That looks very good Christian, well done.
STAY SAFE
current builds:
7 hours ago, Bill Morrison said:
It's interesting to see how much her lines resemble the Le Soleil Royal.  Your Saint Philippe is stunning !
Thanks, Bill
It's like a "sister-ship" of the SR, only real difference is the simplified decoration, with few complicated elements, and the suppression of one upper quarter-deck
Lemineur has also applicated a 10% longer general proportion, and I think that's the disposition making the vessel more "elegant"  😀
Regards,
Chris
Chris,
One of the features that has often been criticized in the Heller Le Soleil Royal is the aft run of the hull below the waterline, which many believe is too shallow.  Another is the depth of the hull below the waterline.  Given the many models of SR and other French ships of the line of the era, I think that Heller is probably more correct than not.  Your model seems to confirm my point.
I have a copy of Les Vasseux du Louis XIV.  My French may be lacking.  The many drawings seem to confirm this as well.
Thanks again for a wonderful build!
Bill
Hi, Bill,
I've rectified some errors of the hull below the waterline, red colored on my illustration
The monograph's hull doesn't run correctly, as seems to me, I ignore the reason of that
I don't know details of Heller's realization, but the monograph is more probably wrong,
and I redraw some rear elements in order to fix this problem, I did'nt like the heavy hull  :
I also suppressed two gun-ports of the back-stern, the four guns were impossible to use (no much place)
Regards
Chris
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
