HMS Speedy by Dave B - Vanguard Models - 1:64
You’re doing really excellent work with this model and with your log, I just stumbled on to it today. You’ve done a great job leaning into other logs for advice.  @DelF is an outstanding builder and a great source. For a near first model your workmanship is excellent.
Yes those holes are for rigging, easiest way to determine size is to look at the plans for what size rope goes through it and drill accordingly, it will be fairly small. Four anchors is fairly common, two rigged and two lashed on as spares.
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Share on other sites
Thank you Glenn for the postive comments and answer to my question!
I've made more progress, almost finished with the bowsprit. It was tricky getting the 3 wooden parts lined up and attached correctly, and again the photos from other build logs helped me out with that along with the excellent plan diagrams.
Dave
Dave Barnard
Current build: HMS Speedy (Vanguard Models)
On hold: Niagara (Model Shipways), Constitution (Mamoli)
Completed:
Marseille (Mamoli)
Duke William (Kammerlander)
Halifax (Lauck Street Shipyard)
Link to comment
Hi and here's an update. Been moving along in spurts this past few months. Seems like I spend as much time looking at other build logs as I do actual building. They are so helpful. The plans are great but seeing photos and detailed explanations is helping me with the rigging which I haven't done in this amount of detail for many years.
I've got the bowsprit on and a lot of that associated rigging attached, and now getting to work on the shrouds. For the first time ever I did serving of ropes. My Syren serving machine was a little rough going at first but got things smoothed out, I had some parts too tight apparently.
Thanks again for all the great help from the build logs!
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Thank you!
A couple more photos I took of the bowprit area
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Thank you whitejamest!
Working on the shrouds and made this little spacing device similar to what I've seen on other logs. CA glue practically welds this stuff together, it's extremely strong if you use a lot of the glue.
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Here's how I used it to determine the length and where the seizing above the deadeye should go. I used another trick (I think from Delf) and threaded a little white thread through the bottom of this so that I could work on these off the ship after doing all of them. Mast is tight in the deck so I know the position is accurate but I'm able to remove it.
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Then after completing the first seizing above the deadeye on all of them, I used the little spacer device to recheck all of them before doing the rest of the seizings.
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
  • 4 months later...
Hi everyone,
Looks like it's been over 4 months since my last update....crazy how time goes by
I've been making progress though, sometimes very slowly, with the rigging. The ratlines were definitely a trial and error experience for me.
I'm still following along the kit instructions/plans supplemented mainly by Delf (Derek)'s excellent build log to guide me.
Here are a few photos of where things are now with my Speedy. Please excuse all the lines left hanging but I want to make sure I haven't done something wrong before I make the final trimming of them and as long as I can still get to them easily I figure just leave them for now.
Thanks for following along!
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Thanks Theodosius! Yes that worked out well for me.
Here is my cluttered workbench and Speedy and photos of using the Quad Hands which has been extremely useful, recommended by other Speedy builders.
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
After getting one of the larger Quad hand sets, I later added the smallest one which has been handy for more options as shown in this photo. I love how heavy the bases are on these, nothing moves when using them.
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Here I've attached all the lines to the topgallant masts which are ready to put in place once I make sure I haven't missed anything that might be more difficult to access later on.
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
