Hope someone can help.
I assume the thwarts of an early 19th century launch, an English ship’s boat, would be removable. Is that correct?
Thanks,
Bruce
STAY SAFE
current builds:
Hi Bruce,
I think yes, and not only on launch, but also on longboats of early times. The boats are usualy stowed one in to other in the waist.
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
  • Solution
The various tables of scantlings for boats available break down thwarts in to 'main', 'after', 'fore' and 'loose' which might imply that the 'main', 'after' and 'fore' are not loose and most likely have knees.
The transcripts of the Bounty mutineers trial include statements the the knees and bolts for both the launch and large cutter had to be retrieved from the chests of the carpenter and carpenters mate. These chests weren't all that big so perhaps only the knees of the main thwart (or thwarts in larger boats) were removable.
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
Good Morning Bruce;
To add to all the replies above, yes, thwarts in many ships' boats were removable. This was to allow flexibility in the cargo which could be ferried in them, for example water casks taken to shore to replenish the ship's supply at a stream. By removing some of the thwarts, 2 parallel rows of casks could be laid end to end in the midships. There is a model in the NMM depicting exactly this. Contracts for the building of boats normally specified the number of fixed and loose thwarts.
All the best,
Mark P
Previously built models (long ago, aged 18-25ish) POB construction. 32 gun frigate, scratch-built sailing model, Underhill plans.
2 masted topsail schooner, Underhill plans.
Started at around that time, but unfinished: 74 gun ship 'Bellona' NMM plans. POB
On the drawing board: POF model of Royal Caroline 1749, part-planked with interior details. My own plans, based on Admiralty draughts and archival research.
Always on the go: Research into Royal Navy sailing warship design, construction and use, from Tudor times to 1790.
Member of NRG, SNR, NRS, SMS
Thanks to all who have replied. Craig has found what I was looking for, a specific reference in scantlings to thwarts being described as  'fixed' etc. This did not appear in my sources. It would be interesting, if possible, to date those scantlings.
It makes sense of the drawings I have been pondering of launches and other boats adapted to mount cannons or carronades.
Mark, I believe we have been looking at the same model. I was thinking of doing something similar for the boat on the deck of my Mediator. Looking at this model and also trawling through images of cannon armed boats the thought occured to me: how did they stack the boats if the centre thwart was fixed?
The boats were in many cases capable of carrying guns when required. The slides for these guns varied but looking at the full length versions, the slides were on top of the thwarts. It seems certain that the slides required solid fixings and removable thwarts don't fit in with that idea.
Some mountings were shorter and allowed for lowering the gun to improve stability of the boat. These slides all seem to be either side of the centre thwart.
I may be chasing my tail here but the two requirements, ie stacking boats and having solid thwarts, seem to contradict one another. If the answer is obvious, I ain't seen it so before I spend a lot of time re-reading every practicum I thought I would ask.
Thanks,
Bruce
STAY SAFE
current builds:
8 hours ago, shipman said:
Out of curiosity.......was there a standard width of thwarts?
Probably the safest way to answer this is that there are tables giving standardized sizes but that size varied by boat type, boat length and thwart position/type.
Edited by iMustBeCrazy
Craig.
Shipman,
Pick a boat and you will get answers for sure.  There are scantlings by Steel and more information in Boats of Men of War by W.E. May  Scantlings for boats of about 1800 that show main thwarts from 7" broad for a 16 foot cutter to 12 inches for main thwarts for a 32 foot longboat.  Pinnaces and yawls were from 9" to 10" broad.   Loose thwarts for a 16 foot cutter were 7" broad up to 9" broad for a 32 foot longboat.  After thwarts ranged from 7" on a 16 foot yawl to 9" on all longboats.   Forward thwarts ranged from 7" on a 16 foot yawls,  to 9" on all launches and  10" on all longboats.  Pick a boat and size and there is information available for each.    Earlier scantlings give thicknesses of main and loose thwarts, but I could not find any dimensions for their breadth but would assume they would be similar to those in the 1800 scantlings.
Allan
My longboat model built to plans in May’s book includes three fixed thwarts; one in the bow, one at the mast partners, and one just forward of the stern sheets.  These fixed thwarts are each fastened with knees into the rising strake.  The other thwarts are loose.  Both the NMM “Medway” longboat model and the longboat model in the Krigstein Collection are arranged the same way.
By the 1840’s navies had switched to launches instead of longboats and the US Navy specified that all thwarts In launches be loose.  The ends of the thwarts were to be reinforced with iron plates and were to be secured with removable iron pins through holes and passing into iron brackets.
