Just read through your log - excellent work - I especially admire the sweeps - really impressive!
hamilton
WOW!!!
hamilton
Just looked again trough your build log...
Really an outstanding model, wonderful pictures and interesting description. I like it very much!
Regards, Joachim
My new Book in ENGLISH and GERMAN available:
"The colour blue in historic shipbuilding"
http://www.modellbau-muellerschoen.de/buch-en.htm
Current build   Amerigo Vespucci    http://modelshipworld.com/index.php?/topic/836-amerigo-vespucci-by-schiffebastler-mantua-model-scale-184-italien-sail-training-ship-build-1931/
See also our german forum for Sailing Ship Modeling and History:
http://www.segelschiffsmodellbau.com/
Before I attached the oars I needed to mount the ship to its permanent base, and because of all the oars sticking out I decided to build a case. The ship is rather large, and I didn't want the case to be any larger than needed. I attached two oars on each side and started measuring.
42.375 inches.  (107.6 cm.)  long.
18.875 inches. (47.94 cm.) from oar tip to oar tip.
28.75 inches. (75.57 cm.) to top of main yard and flag.
Edited by Bender
I used birch plywood for the base and poplar wood for the corners and top edges.
This picture shows the clearance the oars tip has with the grove for the glass.
I made three mount that fit the curve of the hull.
Top edge and corner
Bottom edge and corner
Just for perspective. This is me.
Edited by Bender
The oars:
Each oar rests on top or a wear pad, and pivots against a "Thole-pin."
To cut the 59 pins I cut brass rod a little longer than needed. I cut a piece of scrap wood to the thickness equal to the length I needed for the pins and drilled 59 holes. I inserted the brass pins into the holes so that a little stuck out on each side. I then used a belt sander to sand off the brass the protruded from the piece of wood. I ended up with 59 brass pins of equal length.
Clamping the wear pads. All of this was dune before any of the rigging.
Also before the rigging I attached the gun mounts.
This caused an unforeseen problem.
The wrap of string I used to tie the reforcement battens to the oars would not fit between the bottom rail of the hand rail and the wear pad.
On some of the oars I could push the oar under the handrail ahead of the wear pad and then slide it backwards in place, but the vertical post for the hand rail was in the way for every-other oars. That was thirty oars that would not slide in place. The gun mounts were in the way of twelve more oars, so only 17 oars slipped into place.
I ended up needing to remove the wrap of strip on 42 oars. I had used super glue on the knots, but the oars had already been coated with poly. After a bit of wiggling and prying the wrap of string came off and--because of the super glue--help its shaped. After I pushed the oar between the bottom rail of the handrail and the wear pad I was able to slide the wrap of string back into position.
Edited by Bender
Wonderful, absolutely wonderful!! What an outstanding model, I really like it!
Regards, Joachim
Just now saw your Reale in  the completed build log.... again absolutely gorgeous, well done AL!!
Frank
Edited by riverboat
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Again, stunning. I just got a notice of your latest update, and like others, I again went through your build from the beginning. What a complicated super detailed work of art. So beautiful.
Regards,    Michael
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Looking really beautiful!
hamilton
  • 8 months later...
  • 9 months later...
Hi Bender
Great workmanship what a stunning model.Now i too have a kit Reale de France but my kit is made by Dusek and is to 1/72 scale
that works out to 79cm length, i have not opened the box that was until i saw your build so i am curiose to see how the contents
compere with the Corel kit.Well at the moment i do not have the skill but perhaps later,anyway well done.
Regards janet ( B)
  • 5 months later...
Hello,
I'm find yours nice ship, on this pages. I'm modeler from Czech, and preparing on building this nice ship from kit Heller. But here are very pad paper flags. I want make new, but need good background for make it. Please, are in kit Corel some good plan og flag, or some other background. And if yes, can you send me it?. Or, can you recommend, where I search this good background for good flags and baldachin for this kit?
I look forward on answer. Thanks, Radek
