Starting build number 2.  Staying with Artesania for this one but a bit more complex than the virginia schooner I started this journey on.  Would like to do something like the Ocre Terror but this is my next step in that direction.
Unboxed and everything looks good so far (oldest laptop in the house was the only one left with a cd drive which makes this interesting with no printed instructions but I put everything on onedrive to make it more accessible.  If anyone is doing this same, I'd be happy to share the files.)  Laying out the false keel and bulkheads.  As mentioned by others the AL laser cuts are a bit tight so a little filling is needed but I'd rather have that than sloppy loose!  I also found a slight bow in the false keel and a bit more warpage between two bulkheads.  Soaked it in water for 20 min and sandwiched it between two mdf boards with pipe clamps.  With this west coast heat wave, a half day in the clamps took the warpage right out of it.  Flater than flat now!
On my last build, I eyeballed my bulkheads.  Went together pretty well by I did have some slight twist on a few bulkheads and the deck didn't end up exactly centered.  Everything worked out just fine on that build but this time I'm going to see how it goes being extra detailed.  I carefully measured the bulkheads and the ran a centerline on the deck pieces and lined out each bulkhead one the deck.  Then drilled a couple centered pilot holes so that I can try to set the decks/bulkheads exact when I glue.  May not show well in the picks but we'll see how this goes and whether the extra attention makes a difference.
Keep going.  Set the deck plate on fore and aft and furing the stations.  As with most, this kit is off on stantions 10 and 11 and it creates a dip.  Many people seem to try building up with shims.  I found it a lot easier to just putty the dip because I could carefully sand the right curvature into the cured putty and it will have a solid surface to glue to.  I've also setup my jig for the water ways once the walnut fries to shape it should lay well on the deck.  I think I am going to overhangs the deck edge just a tiny bit to avoid a gap between the bulwark and the waterway. Well see how that works.  Easier to sand down the edge than fill a gap.
Brown sharpie along the edge of each piece.  The Sharpe doesn't devolve when I put the finsh on and get the look that is crisp but not too crisp.  Then anytime the I fubar and cut a cap a little large, I use the same marker on the plywood underneath before gluing and it blends pretty well.  Hides my goofs!
Soaked the bulwark and letting them sit a few days with light clamping in hopes of getting a more natural camber to the wood to hopefully make it easier when it's time to actually assemble. (Ine actually had an "outward bend" when I first opened the package so hoping this will fix that.
Decided to go with walnut stain on the walnut.  Adds just a little darkness without over doing it.  Using a sharp punch to create hole for treenails.  Planningon a light stain of cherry on the deck.  The stain should pool in the holes to create just enough emphasis on treenails.
Nice Deck Sir!!
(Love the "Joggles.")
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
Your Bluenose is looking great, Travis! I've always thought she is a gorgeous, sailing ship with her beautiful, sleek lines. My wife and I got to sail on her in Lunenberg, Nova Scotia, 2 years ago. We had a wonderful time and the ship is maintained in pristine condition. By the way, I live in Sacramento. I look forward to following your build.
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Thanks Bob.  Nice to see another local on here (I'm just up north in Loomis/Rocklin). I'd love to find some time to spend on one of these classics, so far most of my experience has been the "gunmetal gray" of the navy.
By the way, have you found any local model clubs yet (I've only seen the rc groups up here)?
I don't believe there is one is the Sacramento area. There is one in the Bay Area called the Hyde Street Pier Model Shipwrights: https://hspms.org  A modeler here on MSW, Clare Hess, who goes by Catopower on our forum, is active in that club and has his own blog also: https://shipmodeler.wordpress.com
Bob Garcia
Current Builds:
Getting back to the log.  Finally finished planking. Almost good enough to single plank but I like the walnut look so going double.  Lots of sanding/shaping on first plank layer.  Decide I am going to place the keel before the second layer (or at least lay as I go.  I like the look of the second plank layer slightly overlapping the keel.  Gives a more finished look without the gaps.  I also took an idea from someone elses log and am heat setting the second layer as I lay each plank.  Don't need to buy anything special though.  Just an old wood burner with a shading tip and then an extention cord with a pigtail/dimmer to reduce the wood burner to just enough heat without burning.  It's working real well to get the last little bend/curve at the bow.
Second plank is on.  Time for finish sanding on the hull.  The wood burner on lowered heat work quite well to set the planks without clamps or mess.  Working on the bulkhead stantions as well.  Set the keel as I was planking.  I followed on other by drilling a couple spots in the two primary/larger keel pieces so can insert a brass rod through the keel and into the false keel for extra strength.  Feels ready for the keel clamp.
Stantions placed, suppers cut.  I think sand and paint bulwark is next.  But first I need to deal with bowsprite.  The bulwark has come loose from the keel at the bow where I need to drill for the bowsprite.  I original tried wood glue and then a little ca in the inside after clamping just to get a little extra hold.  Didn't work.  So little wood to wood contact here.  U think I will create a small wedge to sit behind the keel post and flush with the top of the bulwark where it will be under the rail piece and monkey rail when I eventually add those.  At least it will give something I can glue to and pin (I think the model shipways version does something similar).  I'll send pics when I figure it out.
Tried the "sawdust mixed with elmers" after rough sanding the hull to make filler.  Came out a little darker than I had hoped so hopefully it will blend better after I put the final finish.  Got the filler piece at the bow that holds the bulwark better now. Time the mask and paint the bulwark exterior.
She's cleaning up well.  Bulwark are drying.  My process here was 1 coat of gesso (nice thin "primer"), filer where needed, gesso again, final filler, gesso, then two coats black.  All with sanding between.  Drilled and set the shaft pipe for the screws.  Trimmed rudder to fit.  Next is fully shaping the rudder and bowsprit deck assembly.
Decided to swap the approach to the white stripe at the waterline.  Instead of the 1.5x1.5 sapely, I trimmed down extra deck planks, primed and painted them, and then attached.  Makes it look more like a really good job masking and painting but actually easier.  My waterline isn't exactly correct (especially at the stern) but I'm not going to worry about correcting that.  Looks good enough for me!
