First of all, i'll try to put again all the ideas and photos i have, from the old site.
Sorry to hear that you lost everything.
Here is a new "tool" i made from an old Hard disk
It is a simple "disk sander". You have to use an old IDE hard disc and a power supply from old computers
You can add any type of sandpaper, and glue
I have prepared some discs with 100, 150, 180 and 220 type of sandpaper
The top picture is an example of the force of this disk sander
The bottom picture is how it is made, and a second Hard dirive (SATA) type prepared
Al the best to all
Cristi
Current build : Sovereign of the Seas - Mantua 1:78 scale
Finished:        San John the Baptist - Cross section
                    Santisima Trinidad - Cross section                  Galery Santisima
                    San John the Baptist ( San Juan Bautista)    Galery  San John
                    HMS Victory 1805 - Cross section - Corel 1:98 scale
                    Panart (Mantua) 740 Battle Station          Battle Station Panart 740 Galerry
On Hold:        HMS Bounty 1:64   Mamoli MV39
If you want to use an ATX power supply you have to make a change in such a way that the power supply will start
1. connect pin 16 (Green in the schematic) to anyh ground (ex:15, 17, 18 ...)  - Version 2.0
or  pin 14 to 13, 15 ... on Vers 1.0
2. use a switch between these pins (16 - 17) to make an ON-OFF if you don't have a switch to the power supply,
because on some types the switch is on the computer board side
Hi Hrvoje
It is not very strong, but is good for small yhings, as we are doing
In the picture there is an example of what i do with this
Cristi
Now THAT is creative AND practical!!!   Nevermind the cool factor as well.
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
maybe if some sort of enclosure, with work top, so the whole thing could be sitting on its side... i have one dead hdd here, i could also try that... how bad does it heat up? what about amount of dust it create?
Pavol stands for Paul, Pablo, Paolo etc. Please do not try to pronounce it, just call me Pav...
Maaalo, this is the type of hard disc i had spare. I'm working to some new one and some adjustments
It will have one of them an enclousere. It is not heating to much, and for what i used, it did not make to much dust
I will come withe the new photos when i will finish the sander
Cristi
In the picture you can see how much dust it is on the table, after i worked to one cross section
