Your HL is coming along very nicely!  The HL was also my first wooden model - she sits forlornly in a glass case waiting for me to once more bring her back to the table and finish the rigging. Regrettably, the more I work on her the more issues I see. This is a fun, though challenging due to scale, model to build. I believe that I replaced much of the supplied thread with materials from Syren.
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
I am also confining the supplied chain to the anchors and paddle wheel detente, too thick for the funnel guys. I used thick thread there.
Thanks for the compliment!🙂
Going too slow to post much. I am getting my shrouds up one by one. I glue the chain plate in place 1st, then thread over the cross tree an tension with a weight( clothes pin) before glueing. The small size of this model has me using “bottle ship” techniques, I.e. creating visual illusion, such as gluing, alone, rather than tying knots, in many places.
Clove hitches only look 'right' at much larger scales than the scale you are working at. With scale model work at any size, there are always compromises to make appearance look correct.
So I see🙂. My clove hitches on the lower third of my starboard formast shrouds will stand as a monument to my learning experience. Luckily, at normal viewing distance, they look OK, sort of like antique votive ship modeling.
37 minutes ago, ERS Rich said:
Good move….the difference between theory and reality….clove hitches sound good in theory, the reality is impossible to execute….why not cutoff the lower rat lines?
They don’t look quite bad enough (to me) to replace. The knots have glue in them so the shrouds would be entirely replaced. The labor intensive deadeye/ lanyard work makes that a lot of backtracking. I could always do this later, long after completion of the model🙂
My biggest boo boo on this whole project is that my skylights and companionways are misplaced, and glued down such that the guns cannot be placed realistically ( and there are more of them to place) 😞. If they are mussel loading. This ship was captured in the civil war by the CS and used as a merchant ship- tender, with one blockade run to Cuba. I could hang a confederate navy Jack, in place of the American flag aft. 🤣🤣
Edited by Organ tech
It’s all good….
All part of the learning curve…..
Regarding the cannon….the casual viewer will never know the difference, in the end you will still have a nice model.  Plenty of oh’s and ash’s from family and friends and something the family will want to keep….
20 minutes ago, ERS Rich said:
It’s all good….
Thanks for the kind words and encouragement 🙂. The civil war was very transitional in that breach loading and mussel loading were used side by side. More research my reveal that HL’s guns were breach loading(?)
Still working on my model🙂. All of my shrouds are up, but not the back stays yet. I am waiting on those to give me more room to reach in to belay the bunts on the pinrails. I am glueing the ratlines one by one to the shrouds. I have way to much glue on them, giving them the look of icicles, that real ship crews delt with.
My sail making consists of copy paper, soaked in black tea, with buntlines glued on. The topgallent sail is in place. On the real ship, the bunts would pass through much smaller blocks, on the mast, than those on the mast for lifts and braces. On this scale, I omitted them. I will create the illusion of the full buntlines by making the mast to pin rail runs, separate pieces of thread.
Usually sails are attached all the way along their yards by short lines called robands. At such a small scale I'd simply use a thin line of glue.
I see—— you are absolutely right!! I wasn’t heading my own source material, such as the attached photo from Villiers, Last of the Wind Ships.
I am replacing the top sail with one that appears to be more correct. I am only putting these two square sails on the model. I am going to add two of the jib sails and need to study how those are rigged. Any instruction is welcome!
Rigging square sails didn't change a lot over time. Again, at such a  small scale I'd glue the edge of the jib sails to their stays.
Edited by druxey
