My kit arrived yesterday. I had already committed to working on a repair project at my church but I did have time to gaze lovingly at the contents and conduct an inventory. Everything was there and it looks (and smells) great. I hope to get started today after work.
v/r,
Rob
Edited by rjones726
Current build : Triton cross section 1:48
Well I guess my build is underway. I began by using a set of digital calipers to measure the width of the keel. I then divided by 2, set the calipers and made a faint mark on the charred sides of the keel pieces at the scarf joints. Using those marks as a gage I began to cut and file my way down. As I got close I began using the calipers themselves to check for high spots. I'll glue them up once I run to the store and grab some titebond. I followed Chucks advice to take my time and not settle-make it fit. I'm pretty happy with the way they turned out. For anyone following along I'll warn you, my photography skills are rudimentary at best and all I have is an iPhone. Maybe that's another area I can improve as the build progresses. Any and all comments and critique is welcome.
v/r,
Rob
Edited by rjones726
spelling
Nice start Rob.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
I haven't posted in a week or so- it's time for an update. I sanded the stern keel sections to achieve a 1/32" rabbit to accommodate the width of the planks, Everything went great until I decided to dry fit the transom. I sanded the entire stern keel section such that it didn't fit snugly in the laser notch of the transom any more. Of course I waited to check this until after I had glued the stern keel section onto the keel. I debated trying to use alcohol or some other method to try to get it off but in the end I decided to start over using the simplified keel. This time I was careful to only sand the lower portion and leave the upper part alone.
The transom fit the way it was supposed to and I am pretty happy with the result.
I have been taking my time assembling the frames and working on getting them to fit snugly into the build board. Next task is to get a good fit of all frames in the keel notches. I am sure there are other folks here who are as inexperienced as I am. Hopefully by talking about my mistake, someone reading this will avoid my error.
v/r,
Rob
Rob,
    Is the top picture the old keel assembly or the new?  The center notched section appears to be a little off-center.
    When inserting your frames into the build board, make sure they fit snug.  You don't want them moving around during the build.  I found that out while building the Queen Anne Barge.  On the other hand, don't make it too tight or else you might break something trying to get the hull off the build board later own the road.  Sand the frame ops down so they are snug but not too snug.  If you over-sand, use some blue painter's tape to snug it up (see Chuck P's build log),
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Hi Chuck. It is the new keel. I sanded the center keel piece (with notches) after it was glued on to match the stern pieces. I took the photo before I did it.
v/r,
Rob
You can actually still use the first version.  It doesnt matter a whole lot that it doesnt fit snug.  The inboard side will be painted red.  It will be fine.
Chuck
Chuck
Thanks Chuck. Lesson learned.
  • 1 year later...
