Hey fellow Builders!
I've been lurking on this site for almost a year now and I feel it's time to reveal my work... or pile of poorly painted bent sticks. I would like to give my thanks for all the other Sherbourne builders on this site as it has been immensely helpful to see your builds!
I started building this lovely little kit last August and have been working on it slowly over the last 9 months. It would totally be done if I wasn't working so much, I'm a line cook so I get home and most of the time collapse into bed. Anyway I bought this kit after doing some research, it came highly rated for beginners. I still couldn't have made it without the resources on this site or the books I bought. Most kits are just assuming you know what you are doing it seems. The kit was missing the maple wood for the deck so I contacted JoTika/Caldercraft and they mailed some out to me for free!
The build is at the rigging stage... I've been a little stuck there and will probably ask for help. I'll just post these two un-boxing pictures for now and add the rest later in chunks.
58e2c6103795c_Ship1.thumb.jpg.da7f8011a02723d232063eb2e1efb53a.jpg58e2c637c4565_Ship2.thumb.jpg.479e7fc297474cd77304424bcb254990.jpg
Looking forward to this build! You're pretty much guaranteed lots of support because of the large number of people who've built the Sherbourne. Don't forget that when you post a log it's not just so you can obtain support, though. Every builder gives ideas to others as well.
Tony
Keel & Bulkheads
Hey Tony! Yes I hope to steer some people away from my mistakes, also there is there is the fact I have a small work area and lack of tools. I hope that could be some encouragement to some in the same "boat" as me. It's been challenging but it feels good when you make your own tool or jig. Even random household items can be of use.
So My keel was a bit warped and so I soaked it for 3-4 hours and put a huge pile of useless law books on it for a day. That took out some of the bend but what really aligned it was the bulkheads and deck were in place. I did not need to throw it away and start over like one of my books said Ha! I squared the bulkheads to the keel with large binder clips and they came out squared, didn't snap a picture of that step sorry. You can't really tell buy my awful photos but I did cut some rabbeting into the keel before gluing the bulkheads.  In picture 3 & 4 I had everything glued in place and started adding small filler blocks on the bow and stern. I felt it needed some support there but I opted out of using balsa wood to fill most of the hull, didn't feel necessary to me at the time but I would have used less filler on the planking if I had. As long as everything is shaped and smooth for second planking you should be good.
58e2e1e50c42b_Ship4.thumb.jpg.5774354dd491a5ab9b27f4ceff6446b1.jpg58e2e1f5d88e3_Ship7.thumb.jpg.4239651f422914d0c1a247883cabcb5e.jpg58e2e24122b1c_Ship8.thumb.jpg.4566be93a68e8800bc3c63c47b859e14.jpg58e2e24ab4fc0_Ship11.thumb.jpg.77c183e993f37f54cec819696222d326.jpg
Bulwark strips
They looked like they would be easy! The plywood definitely needed a soaking so I soaked the front ends and shaped them around a bowl over night. I made up one of the cannons to check the gun port levels and no matter what I did something was off so I glued them on with the bow section being low. I ended up adding some lime wood strip to the top of the bow and had to adjust 3 gun ports on each side.
58e3e4ad3a8ea_Ship12.thumb.jpg.b87770c3451c21a0e8013882d4831a90.jpg58e3e4cdea2ad_Ship15.thumb.jpg.6f4b8e2e992e896bff39c2be29191707.jpg
1st Planking
I regret gluing the stern post on but didn't really know that it would get in the way at this point, lesson learned. The planking I did was rough and jagged, I figured it didn't mater to much because they would be sanded smooth and be covered with a second planking.
58e3e51f35e71_Ship16.thumb.jpg.15733b3a57d4dd927837ca1975ae0324.jpg58e3e527739bd_Ship19.thumb.jpg.fbffb511536b279ffb3bf94f50ca9adf.jpg
1st Planking finishing up
My carelessness left me with a lot of sanding and filling to do. Also I tried carving the rabbeting back into the the keel as the 1st planking ate most of it.
58e3f9deef18a_Ship23.thumb.jpg.52016e613b7fcaa0d5a5accb0bd055ce.jpg58e3f9e857044_Ship24.thumb.jpg.3043734310d9762bf1c7f8b23828bda5.jpg
2nd Planking
I ran the stern planking level to the deck like the instructions said. I wish now I did something more like the other Sherbourne builders did.
The Binder clips made for a nice smooth run of the planks.
Pulled the bulkhead tabs off and lined the bulwarks with .5mm Walnut because it was easy to bend to shape. Cutting the gun ports and the oar ports to size took a lot more time than I imagined. The walnut is super easy to chip and flake so a lot of care is needed.
2nd Planking trouble
I was trying up to this point not to have a huge gap in the middle so I ran a strip down the middle of it and planked outward from that. That is totally not how a ship is planked or a model ship should be planked!
58e3fac617d1b_Ship34.thumb.jpg.892ff456211e46ff8d8f5589ad0cbac3.jpg58e3fad4e0542_Ship36.thumb.jpg.bb3e0e62b7277484de0287d212edd235.jpg
2nd Planking finished
After a few hours of sanding and a few blisters it looked like this. It started looking pretty ok at this point.
The wales
The wales were a bit tricky to put on. I used a few spots of cyano glue to hold the lateral bend, I didn't know how else to do it. The grainy blurry pictures don't really show it well. I do plan on getting a new camera soon so we can really see how lumpy she is :P
58e56dc261b3a_Ship43.thumb.jpg.29e07f03e0206bb6a03cf4589dffcc33.jpg58e56dc9b4011_Ship44.thumb.jpg.e764d173d7341b6b82e85ac2658b7b5e.jpg
Caprail + Bulwark paint
the Capping rail went on really easy and with good spacing on each side for a lip. I guess I did something right for it to fit like that! I added spricketing along the bulwarks because I liked what I saw on other builds. The paint is some random acrylic I bought a while back and it probably wasn't the greatest choice. Should have bought the admiralty ones. I gave my best try at Ochre red.
Deck planking
I guess I could have used a marker on the edges of the planks for caulking. I regret not doing it but the admiral said she liked it like this. I will definitely get a little more adventurous with my next build in this regard, maybe even tree nailing.
Edited by Duncbe
The Cannons :pirate41:
I saw on some of the older builds that the guns were badly cast white metal but at some point Caldercraft upgraded to turned brass. I was impressed with the carriages to but I did add a tray for the quoin. I could have kept the wheels natural but they were so hard to sand down to make them look nicer.
58e57cd96e643_Cannon1.thumb.jpg.46561f80c801ffb5d761e71755631e95.jpg58e57ce1421c9_Cannon3.thumb.jpg.05ee1ad130c79db90c49a2117b19b10d.jpg58e57cf8ee355_Cannon6.thumb.jpg.7cb76f97ad7e050a55b9e1392c061292.jpg58e57d0a593a1_Cannon7.thumb.jpg.4e607896f7c3336ea324136a0505f698.jpg
What a little gem. Your doing a beautiful job of her. Well done. Your cannons look spot on. Will these be fully rigged?
Regards, Scott
Completed builds:
Awaiting construction:
Thanks Scott!
I put breaching rope for this build. I'm definitely going to do it on my next build though.
Anchors
The kits anchors were a fun little side project. I don't know if my pudening is right but I like the way I made them look tared up.
Deck pumps
I removed about 3mm from the end of the handles as they just looked over sized for the kit. They are still a bit monstrous. The kit told me to use 4mm dowel for the pump stand/pipe it seemed realy small so I ran some strips around it and made and octagon shape, its probably not realistic.
Breaching rope
I did my best I swear! I had glued the guns to the deck before I realized I should have made a jig to get all the rope the right length. So there all a little bit different, I'll live with it. Next time I'll do it to code ;)
Up to date progress
That's where she is currently. I'm working on the mast and booms.
Absolutely beutifull  and a pleasure to follow your build very neat work , I think think your correct on the pumps adding the hexagon effect also great build lovely pictures
Stern Fascia
I chose to stick with the photo etch letters that came with the kit. Getting them on there with an even curve was hard to say the least, shaky hands sweaty palms. I used fine grit sand paper on them and used satin varnish and liked the results.
These Pictures are with a proper camera I found in the house. I'm working out how to use the old thing... might be making an investment in a new one on my next build.
Mast & Yards
I chose to paint the mast and bowsprit yellow ochre because I didn't like any of the stain I had. learning to tie blocks was a lot of research. The footrope on the lower yard is going to be reworked (the plans are rough in this regard) I will do them up proper.
Lower yard
I changed what the instructions told me to do and I added 4 small eyelets to the yard for the footrope. I Think they would have been rope but I cheated and used the eyelets, I think I've seen some like that on other builds. Tying all of these little lashings and knots is quite time consuming, fun though.
Bowsprit positioning
I've held the ship up to the plans to see if the angle is right but it seems too low maybe? I don't think I will be gluing the mast or bowsprit in as all the rigging seems like it will do the job of holding everything down, There is a discussion in another thread on this site about it and it seems quite normal.
Duncbe what part of the world are you from if you don't mind me asking I see a few things in the background like your clear plastic storage container and the paint brushs that look familiar to stuff I have
Hey Steve, I'm from Toronto Canada. I bought the stuff from around here. I suppose you get similar stuff in Ireland.
Oh wow that does look like my stuff! how about that eh?
Rigging the Shrouds
Instead of tying a knot around the deadeye I used a tight lashing that could be shifted to get the right positioning. I used 1mmx5mm lime wood strips with pins in them for holding everything in position. Not quite sure how else to do it really.
Yellow Ochre at last!
My snake arrived and with it the paint set and some extra paints I bought. The Snake kit I received was amazing, so much stuff and the wood strips were smooth and well milled but I'll save the rest for its build log. I plan on giving my mast and bowsprit a splash of yellow Ochre to take down the awful yellow/orange I currently have. It is quite off putting at the moment. Another option is that I could take off the yellow with paint remover and use the walnut stain I got with my delivery. Decisions to be made.
a little friendly advice I hope its not to late but from your pictures it looks like your jig is holding the deadeyes incorrectly and maybe someone will correct me if im wrong but I have done mine in the past with the top deadeye as yours sits and the bottom one with two holes to the top and one at the bottom if that makes sense
Hey Steve.
I was following the plans I should definitely look into this.  Thanks for looking out!
Steve's correct about the deadeyes. I thought the plans had shown them correctly, as well as how to thread them. Nice work, though.
Tony
Hey Tony.
Yeah the bottom deadeyes are upside down atm because my jig wont fit otherwise. the channel doesn't protrude far from the hull and the pins were hitting the capping rail. They are not glued in so they can just be spun around when it comes time to tie the lanyards. Thanks guys!
Hi duncbe I hope I haven't caused you too much hassle you have a buetifull build and I'd always like people to point out anything I may have missed that snake kit looks fantastic also I've considered myself for a next build I was looking about the other logs for an Unboxing log but couldent find much in the logs if you can include that in your new build log when you start it that would be great
thanks
steve
Hey Steve. It's not a problem when people point out mistakes! I will definitely post unboxing pictures of the Snake as there has been a lack on the other builds. I can't wait to get onto that build that's for sure.
Mast & Bowsprit repaint
I left a bit of the old paint for comparison and you can see my "yellow ochre" attempts were just miles off. After some research this is what was used on the Victory in 1804 and is whats painted on her currently since 2015. I like it on the the Sherbourne as you can see in the bottom photo. Just fits in nicely I think.
It's a strange color to be sure. In some light its peach and some light its pale mustard. Has anyone else bought this stuff recently and seeing the same?
58ee7e4592376_Ship71.thumb.jpg.12301d354b768c5a9da9c4b8be1791b6.jpg58ee7e50c6b1f_Ship72.thumb.jpg.cadfec9cecac6d2a28314734d9c414eb.jpg
Standing Rigging
Working on the backstays then I'll work on the forestayes. I've been putting "lashings" on almost everything as simple knots just look ugly and out of place. I've run into a bit of a snag in the second picture. I don't really know if I belayed the rope right and what to do with the end of it, make a pool of rope on the deck or make a hoop of pope around the cleat? I should have bought a book about this rigging business. The instructions are lacking in this regard and make it seem like all the rigging can be done in an afternoon... maybe I'm over thinking things.
58f3e571df4fb_Ship75.thumb.jpg.b426a4aa84899a1767df1ae1833be777.jpg58f3e5773fb70_Ship74.thumb.jpg.75ef04212f6906a91a2ca3047a53bc86.jpg
Mouse
I made the Mouse with a small piece of dowel, glued it on and wrapped it with fine black thread. Not quite the shape I was looking for but it will do fine.
Mast & Bowsprit stays
I've been cursing at these little strings for days now and after some reworking and getting the right amount of tension I think there done. I've followed the plans for the most part though I did add another "bowsprit stay" (I don't know what else to call it) that is attached to the cutwater. The forestay for the mast is also done and tied, The lanyard is a bit rough but I'll leave it.
58faa3ef72608_Ship76.thumb.jpg.def63d254feecc9839b3e193f20282f1.jpg58faa40fdaab1_Ship77.thumb.jpg.5774f3895e500f34798ad58262218712.jpg
The view looking down is my favorite. A sailor would scoff at me most likely...
Rope Coiling Jig
I'm currently playing around with this jig to make some rope coils and there just looking wrong. In the second picture below you can see my "attempt". I've seen some rope coils that are tied in the middle but I don't if that was done back in the 18th century. Also I don't really think there would be rope terminating on a windlass would there? Anyone have ideas about making nice looking coils?
58faa43a7e925_Ship82.thumb.jpg.72e50a041547fe2b3d79b0219c91ca8b.jpg58faa446b84c9_Ship83.thumb.jpg.94885d69a75ab161d3c23f394636b93d.jpg
