Just went through your built log. It is a great pleasure to see such a great built be achieved. Wonderful job, thanks for the pictures. Will follow your log with interest.
Regards,
John
<span style='font-family: courier new'>In progress: <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/177-king-of-the-mississippi-artesania-latina-scale-180/'>King of the Mississippi</a></span><br />
<br />
<span style='font-family: courier new'>Completed : <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/176-mare-nostrum-4331-artesania-latina-scale-135/'>Mare Nostrum 4331</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://modelshipworld.com/index.php?/gallery/album/51-16th-century-galeass-imai-scale-1160/'>16th century Galeass</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://members.upc.nl/carla.en.john/Modelbouw/Rocket.htm'>George Stephenson Rocket Locomotive</a></span><br />
<br />
<span style='font-family: courier new'>Next build : sl Louise</span>
Thanks a lot guys for looking in. I really appreciate your commits.
The following pictures show the finished center walkway.
The main mast partners will fit into the opening left in the center walkway.
This picture show the forward part of the center walkway and the raised fore castle. The anchor cable will run into the square holes near the center of the picture. The fore mast will fit into either of the two round holes (actually they are octagons)  on the fore castle.
The next two picture show the mast partners in place but not glued nor shaped.
This is area on plywood will soon be covered.
Edited by Bender
More plywood is covered. This area will have a canopy.
The canopy is supported by two arches. The two arches at the top of the pictures are the kit supplied parts. You can see the part numbers. The two arches at the bottom of the picture are what I made from cherry.
I made copies of the plans and made patterns for the arches.
The kit supplied a lot of brass. The arches are covered on one side with etched brass.
The last three picture show the arches looking back from the fore.
Next the canopy. The kit supplied plywood and PE brass for the lower and upper section of the walls that support the canopy. I messed up the brass on the lower section. The brass on the upper section was meant to look open with vertical spindles. I used some spindles from Model Expo and took some liberty here.
You can see the plywood and the spindles.
The kit supplied plywood to make a form. The slats that make the canopy top are bent over the plywood form. This form has to be remove after the canopy in finished. I made a bunch of cuts in the form to make it easier to brake apart and remove.
The next few pictures show the slats being added.
Edited by Bender
Hi Al, donot know, but they are worth to be seen twice :D .
Regards
John
<br />
<br />
It is always a pleasure, to see such beautiful pictures ! And if you post them twice, it's twice the pleasure!
Regards, Joachim
My new Book in ENGLISH and GERMAN available:
"The colour blue in historic shipbuilding"
http://www.modellbau-muellerschoen.de/buch-en.htm
Current build   Amerigo Vespucci    http://modelshipworld.com/index.php?/topic/836-amerigo-vespucci-by-schiffebastler-mantua-model-scale-184-italien-sail-training-ship-build-1931/
See also our german forum for Sailing Ship Modeling and History:
http://www.segelschiffsmodellbau.com/
More pictures of the canopy under construction.
The last of the curved slats.
The form used to shape the canopy came out at this point. . . . in pieces.
The next few pictures show the cross slats being attached.
A little backtracking and a couple of reposts.
Notice that the upper side portion of the canopy sticks out past the canopy. A platform attaches to the part that sticks out.
More plywood parts I used as a pattern for the platform.
And the platform attached. A side note: I have no idea what the purpose of this platform was.
Next is to cover the bow with planks. This is the last of the plywood to be covered.
I made several copies of the plan and cut out a pattern for each plank. I use kid's stick glue to attach the patterns to the wood.
This pictures show how the planks fit together. Some of the pieces still have the paper pattern attached.
The deck planked.
The real Reale had Iron straps to help strengthen the deck. Here I used brass strips.
This type of ship would ram other ships, so the deck needed these reinforcement.
Great planking Al, the brass strips are an added value to the look of the ship.
Regards,
John
<br />
<br />
Very accurate and nice planking! Looks good
Regards, Joachim
Some more photo etched brass. I painted these pieces blue and then sanded. The blue remained in the low spots.
The next five pictures show the Blue/Brass decorative piece that covers the bow yoke.
The reinforcement knees that sit each side of the midway cannon are installed.
This picture shows two ladders: one ladder on edge, one sitting flat. The two blue/brass decorative pieces that will sit each side of the head. Two cat heads. One of the cat heads is in the plastic dish. The other four pieces are what I salvaged from the damaged brass piece I mentioned three post back.
The blue/brass decorative head piece sitting on the drawings.
The brass piece attached to the head.
Etched brass is looking great Al, well done.
Regads,
John
<br />
<br />
AL,
    Very well done with the brass. Excellent work. Keep the pictures coming, I am still watching. This is one big beautiful ship.
Wacko
Joe :D
Go MSW :) :)
Al, I like this, looks fine!
Regards, Joachim
I added some more of the kit supplied decorations and attached the wale.
In the next four pictures you can see the little brass stars that are attached along the hull.
This last pictures is the kit supplied rudder hinge. It did not hold out very well.post-247-0-24503300-1366330550_thumb.jpg
Next was cutting the vertical posts and handrails for the overdeck and the forecastle.
The post for the handrails on the over deck are made from two pieces of wood and a brass pin for added strength when attaching to the deck.
I need 34 assembled post.
Cutting the posts for the overdeck
Cutting the post for the forecastle handrails.
You are doing a great job, Al. Thanks for the pictures.
Regards,
John
<br />
<br />
I wished, I had so much time for my own model....
Nevertheless, I like following your progress... and it remermbers me, how much work I will have to do at the time, when I will start building my own model....
Regards, Joachim
Before building the handrails I needed to attach the Oar thole-pins (Oarlocks) and the Oar wear pads. On the real Reale de France the thole-pins wound have been a wood. I used brass rods.
The wear pads.
 The shrouds will pass through these four holes and attach to the chain plates.post-247-0-62861900-1366508822_thumb.jpg
Al,
It's great re-visiting your log.  Just a good as the first time around. :)
That is beautiful. I like all the tiny details that really dress up the ship. Are they all part of the kit or are you bashing a little?  Either way your work is fantastic.
-Sarah
Krabbenkutter CUX-87
Harriet Lane
Fishcutter GO-38
In the Wings:
Corel Victory Cross section
Completed Build:
USS Missouri minimissouri.jpgHMS Bounty's Jolly Boat thumbnail.jpg Peterboro Canoe tiny.jpg
