Welcome to our new sponsor - Engine DIY. See banner ad on Home page. ×
Meanwhile, I acquire a taste for my resin printer and it seems, that I'm now able to make reproduceable result. Thereby I dare to make some more complex parts like the counter weight of the topboom.
Painted and mounted
Also,I've made a good progress in handling Fusion 360 and made a first positive form for the hooks.
I'll need heavy hooks on the cables to tighten them. So the hooks will be poured from lead.
2096396532_Bildschirmfoto2019-11-17um18_02_56.thumb.png.7821aff552aeacc0a05aa67c110343a8.png
Regards
Ralf
All booms are now assembled.
Future view of a Seagull :)
Also I've found a good Method to get into the Hull
Additionally the positiv forms for the lead-hooks are ready. waiting for the formsand.....
Layer Thickness of a Resin-Printer
Regards
Ralf
The booms are moving. :champagne-popping-smiley-emoticSlow but steady.   Here you can see a short clip  -> Instagram <-
Thereby I'm now sure that the crane will be work and beside the technical aspects, the optical and scale parts will get more room in my work.
For example, today I've print, paint and mount the 30 manhole-covers.
Additionally I've made the eight Lead castings for the Hooks.
Casting was new for me but works very well and now the eigth Hooks are waiting for they blocks.
Before painting I've tested the strength of the hooks. Same setup as planned.
I think, it's enough. :)
Regards
Ralf
Hi there,
my Original uses railing pillars with chains between them.
In 1/50 the holes will be .5 - .7 mm
Do you know any providers for so tiny chains?
My approximate solution will be thread. But it's hard to fix it in a chain-like curve hanging between the pillars.
Any suggestions?
Regards
Ralf
Such small chain would be difficult to find ... I found that chain, at least in small scales, can be reasonably well simulated by twisting two wires together, but not too tightly. Two lengths of such wire are then again twisted together against the original direction. This will looks reasonably convincing like a somewhat twisted chain.
Thanks again. 👍
Looking great, easy to make and not so much work to install.
A little setup-test
Regards
Ralf
Work on the ballast tank begins. A magnetic valve and a gear pump will be use for flooding and drainage.
First step is the angle adapter through the hull.
It's been a while since I made an excentric turning so I use this part for a pretty practise.
and the complete setup for valve and pump
Regards
Ralf
Hi there,
it's been a while since the last update.
Actual state is:
It swims, all rudder propellers and the crane are working fine. The hull is paintend , some Scale-Details are added (some are still on the todo-list 🤗
and so it's time to put it in the Water.
Ok. A very small lake 😂 , but really important for me. Steering with the rudder propellers is extremly unfamiliar for me.
To get it on a bigger Lake I've build a combined display and transport utility.
Todays work was to build a technical looking load , maybe a large silo
I think, a first testdrive is coming soon, but I'm waiting for lead to made a propper trimming.
Regards
Ralf
Hi there,
today I can make the first real test on a lake with the crane. 90% works well. Just the steering needs an improvement.
After two hours of testing and some fine adjustment I'm very happy with the crane and his behavior.
As a result of that recognition and the great fun I had, I will invest in a professional rudderpropeller steering hardware.
The mechanical indicators are not good enough for my eyes if the crane is too far away.
A short clip
And some impressions
Edited by raven62
Regards
Ralf
