OK folks, I think I finally understand what my problem was.  I needed to do a new post every 10 pictures instead of going back to my original post and editing it.  I'm going to see what happens now.
Mar 17
post-545-0-54699700-1367356124_thumb.jpg  Bow view of finished first hull planking  post-545-0-92794800-1367356144_thumb.jpg  First hull planking completed  post-545-0-45992900-1367356160_thumb.jpg  Stern view of finished planking
Mar 18
post-545-0-61765300-1367356186_thumb.jpg  Beginning starboard side quarter galleries
Mar 19
post-545-0-42060400-1367356204_thumb.jpg  starboard side quarter galleries in progress
Mar 20
post-545-0-11805200-1367356237_thumb.jpg  Stern work almost finished
Mar 21
post-545-0-25449400-1367356268_thumb.jpg   post-545-0-25181600-1367356354_thumb.jpg Port quarter galleries built up
Mar 23
post-545-0-32864300-1367356298_thumb.jpg  Half of middle gun deck planked
Edited by Jerry
Ahoy Jerry :D
WOW
Are you sleeping
The instructions say 2500 to 3000 hours to complete this build
Somehow i do not think this will apply to you
She looks great :)
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Ahoy Jerry :D
WOW
Are you sleeping
She looks great :)
The modeller sleeps, and process goes...  :)
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
well done
For a good start to the build
and overcoming the posting issue
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Jpett..
I hardly sleep but believe me when that happens I play on-line poker and give the ship a break.  LOL  It feels good to know that I finally figured this posting thing out.  Thanks for your support..Jerry
So now I will bring this log further up-to-date:
Mar 25
post-545-0-15386800-1367357461_thumb.jpg  Side entry port sills installed  post-545-0-25214400-1367357478_thumb.jpg  Close up of side entry port  post-545-0-11350300-1367357497_thumb.jpg  Middle gun deck planked and varnished
Mar 26
post-545-0-82271200-1367357545_thumb.jpg  Deck area between barrel strip and ship side painted black matt
Mar 27
post-545-0-46232100-1367357560_thumb.jpg  First two rows of second hull planking
Mar 29
post-545-0-38874700-1367357616_thumb.jpg  Bow view of second planking continuing   post-545-0-69314200-1367357643_thumb.jpg  Rear port view of second planking continuing
Mar 31
post-545-0-90408100-1367357706_thumb.jpg  Hull after 4 mre plankson each side    post-545-0-18384900-1367357737_thumb.jpg  Stern view with up-to-date planking
Apr 1
  post-545-0-00790300-1367357879_thumb.jpg   The second planking keeps growing
Edited by Jerry
Greetings Jerry
Good to see you have got your photos sorted, so now you can get on with your build. Everything is looking good, keep up the good work and keep the photos coming. Regards DAVID
Hello David...Nice to hear from you.  Yes, thank goodness, I finally understood what to do.  It took a lot of prodding by several patient people and I'm on my way.  I started to line the ports today and managed to get two finished. I believe this stage is the slowest part of the buildso far.  I'm going to try and bring the log to where I am at this time.  Have a great evening up in the North there.  Jerry
Well, I only have a month of progress to go..so here it comes....
Apr 2
post-545-0-93937000-1367359407_thumb.jpg  About two days to go to finish second planking  post-545-0-63329700-1367359448_thumb.jpg  Second planking moving along
Apr 3
post-545-0-74878600-1367359481_thumb.jpg  Second planking finished on starboard side of the hu;;
Apr 4
post-545-0-50564600-1367359506_thumb.jpg  Second planking of hull completed
Apr 5
post-545-0-27415500-1367359544_thumb.jpg  Last look at middle gun deck before upper gun deck is installed
post-545-0-05103900-1367359623_thumb.jpg  Hull sanded and keelson and stem post added
Apr 7
post-545-0-45258300-1367359648_thumb.jpg  Beginning to run second planking upwards  post-545-0-15319200-1367359677_thumb.jpg  Continuing planking upwards
Apr 9
post-545-0-55769700-1367359709_thumb.jpg  Upper gun deck and inner bulwark patterns added.  This was my first thought that things were getting difficult.  I kept my fingers crossed as I bent the upper deck horizontally to try and get it to fit over the bulheads. I was sure I was going to split it.  I managed okay but did break a couple of tabs squeezing the deck into place.  These were easily glued and as it turned out, one doesn't ever see this part of the deck when the inner gun patterns are in place.  The inner gun patterns took a lot of sanding at the bottom to get the gun ports of the inner and outer paterns to match up.  But I kept going and finally everything worked out.  Thank goodness for my mini belt and disc sander
Apr 10
post-545-0-82916400-1367359740_thumb.jpg   Planking the upper gun deck
Edited by Jerry
Well, I don't have much more to go so I'll forsake dinner and get this thing to where I'm presently at:
Apr 10
post-545-0-81463900-1367361800_thumb.jpg  Planking upper gun deck
Apr 12
post-545-0-66213000-1367361892_thumb.jpg  Uppergun deck lanking ready for sanding and varnish
Apr 15
post-545-0-30783000-1367361915_thumb.jpg  3rd to 10th gunport lined on starboard side  post-545-0-39902600-1367361930_thumb.jpg  Closeup of lined gunports
Apr 17
post-545-0-66219300-1367361974_thumb.jpg  Beginning the lining of inside bulwark pattern
Apr 18
post-545-0-61381200-1367361989_thumb.jpg  Bulwark walls finished
Apr 19
post-545-0-23198200-1367362044_thumb.jpg  Hull planking begins going upwards again
Apr 20
post-545-0-64413700-1367362077_thumb.jpg  Planking temporarily suspended
Apr 21
post-545-0-46200100-1367362115_thumb.jpg   Inner gunport sides are painted yellow ochre
Apr 23
post-545-0-49043000-1367362156_thumb.jpg  Wales are finished   post-545-0-05814800-1367362188_thumb.jpg  Closeup of finished wales
Edited by Jerry
The following will bring my build up-to-date...........  I would like to acknowledge  Shipyard Sid  (David) with a very special thank you for enlightening me about the balsa lining seats.  They are not in the instruction manual so I was very lucky to hear about this method from David.  Thanks again, David....
Apr 25
post-545-0-14784900-1367362972_thumb.jpg  This is the tool that I used to place the balsa seats that will support the gun port linings.  It is made with two very small fish hooks which turned out to be perfect.
Apr 26
post-545-0-42191900-1367362989_thumb.jpg  Balsa seats after being trimmed   post-545-0-87848800-1367363003_thumb.jpg  Closeup of gunport with rough balsa seat
Apr 28
post-545-0-88871800-1367363018_thumb.jpg  Another closeup of a couple of balsa seated gun ports  post-545-0-49438100-1367363030_thumb.jpg  Balsa seats completed in all gun ports
Apr 29
post-545-0-49438100-1367363030_thumb.jpg  Both sides of hull painted yellow ochre
Edited by Jerry
You are doing a great job. Keep those updates coming. One question, what size were the fish hooks you used for the gunports?
Thanks,
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Sorry, Mort.. I have no idea.  I bought them a long, long time ago.  They were snelled hooks and I cut off the  leader.  They are a just a drop leass than a quarter of an inch or about 5mm in diameter.  Check out the pic of the tool on my site and notice the relationship between the tool and the American dime.  Hope this helps you.
Jerry
Hello Jared..
Thank you for your pleasant note.
I need sleep!  LOL
I can't believe my misunderstanding of how to post but, as you said, I finally got things worked out.
I appreciate friends like you.
Jerry
And I learned something new, thank you.
Respectfully
Your Victory is looking really good, Jerry!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Thanks trippwj...Nice of you to make a complimentary comment.  FYI, I too have an autistic son who is now 58 years old, living in a great facility and still has never spoken.  He was diagnosed about 55 years ago.  He seems happy, takes care of himself, manages to work easy tasks and I daily pray for him.  I understand your feelings very well;  thank you for the avatar.
Jerry
Edited by Jerry
No problem Jerry. I appreciate the picture. I am going to need that tool when I build my Victory and your pix and Sids will be a great help when the time comes to make my own.
Thanks,
Mort
Hi Derek...Thanks for your compliment.  I appreciate your comment as I have visited your log many times, watched your progress and learned a lot.  I  got the idea for the fishhook tool from your log and from David's too.  Your  log is  one of a handful that helped me make the decision to start the Victory  Thanks, again...Jerry.
Hi Jerry,
Thanks for the offer, I am sure I will take you up on it. I am a few years away from my own Victory. I am building the Snake and hope to build the Diana before going on to the Victory. In the mean time I am monitoring all of the Victory builds and taking lots of notes.
Mort
I've been quiet for a couple of days...all work and no play.  I found the last construction to be the hardest so far, lining the gun ports.  But I kept on trying and thanks to David's idea of making balsa seats for the lining, I finally finished the starboard side of the ship.  Here are three images of where I stand as of now.  It'll be back to work and if all goes well, and with today's experience under my belt, I hope to complete the gun port lining by tomorrow evening.
May 7
post-545-0-27100000-1367964480_thumb.jpg   close up of gunport linings
post-545-0-19547900-1367964538_thumb.jpg   a little longer view of the gunport linings
post-545-0-29182700-1367964564_thumb.jpg   Full view of starboard gunport linings
So until tomorrow or so...
Jerry
Edited by Jerry
Greetings Jerry
Yes your linings are looking good, and you will have the port linings finished tomorrow !!! ?. How much time are you spending daily on the build? What are you going to do when the linings are finished?? I surmise you will be looking at the copper plates. Anyway well done, keep up the good work. DAVID
Hi David, good to hear ffom you again.  Most of the linings are already finished.  I only have to do the 9 upper deck gun ports on the port side.  Thanks for your encouragement and to answer your question, I work on the ship about 5 hours a day and relax to join my wife in the evnings.  She's very much younger than I am and is an 8th grade school teacher here in Naples so I can't spend any time with her during the day anyway.  After the linings are completed I will touch up the yellow paint on the inside gunport wall where I trimmed the excess gunport lining.  I also need to go back and paint the top gunport linings that are not recessed that were finished earlier.  I also have some filling and repainting of the hull to do and then I'll probably paint the black bands to be followed by coppering.
Take care...
Jerry
Edited by Jerry
Jerry
are you going for the kit tiles or copper tape, , yr build looks great, lol -
i wish i had 5 hours a day spare, managed 4 hours during the whole of last week
all the best
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
