HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Ok I'm in, i have been debating what to build next as the sirius is getting closed to the finish line, After 17 years (with a gap in the middle) of working on a POF from scratch i thought I would do something a bit easier and where someone else has done all the research for me, thanks chuck, I purchased the Triton plans at the same time but have decided on the Winchelsea next
Plans are printed, Wood is ordered
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Wonderful News.......glad to have you on board!!!  I am hoping to finish my planking this week if all goes well.
Chuck
False keel being cut
So First question, Just to check what length should the false keel be ? Mine is coming in at 32"
Im guessing the size of frigates changed quite a lot in the 30 years between these two, both at 1/48
Previous builds-
Among others 😁
Im fitting in some pieces while glue is drying on the sirius, stem completed
Edited by paulsutcliffe
Previous builds-
Among others 😁
First bulkheads attached, every other one and some heavy duty aluminium extrusion to keep everything straight as the ply false keel seemed to have a mind of its own once cut out
Previous builds-
Among others 😁
Finally managed to get some work done, warmer weather although very wet, all bulkheads now cut and fitted, due to the fact that I am very lucky to work in such a warm and dry garage 😁😁 I have started adding spacers between the bulkheads to help keep everything nice and straight, they can be just seen in the First picture
The clerk of the cheques yacht can be seen in front at 1/32 scale
Previous builds-
Among others 😁
Ha thanks Fred, its not easy keeping that mess organised 😁😁scrubby j's engine room is spotless compared to my garage, I do keep trying to organise it a bit better but it doesn't work🤣
Previous builds-
Among others 😁
