As you are still in a conjectural planning/spitballing phase, I would like to chime-in on your proposed re-gammoning location.
From a timbering standpoint, running the gammoning above the trailboard creates a vulnerable weak spot that jeopardizes the bowsprit.
Also, it just wasn’t done, so the wrongness of its appearance, here, would look even more wrong than the gammoning soaking beneath the waterline.
It seems to me that, while you may have to re-think the timber joinery beneath the trailbord, there is ample space to locate the gammoning above the waterline, but below the lower cheek.
Your last edited photo with the gammoning going through the trailboard is even less structurally sound.
All I’m trying to advise, here, is that if you are going to go to the trouble of making something immensely complex, like the SP, then try to avoid glaringly wrong work arounds.
If it were me, I might redraw the timbering, so that the gammoning didn’t pierce at an awkward place below the lower cheek, and I would probably cheat the waterline down by a 1/16” - 1/8”.
It may not be exactly right, but it is more correct LOOKING than what Lemineur provides for.
Don't forget that these holes will be hidden under a furring deck, SP seems to be a little difficult, but nothing really impossible for me...   😘
Yes, it's what you've understood, If you know the kit of USS Conferderacy, it's the model i'm following for improve the S-P gamonning
I shall not modify the waterline position, because it's an absolute reference for all the built
I have the "choice" between an historic "probability of truth", and another approach, more "creative"
J-C Lemineur wrote to me that my proposition had existed, but later, then it would be an anachronism, that's also your point of view...
I shall take a moment of reflection before a definitive decision   😘
I posted a test message because your previous post - for which I received an email notification did not appear, when I went to your page.  No number of refreshes brought it to light.  So, I posted a test message to see whether the page would refresh that way.  Whatever you wrote this morning still isn’t visible to me.  I deleted the test message, though.
On 3/16/2021 at 4:19 PM, Hubac's Historian said:
[...] if it were me, I might redraw the timbering, so that the gammoning didn’t pierce at an awkward place below the lower cheek, and I would probably cheat the waterline down by a 1/16” - 1/8”.
It may not be exactly right, but it is more correct LOOKING than what Lemineur provides for [...]
Here I show you a redraw of plan using your recommendation, and water line cheated down 1/8" (around 3-4 mm) :
The ropes will be out of water, but with the decorative element hidden by
gamonning, without inconvenient, it's not an immortal masterpiece of Art  😋
Edited by CRI-CRI
As an alternative you could cheat:
Part 204 - chock piece  - seems the extend to the top of part 202B - upper head rail.
I would place the two gammoning slots in 204 - just above the upper head rail.
This would save having to move the LWL or hide the carving.
In real life, if the boatswain, I would probably try to place the gammoning where the carving is and adjust the pattern to include it.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
For reasons I point out in prior posts, doing so creates unnecessary weak points in the structure.  These ships were massive, with tremendous dynamic forces working against them all the time; the gammoning really needs to be secured by the heavy timbering of the cutwater.
Anyone, of course, is free to do as they wish.  However, if they want to represent authentic reality, then there are some rules of construction that shouldn’t be violated for the sake of aesthetics.
Edited by Hubac's Historian
1 minute ago, CRI-CRI said:
First frame in position
Language differences aside, that is not a frame.  The usual name is "bulkhead".  It is not really a bulkhead either.  What it actually is = a "mold" or "mould"*.   From my time around microbiology, I prefer mould - even if the site spell checker does not. It also does not like a lot of other words we use, such as "futtock".
25 minutes ago, CRI-CRI said:
it will be a fat boy, miraculous
Imagine doing this at 1:48 as provided in the monograph?
* Old Ben, Ben Lankford was the first the make a point of this back on Clay Feldman's listserver.
NRG member 50 years
Current:
NMS
Other
