HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Matrim  Good read on your posts. I have TurboCad Deluxe 9 for Mac (V 9.0.11 Build 1204) and can't seem to get a good quality "Trace" of plans. I have ordered the instruction DVD's but have not received them yet, but they don't appear to address my dilemma. Would appreciate your input on this subject. Thank you in advance.
Dallen
Dupree
"A slow steady hand conquers a fast shaky mind" - me
HMS Triton 1:32 Cross Section
I have TC for PC v19 and have been using TC since v8 (actually v4, but it's a long story).
The trace tool in TC is not good enough for our kind of work.  Under the best of circumstances it leaves one frustrated with its poor quality.
I now have a 64 bit version of TC that no longer has a trace tool.  When using Trace in earlier 32 bit versions I quickly gave up on its utility.
You might want to check out http://forums.turbocad.com/index.php?topic=11696.0
and http://forums.turbocad.com/index.php?topic=12575.0 for insight from the TC forum.
For our kind of work importing the image and then manually "tracing" is better anyway.
Wayne
Edited by wrkempson
Wayne - Thanks for the reply. I was beginning to come to the conclusion "manual tracing" but I didn't want to do it in ignorance. I'm wondering if I should have purchased the "Pro" version. The TurboCAD forum seems to be a little dated.....I guess I'm the last to learn it.  :)
Dallen
Dupree
I agree. I am using (currently) 2016 Deluxe and tend to upgrade every other year.
I also load the image in and then manually trace (it is surprisingly enjoyable). One thing I did have to do was to switch off the red dot graphics thingy that seems to default as it made the imported plan image 'fuzzy' when drilling in (which is really not good for tracing) BUT that was on a windows machine so may well not be relevent..
Thank you for your inputs. All have provided valuable information. One last issue.....can anyone explain the vertical dimension off set above the object. I've used up two evenings trying to remedy this. My inquiry to TC have thus far gone unanswered. Probably something simple. Will try to send screen shot.
Edited by dallen0121
Dupree
You might be better of posting a topic in the cad forum as you may have more chance of reaching someone who uses turbocad with the mac.
Also try posting in the turbocad forums. Again you are more likely to find a mac user there and the forums are generally more responsive than contacting the company.
Another (slow) update. I have started on some build plans. The following are provisionally measured at 1:48 scale though this may be adjusted later after more consideration.
We have two keel build plans. The first showing the side
and the second the top
The False Keel will be an easy addition along the same lines then I will probably move to the stem plans. You will notice the first plan has a 'green L'. I tend to add these to build plans at the correct scale so 1:1 those two lines each measure 48 inches in this case. When printing I can then measure those lines and they should be exactly on 1 inch. If so then no problems with scaling has occurred..
Very nice plans you are developing Joss; they should make building very easy with such detail.
I have been looking in regularly but not posted.
cheers
Pat
Indeed as these plans dont have it.. (most of the plans posted in detail are missing something) though in this case that is less an attempt to deliberately lose something as a decision not made. Basically when I last looked at building on the original plans I had decided to taper after completing the stem and false keel under the perhaps mistaken idea that it would be easier.
Perhaps it would be better to mark the taper now and cut it accurately on all pieces..
Just in case here is a revised with the start of the taper marked with a red vertical line...I am cutting corners slightly by making it start just after the joint (in both cases) so if this is very wrong then please say!
Keel taper is a vexatious question. No source I've read specifies exactly where it begins. I suspect that it starts where the cant frames begin, but have no hard proof of this. Anyone else have more information?
  • 5 weeks later...
Has anyone ever taken a run and automating this? We (and I mean human race) have thousands of these plans in a relatively consistent format. I see no impossible to overcome challenges in creating a tool that can output to formats importable by CAD and creative modelers (MAX etc.), by extracting the station frame curves and positioning them on a correct keel and generating a skinned/solid model. If wer can extract the station frames, we could easily tween the values between station frames to generate the intervening frames.
I'm not saying it would be easy, but I think it's doable, and it seems to me we have enough interested parties and groups that it might be worth doing - imagine there being a library of skinned and solid models with correct hull forms, wales, gunports, would have to draw the line at the head and the stern, too variable and complex. But still if we got that far, modelers, historians, games and movie people, all could access all of these sailing models for whatever purpose they need. And the processing would still require some human input to indicate the correct areas to scan for the curves and which is bow and which is stern, and marking the keel location and length and probably a couple other steps to prime the tool for each unique plan.
Only step I'm iffy on is automated generating of spline-based curves for the station frames, I'm not sure that I know of a product doing that, turning 2d drawings into vector/spline-based lines. I have some idea of companies I could ask who should be able to do it. But also I'll see if I can track this guy down, this was a proposal to do the exact same thing for old rocket parts.(FYI - that's a PDF). This is just the proposal, not clear he did it.
Anyone else know of existing tools/companies/researchers who might find this problem interesting?
Interesting concept though i don't think it is doable. Perhaps for modern plans with no 'give' but for anything on old paper you have to spend a lot of time making certain the plans tie up to each other correctly even before you get to drawing the frames.
The other problem is more specific and directly related to the taper quote. We do not have a definitive way of doing these things and my way is almost certainly a fudge. When build plans are made you spend a lot of time deciding how much detail you want to put in and there are always tradefoffs between realism, ability to draw in scale and time.
I sent some mail to the guy who put together that presentation, will see if he answers. Matrim I wouldn't anticipate you could just point the tool at a bunch of plans and walk away, there would still be a degree of human input to make sure the plan is clean and marking locations of certain items before it could make an attempt to build at the very least.
Are you saying you've found the drawings are stretched somehow? I thought generally speaking the paper used for these plans was fairly heavy and would be resistant to something like that. Yes, that would be very difficult to correct.
If the plans are original (or copies of, even 10 years old), there can be distortion due to things like humidity and temperature.
Just catching up on this. I am very impressed with your work and have got a lot of ideas for when I work from old plans.
One thought on the taper you can use as a check. Fincham lists keel taper as 1/8 inch per foot on each side in his book from 1825. That is a taper of 1 inch overall every 4 feet so that should give an idea of where the taper should start. At the least it can serve as a sanity check.
Hoss
Wayne,
In the 1825 Second Edition I got from Google it is page 9, Section 3. Did you get the 1852 version from Google. I will have to see if I can get it and check for what is different. Sounds like there are a lot of changes.
Hoss
Just returning to this after Christmas. I have been thinking about Hoss's taper recommendations. Taking my frigate she should be 15 inches wide amidships and 12 inches wide at the post/rudder. This is only a taper of 1.5 inches. My current taper starts (at the stern end) around 24 foot from the rudder making it a fairly gentle incline.
Taking the above recommendation then 1.5 inches should take up around 6 foot so 72 inches. This is a much sharper incline but makes some logical sense due to the ships base shape
Anyway throwing those locations onto one of the draft plans we get
The left most lime green line being 6ft and the rightmost being the current taper start point.
Hmm I am tempted to re-do the keel and false keel plans to see what the taper would approximately look like and perhaps cut it out of some scale wood to see as well.
By Hoss's citation the taper would begin 4 feet distant for every 1 inch differential between the midship siding and the end siding.  In your case, 15-12=3  and so 3X4=12.  Hence, the taper would be 12 feet from the end, not 6 feet.  I think you may have halved the 3 inch differential unnecessarily.
Twelve feet still seems too short for my viscera, but if you follow Hoss's formula that's what it is.
I have argued elsewhere for a different way to view the taper, but for the present I am no longer as certain as before.  It's just that 12 feet is awfully severe to me.
Wayne
Edited by wrkempson
Upon looking at Fincham again, his words are "It [the keel] is parallel in breadth or siding, excepting towards the extremities, where it is reduced from two to three inches; in the proportion of 1/8 inch in a foot on each side."
Ignoring the archaic punctuation, this can be read to mean that the taper extends over a length of one foot per 1/8 inch of differential between the midship and end siding of the keel.  Thus, a total taper of 3 inches would begin at a length of 24 feet from the end.  The formula in Finch (a foot to 1/8 inch) does not describe the angle of the taper but is a rule to establish where the taper begins.  So, there is a taper on both sides that begins at a distance of a foot per 1/8 inch of the total differential.
So, I guess I would amend Hoss's formula and suggest the taper begins at 24 feet from the end (if we follow Fincham).
I can think of one reason to ignore Fincham for earlier vessels, but I'm not sure of it enough to suggest it here.
Wayne
Edited by wrkempson
Wayne,
You are probably right on that. I always thought the taper was a little extreme too, but was caught in the 1/8 inch on each side thinking. I will probably go with your interpretation from now.
Hoss
Druxey's "hunch" for a long time has been that the taper begins close to where the cant frames begin.  The 24' figure comports well with that notion.
I got to thinking.  What if the length of the taper also defines the length of the keel piece?  For example, if we use Steel for a 36 gun frigate, the length of the keel tread is 126' 2"; the keel is sided amidships 1' 4", forward 1' 2" and aft 1' 1".  By this the after taper begins 24' and the forward taper 16' from the respective ends.  Steel calls for six keel pieces (the Repository calls for five).  Now, if the forward keel piece is 16' and the after piece is 24' (for a total of 40'), then the remaining four keel pieces take up 86' 2" and each piece would be 21' 7".  Should one use five pieces the inner pieces would be 28' 8" (or 9").  These seem like viable lengths for the keel pieces.
The same procedure for a 74 gives the fore and aft pieces at 24' with five inner pieces of 22' 5" (or 6").  Again, this seems viable.
Of course, all these would be adjusted to account for the joints.
I have made my keel piece lengths as roughly equal, but the above was an amusing exercise if nothing else.
Wayne
Wonderful work guys plus the 24 ft does match the current taper start location quite well so I wont have to re-draw. That was a quite interesting discussion for a point that turns out to validate the guestimate approach taken by many of us :)
K, after the (much needed) assistance from Wayne and Druxey (see Rising wood thread currently around 2 higher than this).
I have drawn out the rising wood though I had to redraw on the master plan first.
As before I am using a simplified notch system to make it easier to seat the frames, As with a lot of things this will introduce its own complications though these will mainly occur when cross marking the relevant heights on the actual individual frame plans (the seat of the frame on the rising wood is usually angled so if it is not horizontal then it needs to be equally carefully marked as it wont be a default height above the bottom any more but will be higher (or lower) dependant on where the horizontal line was taken off of)
Just to reiterate what was done a fresh buttock line was taken off of the body plan using the keel lines. This generated a line that sank veey close to the keel itself at the centerpoint but did not quite touch. Horizontal lines were then thrown up from here 6 inches (the base size of the notch) generating the plans above.
As mentioned before another way of doing this include generating an angled rising wood section with no notches. I did not follow this path because I am happier with right angles and the notches will also help seat the frames at the correct location.
Phew. Next up the much simpler stem and apron structures.
