Kimberley,
the cord Comes in 50m lenth on wooden spools in either 0,3mm thickness or 0,5mm thickness. I found These at Ebay, but probably you can find them when Google-ing up "Diamantlitze", or on enclosed Web link
http://www.rc-toy.de/1390+-+Graupner+Diamantlitze.htm
The pics enclosed Show you what I meant relating to fastening Point above resp. underneath decks.
I remember that the plastic model hulls usually come in two halves, glued together with the decks carefully fitted in place before, unfortunately not allowing Access to the deck underneath afterwards. If you require a sturdy stresstaking basepoint you shall have to treat your deck before it is permanently glued in.
One pic Shows (still without ratlines) the spanners in the upper shroud cores (the smallest spanners I know of in brass are
fitted with M1 left and righthand thread and spanned by the common sleeve on the two spindles.
all this probably will not be of much help when rigging smaller plastic models, but I asume in case of someone rigging up a Clipper or other tallship in plastic could be considered in order to avoid slacking loose lines
Nils
Current builds
-Lightship Elbe 1
Completed
  • 11 months later...
Hello Fellow modelbuilders,
for those who have wondered where the Pictures for machined sail making of this thread had vanished to...., here a resubmit of the part 1 + 2 pics.
Somehow they went lost several months ago, and I trust they may be of interest to the one or other who is confrontated with self sail-sewing......
Nils
Part 1
Current builds
-Lightship Elbe 1
Completed
resubmit Part 2
Current builds
-Lightship Elbe 1
Completed
Thanks for the repost -- I was wondering what had happened.
Tony
Hello Guy,
I`m not sure if you mean the foot device for the sewing machine, this is a regular accessory for doing the last stitch line, (not the bolt rope sewing on...), or if you mean my drawn Hand scetch, first pic in post 33, which is representing my "learning by doing" sequence overview, after several Trials.....
The enclosed pics are showing the Trials on the spanker sail of my 1:64 scale HMS Pegasus, done in the described way
Nils
Current builds
-Lightship Elbe 1
Completed
  • 5 months later...
Update
some of the recently produced sails by the same method, but without steelwire reinforcement in the bottom boltrope
Nils
[Attachment = 230.580: CIMG0556.JPG]
rough prepared sail with sewed on reinforcement patches
[Attachment = 230.584: HMS Pegasus spanker riggimg.jpg]
hand-scetch for overview, lines blocks and arrangement
[Attachment = 230.577: CIMG0527.JPG]
bolt rope all around and fastening loops at the corners
[Attachment = 230.578: CIMG0531.JPG]
topsail shows a natural bow
[Attachment = 230.581: CIMG0571.JPG]
once started, make them all...
[Attachment = 230.582: CIMG0572.JPG]
[Attachment = 230.579: CIMG0533.JPG]
topsail with reinforcement patches
[Attachment = 230.583: CIMG1423.JPG]
rigging sails to the ship
Current builds
-Lightship Elbe 1
Completed
