Due to the forum crash, posting some images again...
Edited by DiKri
Current build: Wasa (Corel)
Already build: HMS Fly (Victory Models)
Starting the hull structure...
Second layer planking:
The galleries...
Very nice build so far. If you haven't done so already, I recommend you visit the Wasa museum in Stockholm. Not only do you get a lot of inspiration (not that you would need it), but it is also impressive to see the ship in real. Keep up the good work!
Current build: Rattlesnake 1781 (Mamoli)
Thank you all for your reactions.
Dominik, visiting the Wasa museum is something that I will certainly try to do.
For now, I'm building the model as intended by Corel, knowing well that it will not reflect the original completely.
Further work has been done on some details on the deck. I also started with attaching the decoration.
Wow, the details are looking great! Keep up the great work...This is very inspiring!
Cheers
Steve
Built:
Charles W. Morgan - Artesania Latina  1/50
Pilgrim 40 Trawler - Scratch  1/24
RCMP 40' Trawler - Scratch  1/24
Flower Class Corvette - Matchbox/Revell 1/72
Current:
HMS Serapis - Aeropiccola 1/60
Future:
NEW! Just Added: Friesland - Mamoli  1/75
San Felipe - Mantua/Panart  1/75
BonHomme Richard - Aeropiccola  1/50
Wasa - Corel   1/75
HMS Victory - Mamoli  1/90
HMS Unicorn - Corel  1/75
Wow! Nice work! I like the golden look as well....you have my vote! ;)
Built:
Current:
Future:
Wasa - Corel   1/75
Hey Dirk!
I have a thought for you to try if you like...have you thought about applying a dark wash to the gold details...this should settle in the low spots and highlight (accentuate) the highspots (details) ?
It might make the details in the castings stand out and be even more pronounced without taking away the golden look!
Just a thought...maybe to try on a separate piece...if it doesn't work just add varsol or alcohol depending on whether you use an oil based wash or a water based wash....
Steve
Built:
Current:
Future:
Wasa - Corel   1/75
Hey Dirk!
Steve
Thanks for the suggestion. I will consider testing it. I don't have dark wax in the house now; so I will need to buy some first :-)
Hey Dirk
Not sure if something was lost in translation but as a wash, I meant a very thinned dark paint like 20:1 thinner to paint and using either oil based or water base based paints. You can try difference ratios of thinner to paint but this should give you a starting point. I and many others use this technique in military model painting to bring out details and then dry brush lighter colours on the highlights...but with this I would just add the wash and then wipe off the excess .
I wasn't meaning a wax....
Hope this helps clarify my friend.
Cheers
Steve
Built:
Current:
Future:
Wasa - Corel   1/75
Hey Dirk
Cheers
Steve
OK! Indeed lost in translation. Thanks for the clarification Steve. I never did that kind of things with paint, but never too old to learn :-)
Dirk
  • 4 months later...
  • 2 months later...
Hello Dirk. First time I come to see your work. Splendid!!! Keep on sending photos.!!!
Edited by Ulises Victoria
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Thanks! I am already following your build a long time and this has been a great help for me.
  • 2 months later...
All masts and spars are ready with blocks attached according to the Corel plans.
I placed the masts on the hull just for the photo. The background isn't what it should be, but nice pictures is for later...
Next I experimented a little bit with a Bosch PLL5 laser pen as help in aligning the masts. Seems to be very helpfull...
