HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Hello friends ,
is there anyone who has experience with this tool
it looks fantastic for small aria ...
i know proxxon has something similar but the proxxon one  it looks like a toy ,
also the vibration of proxxon its horizontal and that one its vertical ! So its much better !
"smooth seas do not make good sailors..."
:pirate41:
MY FIRS BUILD : H.M.S BOUNTY (mamoli)
SECOND BUILD :The concord stagecoach 1:12 youtube link : https://www.youtube.com/watch?v=yJzCs9umWPI
CURRENTLY BUILD : H.M.S VICTORY (Caldercraft) : http://modelshipworld.com/index.php?/topic/15501-hms-victory-by-michael101-caldercraft-scale-172/
There's quite a few different models of those out there.  Some oscillate side to side and other in and out.   It has it's uses for small parts not large one.   Also, best bet it is to check out various models and prices.  Prices and quality range wildly.
I have a Proxxon pen sander and can highly recommend it. This is my second one, the first lasted for 20 years or so. As Mark said, these tools are not designed for bulk removal of wood, but I have just used mine to fine sand the second planking on the hull of my Pegasus build.
Cheers
Richard
Current builds:
Completed builds:
SBLim-2A, MiG 15 variant, WAK card
Harpy by Vanguard
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
I got one for plastic models.  Comes with different sized heads as well as different grades of emery paper.  Am very pleased with it - very easy to use and adjust sanding speed, little of the vibation goes into the hands/wrists (unlike some other tools I have used in the past). Not sure how effective it would be for wood - depends on the emery paper used, I guess.
Heghlu'meH QaQ jajvam
Slainte gu mhath
L.H.
You can't adjust the speed of the Proxxon. This has never been an issue when sanding wood, but could be if it is used on a plastic model.
Edit. Oops. The Proxxon has a choice of two power packs - one of them allows the speed of the tool to be adjusted. 🥴
Edited by Richard44
Richard
Current builds:
Completed builds:
Harpy by Vanguard
I have a Proxxon pen sander.  It is hooked up to a MinCraft 12v variable speed power supply.
I don’t use it often but there are times when it will work better than anything else.  First of all, the long dimension of the tool is perpendicular to the action of the sanding head.  This means that it works well in confined spaces like the areas between frames in an open boat.  Holding it like a pen gives precise control.  The tool comes with several plastic “feet” that hold the sandpaper attached with pressure sensitive adhesive.  I sometimes make shaped shoes from wood that are glued to the feet to sand different contours.
I also have the Proxxon. And it’s GREAT for small detail work. I’ve only used it on wood...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
