Gary, no personal connection. Based on the photo in BlueJacket's catalog I assumed the kit only had the type of air search radar used on about half of the FRAMS so that narrowed my search down a bit (I found out they supply both types of radars). I remember a sailor on my first ship had served on the Basilone and thought she was a great ship, and her namesake was a great hero so I went with her. An added plus was that her former shipmate's website had a ton of photos which helped with the detailing.
Tim
Current build:  Syren
Past builds:    Continental Navy Frigate ALFRED (build log & Gallery)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         Lobster boat RED BARON (Build log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
I looked at your build log for the USS Kirk. Very nice. I served on the Rathburne (FF 1057) mid 1976 to  mid 1978. Good ship in spite of the 1200# steam plant.
Thanks,
Gary
Current Build - Rainbow 1934
Prior Builds:  Lucia A. Simpson (Great Lakes Schooner 1875)
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Thanks. That is an amazing kit - I didn't know how far model-making technology has advanced in the last few years. I have one of their 1/700 scale but I'm not sure I'll ever finish it - it is too small to be much fun.
Tim
The Alfred should keep you busy for awhile. I finished the Niagara awhile back and swore off square riggers for awhile. I enjoy doing the rigging but after awhile on Niagara I started to feel like it would NEVER end; and that only had two masts.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Added the cat heads to the hull. Which leads me to the question of how they would actually raise the anchor out of the water. Every model I have built so far had a tackle at the end of the cat head that was used to raise the anchor high enough to get the flukes lashed over the gunnel or otherwise secured. You certainly can't leave it hanging by the chain from the hawse hole. I am tempted to add a three part tackle to the end of the cat head (similar to what was on the Gorham) but can do that pretty much anytime before I have to rig the anchors.
While working on the hull I added the bob stay and jib stay irons to the bow. I decided to not secure them (and trim the brass rods) until the stays are located to get them aligned with the stays.
I used the BlueJacket brass blackener but managed to get them torn up during installation. Will have to touch up with paint "later" (after the chain is attached).
I have gotten the main mast almost completed. I have to add the blocks for the topsail halyards and the backstays but am pretty close. The "new" thing here is I used Beadalon jewellery wire (0.010" 19 strand - silver) for the topmast shrouds. The wire is covered with a clear plastic covering but that does not seems noticeable (IMHO) unless you know it is there. I used the same stuff (although thicker sizes) for the standing rigging on the 1/35 scale Endeavour with creditable results (also IMHO). This is my first try with the 19 strand (Endeavour used 47 strand) and smaller size. I think .010 is as thin as it comes. I used the size 1 crimp tubes (although there is a size 0 which is on order but will not be here until mid-July). Here are two shots of the shrouds although you can see some of the other mast details.
IMG_5528.thumb.jpeg.497e3dc1022d095da33b5366aa10c116.jpegIMG_5529.thumb.jpeg.f8e7d79ba815fe5e1c51c49c145bf20e.jpeg
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Thanks Nic - Probably had a fair lead on the cat head somewhere to guide the fish tackle. I would think it would be hard to control where the anchor went without a gin pole or some other way to keep it close to the cat head without gouging the hull with a fluke.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
By the way Nic, I am starting on the Notman sails and the sail plan does not indicate how the sails are attached. I assume the fore, main, mizzen, spanker are laced to the booms and gaffs as on I did on the Gorham  but I wondered about the jib and Fore staysail. They both have booms but are they laced to it or are these sails set "flying - only attached at the tack and clew?
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
That is how I will rig them although they will be furled so it won't be obvious how the are attached.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Working on getting the main sail attached to the mast hoops and after that laced to the gaff and boom so I can get them on the completed (more or less) main mast.
On the Gorham I used plastic mast hoops (painted and thinned down) which included a ring on the hoop that provided a ready way to attach the hoop to the sail.
Those rings are not made in a size compatible with the Notman's mast so I decided to attach the hoops using a drop of glue (Weld Bond - it dries clear) on each side of the sail.
To accomplish that I built a jig with slots cut every half inch to hold the hoops and used a conveniently sized piece of balsa to hold the sail against the hoops.
Here is the jig with the sail and hoops with a drop on each hoop. The weights on the sail keep it pressed against the supporting balsa wood. The blue paint swaths were done early on when I was deciding on what colors to use on the model.
Once the glue was dried I turned the sail over and reinserted to hoops into the slots and added another drop of glue on each.
Once these are dry I will lace the sail to the boom and gaff, furl it down (gently) and put it on the main mast to see how things look. Hopefully the glue drops will be lost in the sail folds and made even harder to see because they will be "crystal clear" - it says so on the Weldbond glue container!)
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
So far so good.
I previously got the hoops attached to the main sail and today got it laced to the boom and gaff, mounted it on a stand-in for the main mast, sprayed a little water on the sail and got it furled (more or less).
I put the zip ties and the mast stub on to keep things in place while the water dries. Eventually these will be replaced with proper "stoppers" (I think that is the correct term, or maybe gaskets) to keep the boom and gaff where they belong. On the Gorham I eventually put a .020 wire through the side of the jaws into the mast to keep that end of the boom in place against the pull of the throat halyard. Will see how things go here but will use that here as well if keeping the boom down becomes an issue.
Only five more sails to go.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
I thought I would document the process I used to get the sails onto the boom/gaff.
I used a surrogate mast to hold the sail - here is the Spanker mounted prior to lacing it onto the boom.
My first attempt at this was to just lay the sail flat on the mat and thread a needle through the sail and around the boom. Worked fine until I tried to put the sail/boom assembly on the mast. It seems it is important (dah) to get the jaws of the boom and the mast hoops aligned more or less vertically. Doing it with the mast in place makes this more likely than just lacing the sail on as I did the first time. The good news is that having put holes in the sail once, it was easier to thread the line through the existing holes.
Here is the sail with the boom laced on.
The clamps were used to get some room to pass the line under the boom and to align the sail and the boom. It would appear that I cut the sail a bit short on the leach but with the sail furled this will not matter.
Next step is to lace the gaff on and then start the furling "process".
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Thank you for posting the photos for handling the masts...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
You are welcome Moab.
So with boom laced on it is time for the gaff.
For the gaff I used a soldering "slate" (closed cell foam that is easy to poke a hole in) as the base for the sail with a couple of clamps to hold the gaff perpendicular to the sail. Here is what the set up looked like (minus the clamps) after the gaff was laced. The trick is to get the top of the sail just over the edge of the board. Then you can use an awl to make a small hole in the sail against the board and pass the line through the hole, under the gaff and then "do it again". I drilled five holes in the gaff on either side of the shaft at the jaws to have a way to pass the line around the gaff without going around the "outside" where it is widest. I did the same thing on the boom although it will not be visible.
I put the sail/boom/gaff back on the mast surrogate and yes that is a big patch near the top of the sail. I somehow got CA on my finger, my finger on the sail and you can figure out the rest. Not a big deal as I could not see and of the patched area with the sail furled.
I sprayed the sail with some water and used my fingers to pull the sail material down, bit by bit, alternating which side of the boom the fold of sail went. Here is what it looked like after the first furling.
IMG_5556.thumb.jpeg.8ffbf6f16563e345c30bf0d463945d90.jpegIMG_5557.thumb.jpeg.9808fb893fc913265b856cec6e790cdd.jpegIMG_5558.thumb.jpeg.734c1bbd096841f71a143146d9e92d90.jpeg
Pretty ragged with too much sail to port. So I adjusted, using the wooden end of a artists paint bush to move the material around and (hopefully) under the existing folds.
After I got it about where I want it, I added two zip ties to hold things until the water evaporates. There will be additional "clean-up" (like trimming the ends of the laces, getting the laces tightened up and going in the correct direction, tidying up the part behind the gaff, etc.) of the sail as we go forward but this is pretty much what it will look like on the finished model (more "misadventures" notwithstanding).
IMG_5559.thumb.jpeg.7081cc748f4e03c0c7e49dd5f482d085.jpegIMG_5561.thumb.jpeg.36b2fed6cdf90242fbdcf523f4086645.jpeg
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Here is a better shot of the set-up I used to lace on the gaffs.
and a close-up showing the holes in the gaff for the laces. Similar holes were drilled in the boom.
And here is a better sequence of furling the sail.
IMG_5565.thumb.jpeg.436737f0701ab80079d71899809f2c14.jpegIMG_5566.thumb.jpeg.7d2e35021eed9984f01bdfad568622fe.jpegIMG_5567.thumb.jpeg.71d2b8b770b48dfdfc103847dfc15ea2.jpegIMG_5570.thumb.jpeg.3839c34cbccdbf48ff306f61263c3162.jpeg
Three done and one more to go.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
I am tired of working on the sails so I tried cleaning up some odds and ends.
I cut out all the chain plates from the carrier and used the BlueJacket brass blackener on them. I did it three items at a time so it took awhile. I took the advise from the latest NRG journal and put a little baking soda in the rinse water to stop the chemical reaction after removal from the blackening solution. The thin chainplates sometimes did not blacken evenly on both sides but only one side shows so I did not worry about that too much.
Here are the chainplates drying after removal from the rinse water/baking soda solution.
And after several coats of paint I finally got the trail boards "good enough" and mounted on the port side.
I messed up the dry transfer lettering on the stbd side and have not redone it yet so i will put the stbd side trail board on after I get that done. I am considering putting the lettering on a separate "name board" and gluing that on rather than putting the lettering directly on the splash rail like I did on the port side. Pressing hard enough to COMPLETELY transfer the lettering was a struggle. Using a name board would make it easier IMHO.
Here is the port side.IMG_5576.thumb.jpeg.a6ab7f2a6a2f496dbedf12505336aa25.jpeg
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
With the fore, main, mizzen and spanker sails mounted on the spars and furled (more or less) it is back to working on the masts.
I have been installing the futtock shrouds. The first issue is with the instructions which direct forming eyes in the futtock shrouds and then gluing them into the cross trees and the futtock shroud band on the mast. Later a turnbuckle will have to be attached to the eye in the futtock shroud. Would be easier to form the eye with the turnbuckle already included rather than have to come back later and try and do it. That is what I did.
My first attempt used 26 gauge copper wire that is painted black as it comes on the roll (from Artistic Wire). The problem is that it is hard to keep the wire straight. For this material I drilled out the hole in the cross tree to #68 and doubled the wire around the hole in the turnbuckle and down through the now larger hole in the cross tree. Worked "okay" as shown below (the far shroud - more on the closer one below).
When that process did not seem to be acceptable I thought about using .020" music wire (which I have in "stock"). Music wire has the opposite problem from the black painted copper - it is very difficult to bend. I had to hold one end in a vise and grab the other in pliers to pull a small eye (with the turnbuckle inside). I used a Dremel cutting wheel to trim the excess wire at the eye. Measuring to get the correct length to hit the futtock mast band was another issue but after several false starts I finally got one installed. Here is what that one looks like - much better and I could probably get away with leaving it unpainted - at least for awhile (everything iron rusts here in Florida, even if in the a/c).
After several unsuccessful attempts at doing a second shroud using music wire I thought I would try something else. I have .020 phosphor/bronze wire (I got mine from the Tichy Train Group) which is not nearly as stiff as the music wire but better than the 26 gauge by a good bit. It obviously will have to be painted but I am willing to do that to get a better looking shroud without the extra effort I experienced trying to use music wire.
Here is one of the shrouds using the phosphor/bronze wire - before painting.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
More odds and ends this morning.
I got the name board for the stbd side finished. I used double sided tape to hold the board down then used scotch tape top hold the transfer sheet in place. I used the side of a sanding stick (aka tongue depressor) to rub the transfer on, removed (carefully) the scotch tape and then rubbed again directly on the transfer sheet.
I came out pretty well - I only missed a small part of the "s".
Here it is as it looked after the transfer and installed on the hull.
IMG_5582.thumb.jpeg.0c0bafe8cc5601af55a30e6dc3153784.jpegIMG_5583.thumb.jpeg.ed881c7f54a2c5c25e4797074dae5079.jpeg
I still have to clean up the trail board where the pins are.
I also cut and cleaned the brass tubing that will be the mast chafing plates. I used Jax "Instant brass and Copper Cleaner". It really isn't "instant". It took five minutes in the ultrasonic cleaner while immersed in the cleaner to get them looking like this. Almost a shame to paint them but they won't stay looking like this for long in the Florida heat and humidity.IMG_5584.thumb.jpeg.346ad6c3080e56683a6101e9f313951f.jpeg
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
I have the Foremast about as complete as I can get it without actually installing it onboard.
I have all the halyards (a total of eight - Jib Staysail, Outer Jib, Flying Jib, Jib, Fore Staysail, Peak, Throat and Fore Topsail), the cap and fool stays, topping lifts for the Jib and Fore Staysail and Fore sail (port and starboard) booms.
I am waiting for some size zero crimp tubes for the Beadalon wire before rigging the topmast shrouds and the rest of the stays that use the .010 size wire. The cap and fool stays use .012 and the size 1 tubes seem to be okay for that size. I may redo the cap and fool stays if the size 0  tubes really looks better.
I added the chafing plate and the boom rest and the boom and gaff with the furled sail - it has the be done before the boom rest is added.
I fabbed some gaskets to hold the boom/gaff in place (instead of the zip ties) and rigged the peak and throat halyards since they do not need any other parts and it reduces the clutter of lines by two.
I am thinking of working the boom topping lifts next since that will clear all the lines off the after side of the lower Foremast.
My plan is to get all four masts in this state (although the others have significantly fewer halyards and stay to deal with) and stored in a temporary fixture  while I get the deck furniture and chainplates done. Then the fun really starts.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Main mast is now as complete as the Fore and both are installed in the temporary "holder".
I attempted to rig the boom topping lifts with the lazy jacks already attached to the topping lift lines but abandoned that approach as it was too hard to accurately place the lazy jack lines and keep the lines separated while installing.
My approach at this point if to rig the topping lifts without the lazy jacks and wait until the masts are installed on the hull to rig the lazy jacks. I believe that you need the peak and throat halyards and sheet lines tensioned to their final position to accurately position the lazy jacks.
I am using .012 Syren tan line for the topping lifts and have dyed some of the Bluejacket white .005 line to match (more or less) to use for the lazy jacks and have demonstrated that the .005 can be successfully inserted (with a sewing needle) into the .012 so that is how I plan to attach the lazy jacks to the topping lifts.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
The size 0 crip "beads" arrived yesterday.
Based on what I can see online, the crip tubes (cylinders) do not come small that size 1. Only the "crip beads" come in size 0 (although the data seems to indicate that they are the same size as the size 1 tubes -  not clear what dimension is being quoted, at least to me).
So I used the size 0 beads to join the .010, .012 and .015 Beadalon silver line and the size 1 tube on the .010.
You can see the difference below. So I will use the size 0 "beads" for joining the Beadolon wire that simulates the galvanized wire used for the standing rigging.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
While waiting for glue to dry on line seizings I glued in the ladders (no stairs on ships I am told) to the main deck.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
And then there were three!
Last night while fumbling around in one of the cabinets above my work table I found a "Ratliner" which I believe I got from Model Expo some time ago. It purports to allow assembly of an entire shroud/ratline set (for one side of a mast) off board. I never tried to use it but was intrigued enough (after rereading the included instructions) to order one for the closest to the Notman scale (they come in 1/48, 1/64 and 1/72-1/90 sizes).
I plan to give it a try on the Spanker since you have to have the bare lower mast head available - no topmast to be able to slip the loops at the shroud tops over the lower mast head.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
While looking for something else I ran across a Syren kit for a ship's wheel. The label said it was 15/16" diameter. I looked at the parts list and the ship's wheel (Britannia metal) included is 3/4" diameter so I thought I would use the (much nicer IMHO) wooden wheel.
I spent most of yesterday putting the wheel together. It is quite a task with a bunch of small delicate parts that need to have the laser burn removed. To its credit the kit includes plenty of spare pieces to accommodate the to be expected problems (including dropping a small piece and being unable to locate it on the floor and breakage.
Here are the two wheels side by side - wooden one is bare wood - I will stain it cherry if I use it.
After all that work I am not sure the wooden one will really work.
At full size the wooden wheel would be 7'6" in diameter compared to the Britannia one which is 6'.
At the very least I will have to modify the wheel box to provide the additional clearance so the wooden wheel will clear the deck.'
We will see as I get closer to having to make a decision.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
And then there were four!
Mast assembly and initial rigging (peak halyard, throat halyard and topping lifts) is complete and the masts are "resting" in their temporary home until they are needed onboard.
I also added the forward pin rails and drilled the holes for the belaying pins in the fly rail. I added the pins everywhere on the fly rail and where the belaying plan shows them in the forward pin rail. I am not sure what I am going to do with the pins that are not used. There are quite a few of them. I am not sure the kit has enough to put a pin in every hole and even if it did I am not sure that would look all that "authentic". I notice there are eyebolts at several points on the fly rail but nothing is shown using them. At the moment I am thinking about whether they are worth adding if they are unused.
Here are the four masts and a shot of the forward pin rails and the belaying pins in the fly rail.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Now that the masts are done (more or less) it is time to work on the bowsprit.
I initially tried to drill holes for the inner stays in the whisker pole but quickly realized that trying to drill a hole in a 1/32 round rod was not going to be easy - and getting four of them drilled without having even one get out of bounds was more than I was capable of. So I flattened the end and cut the groove per the instructions (and that was not all that easy) and will loop the inner stays around the pole as was done on the prototype.
I had the basic pieces already shaped and finished so it was a relatively short process to do the assembly per the instructions. Speaking of which, they seem to imply that the dolphin striker is to be left attached to the eyebolt on the underside of the bowsprit cap but not glued in a particular position. In theory the dolphin striker is positioned by the stays that pass through/around it but this is the first kit where it has not been glued to the bowsprit cap. Speaking of the stays, I started working on the Britannia metal deadeyes supplied with the kit to try and get the groove around the outside cleaned up from the mould marks and extra material. After about a half dozen  I gave up and orders some 3/32" wooden deadeyes from Model Expo. I have experience with these and will paint them flat black. I believe that a consistent groove is important on these since one end needs to be secured with a eyebolt in most of the places they are used. I have not tried this with the Britannia metal ones before and decided it was easier to switch than fight.
Anyway here is the bowsprit waiting with the masts.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
With the spars complete it was time to work on the deck houses.
I decided to start with the most complex (at least is has the most structural pieces) - the after house.
It went together pretty much per the instructions with one notable exception. Although the drawings do not explicitly show the styrene angle pieces being used on the companionways and skylight structures I used them to cover the joints where the sides come together. That turned out to be a mistake as the Britannia metal windows are too long to fit inside the styrene pieces in the ends of the companionways and all four sides of the skylight. I had to cut about half of the sides off the angle pieces to get enough room so the windows would sit against the wooden side material. It did not turn out too bad in the end but I should have looked more carefully at the drawings. Had I dry fit the windows in every location I might have noticed the limited clearance -but probably not.
In any event here is the after deck house sitting in its approximate location on the hull. I have yet to fabricate the rods that connect from the companionways/skylight roofs to the main roof. I am going to work on the other deck houses before I add the "extras" to each one. I wondered what the purpose of these rods might be and finally decided they were probably there to keep lines from getting fouled on the structures sticking up from the main roof.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Absolutely gorgeous work on the Notman. This is an orphaned kit I'm working on as time permits that I have had to replace just about all of the work the previous owner did. I'm following your build intently. I love the blue trimming of the deck.
