I am starting a build log on my fun project to rebuild the famous Dutch War Clog, the Nulli Cedo (« I will not budge »), also known as «The Menace of Medway».
More about her history later.
I am also building HMS Bellona but in stead of waiting for glue or paint to dry I might as well stay busy.
I started with a very small clog which was absolutely inadequate to show the fierce appearance of these redoubtable sailing fortresses. So I took a size 5.
I am going to build a main deck with the usual clutter, a quarterdeck, two "inner gun decks", a balcony for the captain to sit and relax and enjoy his jenever, two masts and a bowsprit which all shall be rigged 18th century style. I will arm her and paint her and give her a coat of arms on the bow.
And I expect to have a lot of fun building her. Feel free to comment and if anybody has an idea to improve Nulli Cedo : please bring it on !
Picture below: first attempt. This mast will be used as the foremast on Nulli Cedo.
Below: her Coat of Arms. Nulli Cedo: I will not budge.
Below: The hull. Finest poplar ...
First gunports opened, decks and stuff dry fitted, vague drawings of where the inner gun decks will be situated. I haven't decided what to do with the "foredeck", maybe 2 caronades ...
Below: a closer look.
So here goes.
Enjoy. I will.
Cheers
Pieter
Some much wood so little time ...
Current builds: Nulli Cedo, an 18th century Dutch war clog,   HMS Bellona
Update.
Almost finished the entrance to the captain's cabin (just needs some touching up) and I changed the design for the quarterdeck because there was no space for the stairs and the cannon in front of the cabin.
Cheers
Pieter
Edited by peveka
Update.
I have been working on Nulli's quarterdeck. The plan is to build up the bulwarks including supporting beams. Later I will cut out at least two gunports, maybe I'll install caronades. I made a railing on the front of the deck. After dry fitting I found the supports totally out of scale (6mm for an estimated 1:100 scale is a bit heavy ...) so I am going to change these. Gunports on the main deck are finished. Decks are roughly sanded and will be scraped. I won't put on varnish until I've glued everything in place.
Cheers
Pieter
Building up the bulwarks on the quarterdeck.
Admiral: don't you think you have enough of those, what, clamps?
Me: Nope.
Frank Martin has his rules of the car, I suppose we have our rules of the model.
Rule #1: Never assume you have enough clamps.
Cheers
Pieter
Edited by peveka
Nice build, Pieter. It has a certain panache. Whilst waiting for glue to set or paint to dry,  you can do a Dutch clog dance to kill some time
#2 if in doubt, use another clamp ... or two
Carl
Live in Empe, near Voorst ... Zutphen. I see you swapped living quarters ... lovely region where you are
Carl
Zutphen is more for tourist. I prefer Apeldoorn or Deventer. Maybe it's the Westerner in me .... You must miss  "hagelslag" .......
Edited by cog
Carl
I think I would pass for seafood on my baguette in the morning ;)
So what will you do with the other clog?
Carl
This project is too cool. I love what you did with the clog. I have several old clogs in the garage and may just do what you did.
I buy my clogs in Holland, Michigan which is a 3 hour drive from me. I wear mine in the winter when shoveling snow and when my edible garden is too muddy.
.Marcus
Some work done on Nulli Cedo.
I'm not unhappy with how the quarterdeck is coming along. It needs some paint work and I'll have to decide where I shall cut out the gunports. I also have to add a railing and find a nice way to finish the "entrance" at the end of the stairs. The carronades look nice and chunky, they will be outfitted with proper carriages.
I've also been working on what I call the inner deck but I'm not happy with two "extensions" that sort of rest on the sides of the hull.
They have no function and look ugly.
So I'll probably cut off a chunk of the deck which would also allow a view of what is going to be a "wall" with windows and a door, the entrance to the front part of the hull.
Right, back to Bellona's gunports.
Cheers
Pieter
Edited by peveka
Something went horribly wrong ...
You could cut away some of the hull to make the platform bigger, and have it extend along the sides ...
Carl
