I only found out later, much too late later that the stern planking on either side of the stern post should be at a 45° Angle:angry:
My fault. It's been a fun process though.
Regards, Scott
Completed builds:
Awaiting construction:
Last few hull planks and it's onto plank the 2nd deck.
Mamoli suggest the same 5mm wide planks as used on the main deck to be used on all the decks. But I didn't like the look of massive bulky planks on the smaller decks so I raided my stores for smaller width planks.
Also tested heights for cannons at this stage and cut out the 2nd deck gunports ports.
Regards, Scott
Completed builds:
The next stage to start working on the stern galleries roofs and ornamentation.
The decorative peices around the windows were painted and attached. Abit of bending and elbow grease and finally got them to fit properly. They are of a soft metal.
A 2×5mm strip was bent around the top of what is to become the gallery roof.
The green is actually dyed Wood strips that had to be cut and mounted on the inside of the decorations under the windows.
Regards, Scott
Completed builds:
Hi Scott - you are doing a fine job with this kit. I built it many years ago. One thing I noticed when I built mine was the bottom row of dummy gun barrels stuck out way too far. I didn`t notice it until they were all glued in place - I should have shortened them or got shorter gun barrels. You might want to test fit them & see what you think.
current build - HMS Vanguard - Model Shipways
Yes I have seen that too with the build log of greatgallons.  But lucky for me this kit must be a newer one as I have already measured and they are fine.
Cheers for checking in. :D
Regards, Scott
Completed builds:
6 hours ago, granta said:
Looking pretty sharp, Scott. Sometimes the quality and finish of the decorations on these sorts of models can look overscale and detract from the model but these look terrific.
Grant
Thank you Grant for having a peek.
These decorations are coming up great. It's putting so much weight onto the model that I had to move it's temporary stand down the keel towards the stern in order for the model to be balanced.
Thanks for checking in. :)
Regards, Scott
Completed builds:
So onwards to planking the fore deck.
Also the green laths are being installed. These are to be installed as a clinker type style. The wooden beams for the both balcony roofs are bent to shape and placed. So far so good.
Regards, Scott
Completed builds:
The horses with mermaid tails went on next. So far the decorations are fitting ok.
Regards, Scott
Completed builds:
Thank you kindly for the likes guys. Please feel free to ask any questions.
Regards, Scott
Completed builds:
Port and Starboard gallery roofs done and planking with green strips up around the 2nd deck gunports.
Started to add stern decorations and painted the central crest.
Regards, Scott
Completed builds:
The last of the green clinker planks going on and the Wales and strakes painted black.
Waterways and gunports. Are being framed and the cap rail going on top of the bulwarks.
Regards, Scott
Completed builds:
Tempted to buy another of these after seeing yours. I remember the kit I did build years ago was plagued with problems but perseverance paid off. The main problems with mine were the gun ports! Not one of the notches lined up so I had to redo them on the frames. It was an old kit left over from my father which from memory was bought in the late 80's in Holland
Anton T
Current build
1/78 Sovereign of the Seas - Sergal - kit bashed
1/72 Arleigh Burke class DDG flight iia/iii - Sratch built RC - no log
Waiting for further inspiration
STS Leeuwin II 1/56 scratch built (90% completed)
Previous builds - completed
1/72 HMAS Brisbane, Airwarfare Destroyer 2014 -Scratch built RC - completed
1/64 HMS Diana 1796 - caldercraft kit - completed
1/75 Friesland 1668- mamoli kit - completed
1/96 HMAS Newcastle FFG 2011- scratch built RC - completed
1/75 Vasa - Billing Boats - completed
I have seen other logs on here with the same problem, But I guess I was lucky. After reading about this problem in other logs of the Friesland, I was waiting for it to happen to mine. But yeah, as I said, lucky.
The plans show the ports cutting through the Wales.  But not quite to the extent mine do. I had just followed the countor of the decks .
You might struggle to find one of these kits now as the manufacturer has shut up shop. Have a look at Ages of Sail as they still have a supply of Mamoli such as the Friesland.
I really want the HMS Beagle by Mamoli but I'm affraid it's way out of my limited budget. Maby if I win lotto....😂 Cheers for looking in.
Regards, Scott
Completed builds:
If I can't I do have plans for De Zeven Provinciën so I could just scratch build that one hahaha
Perth Hobby did have a beagle a while ago.
Anton T
Current build
Well when I'm done your most welcome to my plans of her. If there is anything left of them!
They only have the Mamoli 1:93 USS Constitution left in Stock. It's looking very bleak now.
Regards, Scott
Completed builds:
Cathead sheeve's drilled and carved out, And assembled onto the bow.
Handrails on foredeck almost done and the decorative Wood peices bent to shape and placed.
Also gunport lids are being installed.
There are for vertical strakes at midship that cross the Wales that have been installed.
Regards, Scott
Completed builds:
Deck fittings like pillar ornamentation and stairs, Handrails, Belaying pin racks added.
Regards, Scott
Completed builds:
Haha thanks! I'll keep it in mind. I was wandering what had happened to mamoli. They have produced some beautiful and interesting vessels.
Anton T
Current build
Such clean work!
Anton T
Current build
Sorry about the poor quality photos. The cannons have all been painted and carriages that were placed under the decks have had the cannons placed on them.
Had to make sure to place these carriages first as it would of been very difficult after the decks had been installed.
Regards, Scott
Completed builds:
Cheers! Thank you.
 They had that large fire which burnt everything to the ground, as reports have it.  But no need to worry as Dusek has come to the rescue. They have the rights to now reproduce Mamoli kits. Same but a little bit better. Just have to wait for the release.
Regards, Scott
Completed builds:
Cheers JP. Thanks. It's a job and a half.!  But it's coming along nicely.
Regards, Scott
Completed builds:
10 hours ago, Tallshiptragic said:
Such clean work!
Thank you very much.
I'm very pedantic about clean builds and the way I build models.
After each session I clear away all my tools and rubbish. Have everything neat and tidy.
You may notice in a few of my posts I'll have the table clean, cutting mat square to the edge of the table and pencils and rulers perfectly lined up. It makes me a little depressed when I have stuff all over the place. Haha.
I'll let you in on a little trick. - Take a photo of your build. Examine the photo.  I bet you will find One or two things that don't look right and parts you need to fix up that you don't notice otherwise.
 The camera never lies! It's helped me a few times to point out bad areas. Only if it's a good camera that is.
Regards, Scott
Completed builds:
Okay, So more guns ports made up and fastened and deck railing on the second deck done. The bow has received its ornamentation timbers,
All the deck grating is completed and the ships boats chocks are in place.
Cannons are are assembled and placed on the deck. I rigged these cannons the best I could with just a breach rope. I had a go at rigging the blocks and all, But with disastrous results.  Also at this stage the rudder was fabricated and installed.
Regards, Scott
Completed builds:
Opps and let's not forget the bay windows that are placed just above the gallery roofs on bother sides.
Regards, Scott
Completed builds:
Channels and chain plates on, Deadeyes attached. Last of the ornaments and decorative peices fitted.
Ropes on all gunport doors. Bow figure head is installed. Dead eyes were simply crimped into the chain plate loops.  This is so they can be rotated so that the holes line up perfectly with the rigging.
Regards, Scott
Completed builds:
Gee, that's looking good, Scott. A pleasure to view. Have you made a decision about finishing the lower hull? A lot of Friesland modellers  have painted it white. I really like the natural finish, though.
Cheers Grant. Yes the lower hull will be painted white. More of an off white colour. Thank you for checking in too :D
Regards, Scott
Completed builds:
