd just as soon drop it all the way down to the deck and cut out the molding there entirely.
But Adrieke is the Capn'   :)
Augie
Previous Builds :
that was my earlier thought.......drop 'em down to the deck.   I agree........Adrieke will figure it out,  with the thoughts we've batted around  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi  Adreike, Very classy looking display cabinet,shows your fleet real nice,for my 2 cents worth I would put the door down the floor with trim to each side. good advice on the spray box,prevention better than cure. G'Day Edwin
