Thanks David
My nightmare contimues.  I made a big rookie mistake with the gallery glazing as it has clouded over due to the CA fumes to I've had to take the gallery off and start again.
I know whart you mean about matching the brass profile - I think I'm going to have the same issue....
Cheers
yon
Hi Yon yep i had same prob with windows in the end i took them out not only did they mist over they gathered so much dust to be useless as for cleaning them i found it was more trouble then they where worth,hoping to resume some work on my Vic now    DEREK     :pirate41:
for the brass profile,on the stern i am going down the route of using a plastic strip layed flat against the hull, and one at 90 degrees to it to form a window sill, - well that is the intention at present -  yes i have pinched the idea from Gil, but looking at the photo's of the real vessel, there is a defined sill under the windows that wraps around the galleries that cannot be obtained through the brass profile alone
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi Guys
Good to see you back Derek, I think I'm now OK with the windows I just have to watch the CA. Kevin, I agree about the sill (see the bottom picture below) although on my model it will have to be a very specific angle to get it at right angles to the hull as my stern is sloping inwards at that point.  I might experiment with wood strip instead of styrene as its easier to work with.
Overall I'm still having a very hard time with the galleries.  Mainly because I messed up the profiles right at the beginning. My errors are compounding as I work downwards and I haven't even bothered with the bottom skin, I just filled the gap with filler. Still I think I will get there in the end and then start all over again on starboard.  Here's some pics - not very pleaseant viewing I'm afraid....
post-464-0-89914700-1367481396_thumb.jpgpost-464-0-16097100-1367481407_thumb.jpgpost-464-0-03436200-1367481417_thumb.jpgpost-464-0-35044900-1367481429_thumb.jpg
and this is what it should look like
you could always contact jotika and ask/purchase replacements, whats the worst they are going to say?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Good suggestion but the problem is really with the profiles and to replace them properly I would have to take the whole stern off.  I'm having to mess around with the skins to get them to fit the profiles.  If I succeed, I don't think you will be able to tell that the profiles were wrong. Its hard but I think I can see light at the end of the tunnel.
Cheers
Yon
Hello yon
I don't know if this will help as I cannot tell what is actually going on, but to tidy things up, maybe you could use some marquetry
Sheeting in places as skins, which is easy to work with. I used it on both the upper and lower counters to tidy them up and it's easier and quicker than planking . As Kevin said give jotika a ring and tell them which sheet you need. They will definitely send you one no prob. Ring them now. DAVID
Hi David
Thanks for that but I think its going to be OK once I clean up the painting and put on the decorations.  I've cleared my diary for the next 5 days to tackle these !
I like the marquetry idea generally though so I've placed an order with amazon to add to my box of materials.
Cheers
Yon
if you ask for the profile and the platforms, you will not have to remove the strern, just sand down to the original hull, find the location slots are rebuild  from there, soak your existing profiles to remove windows
the worst jotika will say is - no can do
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
You're right, thinking about it - I wouldn't have to take the whole stern off.  I think I'm going to finish off the port side and see whether I can make a decent job of it with paint, sandpaper and filler.  If it doesn't work I'll try Jotika and strip down the patterns. If they won't replace them I think I could make some up without too much difficulty
I should be able to post some pictures later today and go from there.
Cheers
Yon
A quick update....
I've managed to complete the port side quarter gallery except for the brass profile which hopefully will cover up more of the mistakes. Its not going to win any prizes but I'm reasonably happy with it considering what it looked like this morning.
that's a good recovery - well done
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hello yon
Well that looks ok to me. Only the edge of the facia needs tidied and you've cracked it, well done yon. Post some more photos as you
Complete it. DAVID
Thanks guys for your help and comments.
Now doing the starboard side and its much easier now that I know how to fudge it !
Cheers
Over the last few days I've finished the quarter galleries including a shelf along the stern.  I did not put the lowest of the copper profile around the quarter gallery - it just looked too big so I used a strip of wire instead.  I don't really understand how the kit designers expected the stern profiles to be done according to their instructions.  For me it was a case of improvising and experimenting.
So that's the stern finished for the time being.  Next I made up the bulwarks and capping rails for the poop deck.  I now have the flag lockers to do although I am missing the sheet to make up the internal part for one of them (I think Derek had the same problem).  Fortunately I was going to cover one of the lockers in canvass anyway so no delays while I wait for the part.
Some pics...
post-464-0-98869900-1367917772_thumb.jpgpost-464-0-89888500-1367917784_thumb.jpgpost-464-0-76721700-1367917793_thumb.jpgpost-464-0-31825000-1367917804_thumb.jpg
Yon
Well done it looks excellent. It was me who had the prob with the lockers. I phoned caldercraft/ jotika, and he knew exactly what I was going to say when I mentioned the lockers. There was a fault on production, and the sheets were getting cut in half. Just ring them, no prob. Mine was sent out, and I received it a day later. Yes it's looking really smart now. I bet you are looking forward to the gunport lids!!!! Not!!!
I have my last 38 ready to fit, starting tonight. Well done you , keep up the good work DAVID
Thanks very much guys.
David - I was intending to cover the lockers with material. I bought some tissue-like stuff which was referred to in Kevin's log about making sails (can't remember what its called). Then I was going to cover one completely and have the other one turned up a little showing the flags underneath so I should only need the internal part for one locker.  That's the plan anyway - if it doesn't look very good I'll phone Jotika.  Good luck with your lids - I'm certainly not looking forward to those !
Cheers
Yon
Edited by Yon
A very quick update as I don't think I'll get much build time over the next few days.
I've finished the flag lockers with one showing the flags and the other with the canvass cover on.  I'm reasonably happy with how they turned out although it was a bit time consuming.  I then finished off the poop and made a start on the poop ladder assemblies.
Pictures:-
post-464-0-20593200-1368200798_thumb.jpgpost-464-0-95309700-1368200810_thumb.jpgpost-464-0-75600500-1368200827_thumb.jpgpost-464-0-09668700-1368200840_thumb.jpg
Thanks Derek
The decision to cover the locker saved me about 8 hours !
Cheers
Yon
Hello yon
Yes the lockers are really good. An excellent idea, well done yon. Things are looking really good. Keep up
The good work, and enjoy the stairways. DAVID
Yon,
    Excellent work on everything you have done, your detail work is Beautiful. Keep the pictures coming, I am always watching.
Wacko
Joe :D
Go MSW :) :)
flag lockers look great, what did you use for the flags themselves
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks Kevin
I ended up using "modelspan" tissue which I discovered on the pdf about sails which is linked to your log.  Originally I thought to use it to cover the lockers but its too thin.  I cut out a rectangle and then folded it several times using a pin to make the crease and then dipped it in a little PVA to hold it in shape.
Cheers
Yon
are the flags just coloured paper?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
