coming to the end of my 1/72 build of the Victory, and i was asked a question about it on another site,
"how did 18th century sailors know what rigging went where"
subject to the masters fine tuning, if two identical ship were built would each line go in the same position and tied off at the same point
how were young sailors taught this as i quess very few could read
so basically he is asking how would a young sailor know what rope to handle if told to do a specific job
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
"Rigging Period Ship Models" by Lennarth Peterson shows deck belaying plans. There were standards to follow like most things in the navy at that time which could be modified to fit the needs and peculiarities of individual vessels (example- bomb ketch).
What Spyglass said.   However, captains were free to change the rig such as belaying points, angles of the masts, etc. to maximize performance.
Whilst there was a degree of standardization, the bosun (I think, may have been another non-officer) and sailing master had great leeway with where running lines terminated (belaying points), obviously within the physical constraints of the vessel and total rig.
Once the landsman learned his way around the vessel, including the riggong, he would "test" for his next rate.  If moving to a different ship of same class, there was a shallow learning curve.  A different class or size, though, could be quite different.
There are no references (official or otherwise) from the period which I am aware of that specified the precise run for a line, but rather specified diameter, blocks, attachment points at fixed end and so forth.
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Almost half the time, the rigging was handled in the dark.  Crew was open to change at every port.  Their nationality was varied.  Navy crew altered.
In severe weather the lines were handled under real stress.  There was every reason for having which line was where be as standardized as possible.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
A certain standardisation and composing gangs of men of different levels of knowledge and experience. Most parts were too heavy to handled by one sailor alone, so one would group experienced and unexperienced sailors together. Experience comes very fast with the nine-tailed cat being around ...
There were no formal qualifications and exams for sailors of non-officer grades. They were moved on in hierarchy, if their superiors were satisfied with their qualities.
