I'm planning to lightly sand each block to have a smooth curve as mentioned in the Syren's instruction manual, which would expose some bare wood.
Do I need to treat the blocks with tung oil (or varnish) before installation?
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
I think blocks look better if they are darker than the usual light colored blocks that come in kits.
Some oil or varnish improves the appearance IMO..
― Jimmy Buffett
Slow crawl:    Rattlesnake
I found an initial coat of sanding sealer gives a more even color, otherwise the end grain absorbs too much dye or stain
Richard
Current Build: Early 19th Century US Revenue Cutter (Artesania Latina "Dallas" - messed about)
Completed Build: Yakatabune - Japanese - Woody Joe mini
Member: Nautical Research Guild & Midwest Model Shipwrights
