Sorry, but I've discovered it is the the small things that impress the most.
You get 90% of your audience with the magnificent looking sail. The another 9% with the two holes... we were told about them!
There is still that 1% out there... those real sailors that see everything.
I'd be impressed to see those holes with the rope grommet sewn around them 😏... a challenge for you!
Alan O'Neill
Quote
Alan, I'm pretty sure that Greg chuckled while reading this, considering my OCD...  😊 I'll see what can be done about the holes...
cheers!
Denis
In Progress:             HMS Pandora 3D modeling
Finished Builds:       Swan Class HMS Pegasus for Admiralty Models 3D Build
                                German Type VIIC U-Boat 3D model
My other 3D work:  Artstation
Excellent!
BZ
Alan O'Neill
hi all. just wanted to post a small update. getting sizes and proportions of staysails at the moment. next is making textures and then puffing them up with the wind, and only then come digital ropes again...
cheers!
Denis
sails and materials are done (-ish)... now I need to shape them and tie them down...
cheers!
Denis
hi, all! the jibsail is done. it's getting a bit crowded with all the ropes up there... ;)
cheers!
Denis
Fore Topmast Staysail is done... at this point the ropes are criss-crossing each other in a very unrealistic manner. if you spot such rope, please ignore, because unless I do a full simulation of all ropes and sails at the same time (pretty much undoable at this scale), there's no way around it.
cheers!
Denis
The Fore Staysail is done. onto the middle staysails... and a couple of ocean renders, because she looks beautiful with sun behind the sails...
cheers!
Denis
hm, it seems I've hit a snag. I've put the main topmast staysail in place but there are a lot of lines that get in the way. I can't seem to come up with a satisfying solution to the problem. where could I actually squeeze said sail where it wouldn't interfere with other lines? please, help.
Edited by herask
cheers!
Denis
it's a shame that ropes are getting in the way. the sails are looking really impressive as they are right now.
come to think of it, was this sail setup even used back then? what was the most common configuration of sails? maybe I could omit some, instead of going full throttle?
cheers!
Denis
Add additional vertices to your pin group, or just bite the bullet and set up the ropes as collision objects - that's what I did.
I hate to say it, given that the rest of your model is so impressive, but to my eyes your sails are a bit of a let down. The textures and subsurface effects are good, but they don't behave like real sails.
Here's a few tips:
  • Make sure your sails are high poly (remember to use simple SS, not catmil-clark) and add the solidify mod after you run the simulations
  • Run a different cloth simulation for each sail, or at the very least, apply the physics simulation at a different point on the timeline for each sail
  • Animate the force field - real wind is not constant, changes both direction and speed.
  • For extra realism, I added a low value to the verts in front of the bunt lines so that the sail billowed out around the lines somewhat. Note that this will require you model the ropes on each side independently (no more mirror mod, sadly, but the result is worth the extra effort.
  • Finally, consider modelling the course sails as furled, Not only will this add to the realism, It also allows more of the actual ship to be seen in renders
Edited by 3DShipWright
thank you for the tips! I did try full sim on sails but it all got weird. sails would clip through ropes, or even stick to them like glued for no apparent reason... I'm aware that the sails are somewhat simplified affair but in all honesty that's the intention. as much as I would like to engage full cloth sim on everything I've decided to skip that step for the sake of my sanity :D. will try and make furled courses, though. the initial idea was to make three states for each sail: fully set, half furled and furled, so I could cover all sail deployment(?) scenarios. but, again, my sanity...
what actually halted my progress here is that I don't know where to squeeze the staysail between all these lines. full sim or not, I can't see how the sail actually fits there...
EDIT: by the way, when I was looking at your post on my phone I had to squint to really notice that your renders aren't photos. that blender gizmo in the upper right corner gave it away. great work!
Edited by herask
cheers!
Denis
hi all!
first, I wish all the very best in New Year to everyone. may it be full of great ship models, especially finished ones :)).
and second, I think I'm finally calling this project - done! I haven't finished all the fore-aft sails since I can't figure out how to physically put them in place without intersecting with various lines there. so, with mizzen course done I put an end to this great journey that started almost seven (yes, seven! yikes!) years ago. thank you all for pulling up chairs and being a part of this endeavor. and the biggest "thank you" to David and Greg for for making me a part of this endeavor, as well. I have learned a lot, have a lot to learn still, and right now I'm going to sit down and try and decide what to tackle next. for now, finishing Pandora seems most likely candidate, but more on that in due time.
thank you and cheers!!
cheers!
Denis
