Hi.
This is just going to be a fun build while getting the drawings for the Gondola done.
The design comes from a district called Mandalay. In centra Burma.
The only thing I have is the video.
As you can see by the video it's  a very long boat that is quite simple.
The model will be 100cm in length and made from anything wooden I can lay my hands on.
https://m.youtube.com/watch?v=_9oJErubzfY
I have made a building frame as the boat has a curved base from bow to stern and also a curve across the section.
Have just put a Pdf file of my drawings.
Myitkyina.pdf
Jig above is cheap plywood.
Bow support and clamping above.
Stern support and clamp above.
Shot from above to show the length of the boat.
The floor just laid on the jig.
I will try and build this as the video shows with internal supports and joint covers.
The reason why the scale... I can purchase a plastic model car engine and mount it on rear bulkhead. With the extended shaft and propeller.
As I have said... It's a fun build...
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Antony,
a great intermediate "filler" project......
Iliked the U-tube video,....those guys working with simple tools, and still its a full worthy boat for fishing etc....
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Hi.
Another couple of photos.
First side planks in position and glued.
The supports are working a treat as the angles of the bulwark's are spot on.
The shape of the boat is such that the planks just lie without forcing them into place.
Floor frames and side frames will be added after transom has been fixed.
Regards Antony.
Extra supports will now be added to support the upper planks when I attach them.
Completed Mayflower
Antony,a fun build it may be but it's also a build of an unusual vessel. Watching the video brought back memories of when the Wife and I lived in Thailand. Used to see these Long Tail Boats regularly on both the Mekong and Chao Phraya rivers. They are a common design in S.E. Asia I believe,will be following this build.
Dave :dancetl6:
Edited by davyboy
Another update
Just the half planks to fit on the Bow and Stern. And the planking is finished.
Then it's the ribs to be added. 30 of them. And transom.
Photo as it is now. Stern first.
Then the Bow area.
And one looking from Bow to Stern.
Another update mid week.
Regards Antony.
Completed Mayflower
Very interesting model. Will you be placing some figures to represent the driver and a passenger?
You sure went to great extents to build this jig. It seems like it is almost more work than the model itself.
Yves
Hi.
Thanks for the likes.
Yves.. yes I have a few figures that fit the scale. Also have a model engine that will fit onto a frame that will sit on the transom.
Regards Antony.
Completed Mayflower
Hi.
A few more pictures on the progress.
Have put in all the ribs and bow nose.
First the centre section looking towards the bow area.
The hull with vernier to give some idea of its length.
The bow area.
And the stern area.
I will post the drawings that I have made for the tail boat when all's finished.
Regards Antony.
Completed Mayflower
Hi.
The tail boat is now complete. Car engine still has not arrived. So no photos with the engine mounted with shaft and prop.
The scale works out to be around 1/16. That would make figures for a 6ft person would be 114.3mm high and a 5ft person being 95.25mm high and not forgetting the 4ft person would be 76.2 high.
Does not match any figures that I have at this time.
Full length of the boat being 1010mm in length and 125 beam.
The Bow area
And no I don't like the brass pins..But I have excess of then and need to use them away.
Not going to paint , varnish or oil this boat.
Thanks for the likes and comments.
I have put a pdf drawing on the first post. Should anyone be interested.
Regards Antony.
Completed Mayflower
