OK, I think you're asking a couple different things...
"why put a wipe on poly on before painting"
In my case I'm painting over the black dye.  I don't think the paint directly on top of the dye is a good idea, so I will cover the dye with wipe on poly, then paint the white stripe.  I can also sand between coats of poly and really get things smooth.  The white paint at that point would be the last step - finish wise.  It does remain to be seen however how the white will cover over the black.  I'm hoping for the best, but expecting the worse.
I'm thinking ahead to painting the outside of my Constitution cross section and was planning on just priming the wood before painting, probably acrylic paint, many coats
Yes, this is the method many others, including Chuck, uses.  I just don't have the patience to put on 20 water thin coats of paint.  I've painted cars and finished furniture off and on for 30 yrs and and i can't wrap my head around that method - although I do understand it.  The purpose of putting the poly on before the paint would be to seal the wood, and sand between coats to get things good and smooth.  Basswood is very soft and will soak  up a lot of paint, or any finish for that matter.  Primer would probably work, although depending on what type of primer you might need to thin it down a lot to keep from burying all the fine details under thick primer.  And don't forget to sand between coats.
Good luck and hope I answered your questions!
Wes Cook
Current Build: USF Constitution (Model Shipways)
USF Essex (Scratch build)
MS Syren (build log lost, need to rebuild)
Future Builds: MS Confederacy
Absolutely.  Thanks for such a detailed response, I appreciate the information as well as the explanation.
Much thanks,
Andy.
Thanks you Hipexec!  Don't know if I'd go as far as beautiful but hey, I do appreciate it!
Wes Cook
Just checked in Wes and you've got some lovely work going on here.
I cant believe your going to paint that great planking. Seems such a shame.
following your build from now on mate.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Mobbsie, Conny wouldn't look right to me without the black hull.  And it's basswood, not the prettiest wood with a clear finish.  With my perfectionist nature I'd look at that natural basswood hull and never be happy....  I am going to plank the deck with boxwood i got from Jeff at Hobbymill, so THAT should be pretty with a clear finish!  Thanks for checking in!
Wes Cook
Hey, I'm a sub Lieutenant!
Not much to report other that more planking.  I finally got tired of it and decided to work on the deck, fitting masts etc.  Thought I'd snap a couple pic while she's sitting in drydock on the bench.  That odd bend at the first upper gunport is some kind of optical illusion, it doesn't actually look like that.
Wes Cook
Your planks look excellent! My version has me planking before I mount the stem. I'm not sure how I can get that crisp look you have that way. Oh well, I'll figure it out.
Rich
USS Constitution hipexec
Thanks Augie, your Confed is coming along quickly.  I had visions of starting mine and trying to keep pace with you - but not now!
Rich, not sure what to tell you about your stem.  I do know mounting the stem first with the rabbet it creates makes a great way to insert the planks at the stem.  The three models I have are all Model Shipways and all share that feature.
Maybe some of our more experienced builders can chime in and help you on that one!
Wes Cook
Wes, that's beautiful. It brings back memories when I was at that stage (only mine didn't look nearly as good).
I think what Rich is referring to is that some manufacturers have you plank the hull to the false keel, then shape a flat on the planking to attach the exposed keel. The MS Connie has you attach the exposed keel to the false keel then cut the rabbet to accept the planking. Either way works (in my book).
Hope that helps.
Thanks,
Harvey
Patrick, that's a good question I hadn't considered.  I think I'll lay the large mid ship grating in place and see if I can peer down into nothing, then decide.  Thanks for pointing that out!
Wes Cook
The planking is looking really sweet, Wes. I couldn't agree with you more about painting basswood. When I want natural wood ,I use boxwood, pear or holly.
Bob
Wow, thanks guys!
Bob, coming from you that means a lot!
Evan, I've followed you Conny build and the detailed info you've provided.  It's been very helpful.  When I start work again on my 1812ish transom, your one of the guys I hope will like my approach.
Pygo, thanks so much!
Wes Cook
With planking temporarily put on hold to save my sanity, I moved to deck furniture.
Finally get to use some pear wood, very nice stuff!!
This is the first hatch cover, they"re all built basically the same as far as methods...  I cut the half lap joints with my 10" table saw.  Overkill?  Yes, but I don't have a Jim Saw yet and I do love my power tools....  Once the half laps were cut I cut each piece to length (a little long) with a hobby miter box.  Then I assembled the boxes and trimmed the excess with a knife blade, and added the support pieces on the inside for the grate.  I still have to attach the small trim piece on each side.  Will post pics of that when finished.
Edited by cookster
Wes Cook
Thanks Augie and Geoff!
Hardwood is definitely the way to go, and the swiss pear has a wonderful color.
I never would've known about Jeff @ Hobbymill, or considered milling my own model ship lumber one day without MSW!!
Thanks MSW!!   :cheers:
Wes Cook
OK, got the first coaming done.  (thanks to Lambsbk for reminding me of my ship's terminology!)
I was worried about making these little rascals but this one really weren't that bad!
Anyway, I added the trim pieces ran long to come back and trim down later.
Trimmed and dressed the edge.
glued the rest on
And finished it up.
Laid down some boxwood planking to see how the finished install will look, and of course couldn't resist setting in it's future home...
Now on to the rest of the coamings....
Wes Cook
I planked and varnished my below decks even though I'm not sure anyone will ever see them when they look down the grates. I asked that same question when my plans called for me to plank these hidden decks. I think it was Augie or Sjors who said, "You'll know they're planked even though you can't see them." Well, mine are done. It didn't take that long.
Rich
Thanks Augie!  Can't think of a good comeback for the show off comment so I'll just leave it alone... B)
Wes Cook
